Easy inverter replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SouthtownTaco, Jun 6, 2023.
  1. Jun 6, 2023 at 6:28 PM
    SouthtownTaco
    SouthtownTaco [OP] Well-Known Member
    San Antonio, TX
    2016 TRD Offroad
    RCI Under Armor, Tailgate Lock, Bakflip F1, derped grill
    Does anyone know of a super easy way of replacing the stock inverter in the same location with anything more powerful? Is there a more powerful inverter that fits in the same spot? I'm dying for a real inverter... but don't wan to go crazy with wires or a non-stock look.
    ORtoCOTaco likes this.
  2. Jun 6, 2023 at 6:47 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I’d guess it’s capacity will be limited by it’s existing wiring, so an upgrade may just burn up wires and/or pop fuses.
  3. Jun 6, 2023 at 7:19 PM
    SouthtownTaco
    San Antonio, TX
    2016 TRD Offroad
    Thank you. You know this or are guessing this? Is there a wattage limit to the wiring?
  4. Jun 6, 2023 at 7:33 PM
    Meclizine
    Meclizine Well-Known Member
    CA
    '18 DCLB OR
    It's been a while, but from what I can remember the stock unit is very slim and I'm not sure how much head space that cavity has. Have you taken a look in there and measured it against new units? I was only in there for the 400W anytime harness so I wasn't looking at it too closely.
    SouthtownTaco[OP] likes this.
  5. Jun 6, 2023 at 8:10 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I don’t know what gauge wire is used, but I do know the input wire size will be a limiting factor,,, to what extent? I don’t know. You may well be able to put a slightly larger inventor in there, but I’d guess the factory wiring isn’t grossly oversized allowing for a much larger unit,,, but I could be wrong :D
    @caribe makaira is the man you want to talk to.
    SR-71A likes this.
  6. Jun 6, 2023 at 9:44 PM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    what kind of wattage are you thinking? the anytime mod and 400w output has been more than enough so far, at higher wattages you do get that a/c compressor power drop feeling.
    Chew and SouthtownTaco[OP] like this.
  7. Jun 7, 2023 at 3:08 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Using ohms law, you can calculate the amount of current the wires can safely handle. I would say it's highly unlikely you can safely upgrade the inverter (higher wattage) without upgrading the wires to/from the inverter AND the AC plug.
  8. Jun 7, 2023 at 1:48 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Well 400watt 120volt is like 3.3 amps upgrade will need to be made if you want real ac. You will need to look at manufacturer’s specs for the inverter you like
  9. Jun 8, 2023 at 10:13 AM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    12 volt Power into the inverter will be critical.
    30 amps at 12v is only 360 watts.
    30 amp wire is Number 10. Pretty hefty stuff.
    And you want more.....;-) Looking at #8 wire for sure.
    tacoma_ca, rqwood, ULURU and 2 others like this.
  10. Jun 8, 2023 at 12:13 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Don't forget that you need to take into account the efficiency of the inverter as well. I haven't looked at the one in my truck, but maybe there's a sticker on the unit?
  11. Jun 9, 2023 at 4:19 PM
    VTCAL
    2021 Sport
    rndsommer40 likes this.
  12. Jun 9, 2023 at 4:53 PM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
  13. Jun 9, 2023 at 5:02 PM
    ricphoto
    ricphoto Well-Known Member
    Ric
    PacNW
    ‘19 Limited/nightshade T4R
    Rack, 20”-17” tire switch, interior dog propfing, Front Runner rack, bud built hidden winch bumper, Ironman 9500 monster winch, Redarc dual battery system, Meso dual color interior lights.
  14. Jun 9, 2023 at 5:30 PM
    VTCAL
    2021 Sport
    The reference was mostly form factor considerations. Techy stuff..I leave to others ;-)
    Do you know what is in the taco OEM?
  15. Jun 17, 2023 at 8:13 PM
    VTCAL
    2021 Sport
    It would seem to me odd that a battery charger would care if the input was MSW or PSW.
    Some chargers have a lot of "SMART", so it may be so.
  16. Jun 17, 2023 at 8:17 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i've charged some batteries off a MSW inverter before. they don't ever seem to hold the same charge.
    my running theory is that the ESR of the chargers rectifier circuit is too high to allow for the steps to fully charge the smoothing caps. do i really know? no. but it sounds technically feasible.
  17. Jun 17, 2023 at 8:30 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    My battery charger has a lot of inductors, and inductors do not like the harmonics you get off of a msw
    soundman98 and D.A.S. Taco like this.
  18. Jun 17, 2023 at 9:12 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    I agree with this, and imagine a quality charger wouldn't work any different whether it's running off of a pure or modified sine because chargers typically use rectifiers, and rectifiers don't care about the shape of the waveform.
  19. Jun 18, 2023 at 3:06 AM
    Zuba Gooding Jr
    Zuba Gooding Jr Well-Known Member
    People run heavy gauge wire for stereos all the time directly from battery. Think 1500+ watts.
    Its not hard to do or a big deal. There is definitely space under there for a bigger inverter, but you will have to check dimensions. You could put it under passenger seat if needed and just leave the existing one too. Theres also floor grommets to run grounds to the frame in the shortest path possible.
    Like others said just make sure your weakest link, fuse or wire, can handle the amps.
    D.A.S. Taco and ricphoto like this.
  20. Jun 18, 2023 at 4:24 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    The square wave (switched ac) is a perfect voltage transition as a sine wave is a transitional wave the actual peak equal reaching the max voltage for a small amount of time. I think it’s a sales trick to get you to buy something else. But whatever floats your boat
