East Coast Gear Supply Freakin' Rocks!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by winkel, Dec 3, 2016.
  1. Dec 4, 2016 at 5:36 PM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    How hard was it to get it in straight? If you get it cock-eyed I imagine it would not be a good thing
  2. Dec 4, 2016 at 6:05 PM
    winkel
    winkel [OP] Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    If you're talking about the bushing for the needle bearing replacement, I didn't have any trouble with it wanting to not go in straight. It went in fairly easy. I was a little concerned before I started tapping it in since I didn't fully remove my strut or axle shaft. I didn't remove the dust cover or the axle shaft from the hub.
    ecgreen[QUOTED] likes this.
  3. Dec 4, 2016 at 6:19 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Leave the diff drop in. It helps a little bit, so might as well. People will cry "omg it only rotates the diff and doesn't drop it. You'll starve your diff of oil" but I have been on here more than I care to admit, and I have never seen anyone's diff fail because of that.
    mikestaco17 and Justinlhc like this.
  4. Dec 4, 2016 at 6:25 PM
    winkel
    Corydon, IN
    Yeah, everything is working fine now so I'm probably going to leave it alone. The bushing was my last change to the drive train for now.
    I'm waiting on a set of rock rails from Stubbs Welding! It sounds like he's pretty busy right now but I'm not in a hurry for them.
  5. Dec 4, 2016 at 7:26 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Exactly. It twists more than it lowers, but it does in fact lower the differential and improve the angle. There was one guy who had one on his race truck and smashed into a rock while racing which broke his front diff and ever since then they have been exiled from TW :rofl:
    ItalynStylion likes this.
  6. Dec 4, 2016 at 7:27 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh I remember that dude! He modified his skid plate so it would work with the diff drop. Literally had two 3x3 squares jutting down like 2", and was surprised it didn't hold up to smashing into a rock at 30 mph. Freakin tard
  7. Dec 4, 2016 at 9:45 PM
    Pigpen
    Dan
    Northwest Montana
    The question is: do the aftermarket skids work with a diff drop? If not, that would be reason enough for me to not use one.
    For the record, I don't have one with my 3" lift and skids - for better or worse.
  8. Dec 5, 2016 at 7:17 AM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    For the diff drop to work with an AM skid, you would need to lower the entire skid so that it is still a flat surface, thus losing ground clearance. I wheel just hard enough that I need the AM skid's protection. I'm at 2.5ish of lift and my CV angles w/o diff drop are fine.
  9. Dec 5, 2016 at 7:21 AM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    If it is the same one I read about on here, I don't remember him going very fast when it happened, but I didn't bother to look to look it back up. I figure the point of the AM skid is to be flat... so you can slide on it. IMHO his solution was overcomplicated and .... well, clearly it didn't work. For an AM skid to work with diff drop, you need to lower the entire skid so it is still flat.
  10. Dec 5, 2016 at 1:06 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI the ECGS bushing is LONGER than stock. DO NOT push it all the way in as it will bind against the spider gear.
  11. Dec 5, 2016 at 3:30 PM
    Normagene
    Normagene MUTANT TACO
    New England
    Is this an issue with just the Off Road models or will a Sport model have the same possible problem.
    Thought I read somewhere it was for some reason because of the crawl feature. Not sure why that would make a difference.
    Gett'n a 3" front, 2" back, leveling kit installed Wednesday.
    mikestaco17 likes this.
  12. Dec 5, 2016 at 3:48 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It affects all 4x4.
  13. Dec 5, 2016 at 6:27 PM
    winkel
    Corydon, IN
    That's good to know!
  14. Dec 5, 2016 at 6:45 PM
    SB Taco
    SB Taco Well-Known Member
    Santa Barbara, CA
    2007 Silver Tacoma DCLB 4x4
    I only have half inch spacers up front and had the vibe. Did this fix and its gone. So awesome.
  15. Dec 5, 2016 at 6:47 PM
    #35
    winkel
    Corydon, IN
    Good stuff!
  16. Dec 5, 2016 at 6:52 PM
    #36
    Dgibson529
    Dgibson529 Well-Known Member
    Derek
    Westfield, MA
    NE F150s of TW FTW
    I didn't listen and did it with a standard slide hammer and it easily added another 2 hours worth of work. The tool is a must unless you can make it yourself
  17. Dec 6, 2016 at 6:56 AM
    #37
    Shikokaon
    Shikokaon Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    Did you guys replace the Axle Seal as well? Stock or with the one from ECGS? Looking online OEM is like $5 but ECGS one is like $20 when ordering the bushing...
    Thoughts?
    ecgreen likes this.
  18. Dec 6, 2016 at 3:31 PM
    #38
    Dgibson529
    Derek
    Westfield, MA
    NE F150s of TW FTW
    Went with OEM picked it up at the dealership prior to installing it
    Shikokaon[QUOTED] likes this.
  19. Dec 6, 2016 at 3:48 PM
    #39
    Shikokaon
    Portland, OR
    Thank you!
  20. Dec 6, 2016 at 5:32 PM
    #40
    winkel
    Corydon, IN
    I just reused my old seal. My truck only has 36,000 miles on it and it didn't look like I damaged it. Working from my garage floor like I was, I figured I'd do more damage to a new seal trying to get it in than I did to the old one taking the bearing out.
    After driving it about 40 miles afterward, it appears to be functioning fine (the seal).
    ecgreen and Shikokaon like this.
