East Bay Mod Day #2 August 6th
Discussion in 'Northern California' started by JLee, Jul 5, 2011.
  1. Jul 6, 2011 at 11:11 AM
    #81
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yep bring the steel I'll weld it up.
  2. Jul 6, 2011 at 11:31 AM
    #82
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    Finally gonna do it eh?! I don't mind helping with it if needed.
  3. Jul 6, 2011 at 11:45 AM
    #83
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Nah I already have mine made. But for those people who want to make one also, could copy mine as a template, but they have to bring their own steel. 1/8" should be fine
  4. Jul 6, 2011 at 11:51 AM
    #84
    JLee
    Jerry
    Grass valley CA
    I wasn't talking about you i know your are done.
  5. Jul 6, 2011 at 12:08 PM
    #85
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Bearing puller is all that's needed (slide hammer with the bearing puller attachment...not sure if they're considered two separate tools in the case of a bearing puller). Mostly, I'm looking for help getting to the point of removing the cv axle from the front diff. Someone to say, "yep, take that apart there, and then remove that, etc."
    That's right, you already did yours yourself, didn't you! And you're the one that made his own custom bearing puller for this bearing. I'm thinking I need to definitely check the calendar at home. And then maybe it's time to order the parts...
  6. Jul 6, 2011 at 12:15 PM
    #86
    MJonaGS32
    MJ
    SF Bay Area (East)
    I honestly couldn't take off the CV axle from the diff when I replaced my CV boot. Used a slide hammer and all, still couldnt do the trick. I ended up just changing the boot under the truck :D
  7. Jul 6, 2011 at 12:20 PM
    #87
    JLee
    Jerry
    Grass valley CA
  8. Jul 6, 2011 at 12:21 PM
    #88
    MJonaGS32
    MJ
    SF Bay Area (East)
    haha you and your exclusive smileys :p
  9. Jul 6, 2011 at 12:25 PM
    #89
    JLee
    Jerry
    Grass valley CA
  10. Jul 6, 2011 at 12:33 PM
    #90
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Wrong tool for the job. ;)
    Pry bar (for leverage, not for prying) and a 5 lb sledge works every time for removal and installation.
    I might need some prayers to the shipping gods so that my motor gets here timely. I REALLY want to make it to this mod day to lend my knowledge on the CV BS (and the 35 mm socket) and take advantage of Jerry...for his welding...you sick bastards.
  11. Jul 6, 2011 at 12:33 PM
    #91
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    damn only if i still lived in Novato.
  12. Jul 6, 2011 at 12:35 PM
    #92
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    dammit i hella wana go to these mod days and meet you all, but you know what it is.... work work work FML!!
  13. Jul 6, 2011 at 12:58 PM
    #93
    05Moose
    Jim
    Shit, I forgot about the 35 mm socket! And I assume I'll need something longer than a torque wrench to break that sucker free at something like 172 ft lbs of torque? (I don't have a clue!) I should see if my dad still has his huge breaker bar for this.
    Jerry, go ahead and put me down as a maybe. I'll have to get my act together and start getting the supplies/parts I need to do it. I just think this is the time to do it with all the experts there.
  14. Jul 6, 2011 at 1:01 PM
    #94
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Impact wrench. Air tools FTMFW. Don't even need anyone to stand on the brakes while you pull the nut off. :cool:
    But yes, a torque wrench will work. 174 ft lbs is torque spec for installation.
  15. Jul 6, 2011 at 1:18 PM
    #95
    JLee
    Jerry
    Grass valley CA
    i just did my CV so i have all the tools 35mm impact socket, Impact & a torque wrench good for up to "250lbs $$$"
  16. Jul 6, 2011 at 2:03 PM
    #96
    05Moose
    Jim
    That's right, you guys have power tools.:yay:
    I'm so used to doing everything the hard way. I even split all my cords of wood by hand (I've been doing a lot of this in the evenings lately). [​IMG]
  17. Jul 6, 2011 at 2:21 PM
    #97
    JLee
    Jerry
    Grass valley CA
    Oh yeah how do you think we get so much done at these mod days.
  18. Jul 6, 2011 at 2:37 PM
    #98
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    [​IMG] [​IMG] [​IMG]
  19. Jul 6, 2011 at 7:27 PM
    #99
    05Moose
    Jim
    Okay, count me in for sure. Guess I need to look up the bearing and seal part numbers and get them ordered at the dealership. Then up to the local parts store for the axle.
    Hey Ryan, how long do you need to stick the bearing in a freezer beforehand? (Maybe any of you know this?)
    Also, do you still have the custom bearing puller you made for this? I'm still planning on renting the bearing puller and slide hammer anyway, but who knows which would work better.
  20. Jul 6, 2011 at 7:42 PM
    #100
    06RadiantRed
    CA-Bay Area
    I didn't even stick it in the freezer. Went it pretty easy. But iv only done one, so i can't say it will be *easy*. Also something to rent/get would be a press fitting to hammer in the bearing. When me and my dad did mine, we just used a socket of similar size and took our time. But we had to use what was there to get it done. I'm going to look for the attachment for you when I head over to my parents this weekend. Its there somewhere.
