Easy Map light bulb replacement
Discussion in 'Lighting' started by ExFordFan, Aug 11, 2010.
  1. Aug 11, 2010 at 7:04 AM
    ExFordFan
    ExFordFan [OP] Semper Fi
    Mark
    Wauwatosa, WI.
    Stock
    Last night I switched all my lights to LED's. I had read here how hard it was to pull the oem map light bulb out of the socket. An easy way to remove this bulb is to push a piece of 5/16" hose ( I used clear hose from hardware store (about $0.50) over the bulb and pull it out. The end result is the bulb is out with out any smudges or marks on the reflector.
  2. Aug 11, 2010 at 7:06 AM
    JAG
    JAG Well-Known Member
    Good idea
