East Coast - TRD Pro Wheels w/ BFG KO2 265/75/16 w/ TPSM sensors
Discussion in 'Wheels & Tires Marketplace' started by Overland&UpMoutains, May 26, 2021.
  1. May 26, 2021 at 9:46 AM
    Overland&UpMoutains
    Overland&UpMoutains [OP] Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    ***sold**
    BFG KO2 265/75/16 on TRD Pro Wheels with TPSM sensors
    - $1000 OBO
    - Located in DC, travel up to Philadelphia often so large delivery range.
    - Willing to ship if you really want to pay the shipping
    Tires - All-Terrain T/A KO2
    • Size: 265/75/16
    • Load Range: E
    • Tread Depth: 11/32” (15/32” new) measured at dealer in the last week
    • Miles: 20k
    • Style: Raised White Letters (facing IN)
    Wheels - TRD Pro 16-In. Alloy Wheel - -
    • Size: 16x7
    • Offset : +13 mm (I think, could be 4 mm)
    • Backspacing: 4.488"
    • Bolt Pattern: 6-139
    • Finish: Gloss Black*
    • Construction: Alloy
    *there is some rash on one wheel. It is a superficial scratch just the paint NOT a gash into the alloy. Easily painted.
    TRD4X4TOY likes this.
  2. Jun 1, 2021 at 4:58 PM
    Overland&UpMoutains
    Parker
    Deleware
  3. Jun 1, 2021 at 5:11 PM
    TRD4X4TOY
    TRD4X4TOY Well-Known Member
    2019 Toyota Tacoma TRD OFF ROAD
    Nice! That's a great deal.
  4. Jun 8, 2021 at 9:48 PM
    Dmvyota
    Dmvyota New Member
    Jordan
    TRD OR 21
    PM’d
  5. Jun 8, 2021 at 9:54 PM
    OG_Tacoma
    OG_Tacoma Well-Known Member
    Can I be bumped to the front of the line if I pay extra?
    Jim=2015 TRD PRO likes this.
  6. Jun 12, 2021 at 6:12 PM
    jharr125
    jharr125 Active Member
    Jake
    Atlanta
    2021 Tacoma SR5
    TRD Pro Grill TRD Pro Wheels 265/70/17 Nitto Terra Grappler Tires
    Still available?
  7. Jun 13, 2021 at 2:13 PM
    Btcomcast
    Btcomcast Well-Known Member
    Boston
    2024 Trail hunter
    Far to much money spent.
    Come on up to Boston I’ll pay for them :)
  8. Jun 14, 2021 at 1:50 PM
    Teleluvr
    Teleluvr Member
    2019 Tacoma 4x4 Utility
    Interested in the wheels. Do you want to separate them?
  9. Jun 14, 2021 at 2:53 PM
    Btcomcast
    Boston
    2024 Trail hunter
    Meet me halfway from philly lol
  10. Jun 14, 2021 at 5:08 PM
    Overland&UpMoutains
    Parker
    Deleware
    I’m in DC
  11. Jun 15, 2021 at 2:03 PM
    JManning1423
    JManning1423 Well-Known Member
    Jacob
    Columbus, GA
    2017 M/T Sand Tacoma TRD OR
    Too many to count
    If only you were closer to KY. Im east of Louisville, so out of my reach even with a half way meet. GLWS!
  12. Jul 13, 2021 at 11:02 PM
    Chippyb13
    Chippyb13 Member
    Michael
    2017 Tacoma TRD OR
    Leveling kit, Pro Grille
    Are these still pending. Live in Philly area.
  13. Jul 14, 2021 at 3:04 AM
    Overland&UpMoutains
    Parker
    Deleware
    long gone, sorry I updated the thread
