Easy Maintenance to do- Grease drive shaft U-Joints using the 5 Zerks on a 2nd Gen 2014 TRD OR DCSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UBYBC, Apr 10, 2016.
  1. Jun 4, 2017 at 10:10 AM
    #61
    Sidney Vicious
    Sidney Vicious Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    Do I understand that a 2wd Prerunner (mine is a 2013) does not have zerks?
  2. Jun 4, 2017 at 10:13 AM
    #62
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    My 2015 Tacoma PreRunner 2WD does not have zerks.
    Wife's 2014 4Runner SR5 2WD has one zerk on each end.
    Some do - some don't - you have to get under your truck and check things out to know for sure.
    ready6delta likes this.
  3. Jul 8, 2017 at 1:05 PM
    #63
    UBYBC
    UBYBC [OP] Well-Known Member
    2014 Tacoma TRD OR
    I noticed my 2 year old Lucas Oil Red N Tacky was separating in the top and bottom of grease gun and some oil was running out. It is stored in a TX garage, so I'm not surprised if the constant hot temperatures help accelerate the breakdown. I changed grease to Valvoline Synthetic and it visually appears to be a bit thicker but feels about the same. I just finished changing all the gear oil and greasing all the zerks. Now onto figuring out why the transmission hunts and lurches in slow and go traffic since I know the driveline is tip top.
  4. Jul 8, 2017 at 3:19 PM
    #64
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Mine were bone dry when I bought my truck with 40k. Was chasing some clunks and realized it was the poor u joints. Truck was routinely serviced by previous owner at toyota. If you haven't gotten around to doing this id just get it done. Lame that some are ungreasable
  5. Oct 16, 2017 at 4:34 PM
    #65
    SourCreamTaco92
    SourCreamTaco92 New Member
    Southeast Michigan
    2015 DC SB TRD OR
    I just want to second everyone else's experiences here with the u-joints being a bit on the dry side. Especially, as mentioned, the rearmost front driveshaft u-joint.
    My heat shield would not come off for anything, so I got creative and using a normal grease fitting and a pair of vise-grips, routed the grease gun hose over the exhaust tubing and over the heater plate with the fitting facing towards the passenger side of the truck- with the vise-grips routed in between the heat shield and the transfer case I was able to push the nozzle down onto the zerk. That joint was bone-dry, and the other joints were definitely under-greased.
    Definitely worth checking ASAP if you've been relying on a dealership to do it beforehand, as I have.
