Easy Always On Outlet
Discussion in 'Technical Chat' started by ttaaooaa, Sep 2, 2022.
  1. Sep 2, 2022 at 4:30 PM
    ttaaooaa
    ttaaooaa [OP] Well-Known Member
    Aaron
    Colorado
    I'm looking to make the 12v charger on the dash (3rd gen) always on so I can charge things without the truck on. Is it possible to use an add-a-fuse on that circuit and connect it to another add-a-fuse on an always on circuit. I can't find anything online about whether this is safe or would actually change the ign triggered circuit to always on. I would plan on using fuses rated to the original circuit. Looking for a way to avoid having to solder the board. Thanks
  2. Sep 3, 2022 at 8:29 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I don’t understand why you’d need 2 add a fuses. Just fine one with power that’s always hot and connect your accessory to it.
  3. Sep 4, 2022 at 7:28 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I added a USB port in the center console switch panel. Then you can wire it to an always hot source. Much easier than trying to hack into the OEM port. You can find them on Amazon.
    ttaaooaa[OP] likes this.
