Easy method to grease the clutch fork ball
Discussion in '4 Cylinder' started by iroh, Oct 7, 2015.
  1. Jul 6, 2018 at 2:23 PM
    downhillbik3r
    downhillbik3r Well-Known Member
    James
    Carson / Big Bear
    2016 2.7L 4x4 5spd
    Kings, 4.88's, ARB, +2 LT, DMZ SUA
    Greased my clutch fork the other day. This write up was a great help. But, I performed it a little bit differently. My fork was extremely loud and obnoxious.
    1. Move the boot out of the way.
    2. I was able to push the fork towards the slave cylinder and move it enough to create a small gap between the fork and the ball it pivots on.
    3. I then took a grease gun with a "needle" style end long enough to reach the clutch fork ball and squirted some grease between the clutch fork and the ball. Easy peasy, no need to remove the slave cylinder.
    The clutch fork is now silent and pedal feel is much better.
    t1m829 likes this.
  2. Jul 6, 2018 at 2:52 PM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    i used engine assemble lube made by lucas no more noise been about a year now
    Dalandser likes this.
  3. Oct 22, 2018 at 2:25 PM
    Portlander
    Portlander Active Member
    Portland, Oregon
    98 XTRA 3.4 MT 4x4 TRD / BU CK CL LX SR TW
    Just did this technique -- excellent. Used Mobilgrease XHP 222 Special I had preloaded.
    downhillbik3r[QUOTED] likes this.
  4. Dec 15, 2018 at 4:15 PM
    Wulf
    rock raisin
    Just did this, straw was an awesome idea :thumbsup:
  5. Mar 2, 2019 at 7:40 PM
    Bowers86
    Bowers86 Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    I have a question regarding this process. I tried to lube mine today and couldnt really get the fork away from the pivot/ball. Is there any trick to getting that space to place lube in between the two? Since the fork pivots on that point, how much space can be achieved?
  6. Mar 2, 2019 at 7:51 PM
    Portlander
    Portland, Oregon
    You push the clutch fork towards the slave cylinder such that it no longer pivots on the point you mention. There will be enough of a gap to use something like a long needle grease gun fitting.
    Bowers86[QUOTED] likes this.
  7. Mar 7, 2019 at 12:31 PM
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    Maybe I’ll have to press harder next time, thanks. For now I think I got enough grease in there to stop the squeaking temporarily. When the weather warms I’ll try again.
  8. Mar 7, 2019 at 12:46 PM
    eon_blue
    Azusa, CA
    Same procedure for us 1st gens too I imagine?
  9. Mar 7, 2019 at 1:04 PM
    Wulf
    rock raisin
    Yup. Worked better than trying to use a spray can of whatever oil
    eon_blue[QUOTED] likes this.
  10. Mar 7, 2019 at 1:04 PM
    eon_blue
    Azusa, CA
    I'll have to do this next time my clutch starts creaking. Both times it resolved itself after awhile but it probably could use some grease.
  11. Mar 16, 2019 at 5:04 PM
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    With the decent weather I was finally able to jump back underneath. Doing it in a cold dark garage definitely didnt do me any favors. The moly grease I put in there worked like a charm, hopefully it'll last a while but easy enough to do when it's not miserable.
  12. Mar 28, 2019 at 5:08 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Any info for the 6sp tranny and how to do this?
  13. Jun 11, 2019 at 3:31 PM
    Ramphonic
    Ramphonic Well-Known Member
    Cape Cod
    2k1 SR5 4x4 V6
    Adjustable Bilstein, AAL Lift, Eagle Rims with BFG ATs, Trd Exhaust, Clear Corners, Red Clear Tails
    I couldn't get the straw in between even with the slave moved out of the way.. Squeak back one later :(
  14. Jul 7, 2019 at 8:09 PM
    Pandatruck
    Pandatruck Member
    ya Know, my clutch pedal squeaks a bit too, but it’s kind of endearing, in a way...
