East Coast Gear Supply Freakin' Rocks!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by winkel, Dec 3, 2016.
  1. Dec 3, 2016 at 5:26 PM
    winkel
    winkel [OP] Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Hey Yota Fans,
    I installed a 2 1/2" lift on my 2014 Tacoma, TRD Off Road a few months back. I finished the front on a Saturday and the rear on the following Sunday. When I had the front done, Saturday night, I drove it to town. I had the dreaded droning vibration from about 25 mph to about 50 mph. It bothered me to say the least. Even with the diff drop spacers installed, it did it.
    I noticed that my driver side axle shaft had noticeably more slop in it than my passenger side. After some research, I ordered the replacement bushing from East Coast Gear Supply. I FINALLY got around to replacing it today and the vibration noise is GONE!
    For what it's worth to anyone considering this upgrade, I didn't unbolt the axle shaft from the hub. I just removed the bottom strut mount bolt and the two lower ball joint bolts. This allowed enough room to pull the axle shaft from the differential. I had to work around the strut and the axle shaft but it wasn't too bad. In total, I think it took me about 3 hours. It would go so much quicker on a lift but a good floor jack and some large jack stands are all I have.
    If any of you are considering this, I would highly recommend it. My truck has just under 36,000 miles on it now so I'll post back with an update in another 20,000 or so miles.
    Let me know if any of you have any questions about this.
    Winkel
    Kyitty, Crom, TACOVRD and 4 others like this.
  2. Dec 3, 2016 at 5:59 PM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    my 11 only has 30k i guess i have to look into this soon.
  3. Dec 3, 2016 at 5:59 PM
    Coleman42
    Coleman42 Well-Known Member
    NH
    14' White TRD Sport DCSB
    5100's @ 1.75, FN F(x) 17x8 0 offset bronze wheels, 265/70/17 Toyo Open Country AT3, Tint, SS3 fog lights, Leer 100XR Topper, Derped Front Emblem, Martin off road foundation rack
    That is exactly what I wanted to read. I did 5100s @1.75 and I get the same drone vibration with 36k........it's driving me insane. it's only been a week too. looks like I'll be ordering that......in about 3 minutes
  4. Dec 3, 2016 at 6:03 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I had them do mine while we were in town several years ago and haven't looked back. I could tell it fixed the problem within driving a half block.
    Crom likes this.
  5. Dec 3, 2016 at 6:07 PM
    winkel
    Corydon, IN
    Excellent! You won't regret it.
  6. Dec 3, 2016 at 6:07 PM
    J_Hacker
    J_Hacker Well-Known Member
    Somewhere in Virginia
    '19 White Tundra Crewmax
    Bilstein 6112, CB +2 Shackles, Soft Topper, Method 316, 295’s
    Good to hear. Having the same grinding drone. Hopefully it's the same problem you had.
  7. Dec 3, 2016 at 6:10 PM
    winkel
    Corydon, IN
    Crawl under your truck and wiggle each axle shaft right where they come out of the front diff. My driver side was noticeably looser than the passenger side. That was my clue.
    J_Hacker[QUOTED] likes this.
  8. Dec 3, 2016 at 6:12 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    How far in did the bushing go? I'm currently working on mine and having some issues.
    Won't go farther than this
    Edit:
    added pic:
  9. Dec 3, 2016 at 6:16 PM
    winkel
    Corydon, IN
    It looks like you're good. Mine went just flush with the steel around it. Smear some lube in there and re-assemble.
    Let us know how it turns out! I JUST finished mine about two hours ago.
    danbow[QUOTED] likes this.
  10. Dec 3, 2016 at 6:18 PM
    winkel
    Corydon, IN
    And of course, refill for the fluid that leaked out when you removed the axle shaft.
  11. Dec 3, 2016 at 6:19 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Thanks! I watched the video ECGS made and it looked like it went further in, but was hard to tell.
  12. Dec 3, 2016 at 6:27 PM
    J_Hacker
    Will do. Thank you for the tip :thumbsup::thumbsup:
  13. Dec 3, 2016 at 8:09 PM
    Coleman42
    NH
    Should I buy the 60$ tool to remove the bearing? or will a blind bearing puller work? the straight slide hammer type.
  14. Dec 3, 2016 at 8:34 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    don't buy the tool new. Find someone on here that has one. I ended up borrowing one from another member. The tool is specially made for this one job and it works great.
    Coleman42[QUOTED] likes this.
  15. Dec 3, 2016 at 8:39 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah there's a few in circulation around here and even a thread. You've just got to pay shipping to borrow it.
  16. Dec 3, 2016 at 8:45 PM
    winkel
    Corydon, IN
    If you can't find one, I'd buy it. I'm not sure about the other option because I haven't tried it. I do know that I'd hate to have everything torn apart and not be able to get the bearing out.
  17. Dec 4, 2016 at 12:28 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    The standard test that everyone has been using is to put the truck in 4wd. If the sound/vibration goes away, that's (the needle bearing) the problem.
  18. Dec 4, 2016 at 2:39 AM
    Coleman42
    NH
    Very valid point
  19. Dec 4, 2016 at 4:52 PM
    RIck Murray
    RIck Murray New Member
    2013 Tacoma TRD
    you should crawl back under your truck and remove that diff drop too, they're useless
  20. Dec 4, 2016 at 5:23 PM
    winkel
    Corydon, IN
    Really? I wondered about this. Even though the diff drop spacers are about an inch thick, I assume they don't actually drop it a full inch. I assume you are running a lift without the drop?
