Easy methods to try and get rid of p0420
Discussion in '1st Gen. Tacomas (1995-2004)' started by rll131, May 22, 2012.
  1. May 22, 2012 at 8:38 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    2000 2.4 liter 4 banger
    I've heard lacquer thinner in the gas also have heard sea foam a
    In the gas any other ideas I really don't think it's my cat but I could be wrong I'm still getting 27 mpg on ave it's a 2000 2.4 with only 77k miles are there any possible ways to test o2 sensor without a shop or test the cats money pretty tight right now.
  2. May 22, 2012 at 8:41 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    clean 02 sensor or replace. clean air intake. clean maf. clean throttle body. replace air fuel ratio sensor
  3. May 22, 2012 at 8:41 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    If money is tight, I wouldn't recommend putting lacquer thinner in your gas tank... I'm no expert but I believe you would be buying a new motor after that. Wait until you have enough cash to get it tested/fixed. Some shops will give you a free estimate.
  4. May 22, 2012 at 8:42 AM
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    your sensors will go bad before the cat will
  5. May 22, 2012 at 9:09 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    Yea I'm not positive but I don't believe it is the cats will running sea Foam through the gas tank clean the o2 sensors up
  6. May 22, 2012 at 9:16 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    :rofl:
  7. May 22, 2012 at 9:20 AM
    ohicos
    ohicos Member
    San Diego, CA
    2012 DCSB ???
    I recently used the Spark Plug Non Fouler method described in this link:
    http://honda-tech.com/showthread.php?t=1841240
    I used it on my 2005 Tundra, I had the engine light on for almost a year, I scanned it and it was the P0420 code.
    After I did the non fouler mod I cleared the code, then I completed a full drive cycle (this is needed here in california or you will not pass smog check), scanned it again and no codes were registered. Next day went to the smog test station and passed.
    Scanned it again a few weeks after the smog test and still had no codes registered.
    Hope this helps.
  8. May 23, 2012 at 7:37 AM
    rll131
    rll131 [OP] rll131
    raymond
    elkton md 21921
    I don't want to hide the problem just was curious if there was a easy way to tell what the problem was
  9. May 25, 2012 at 11:02 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    The URD o2 sensor simulator will probably fix the code 420. I haven't tried it yet. My 420 code is just pending and hasn't set off the light yet. I have a slight miss in the idle, and I think I could get better mpg. I'm gonna run the seafoam for a while and see if things improve. I have seen improvement after 2 tanks of gas with seafoam, but it could idle better. I will pull codes again soon and see if it's still pending, and may go with an o2 simulator.
  10. May 26, 2012 at 9:07 PM
    bzwarts
    bzwarts Well-Known Member
    brad
    ontario
    01 tacoma trd 5 speed fully loaded w sunroof
    i have just went through this only with a v 6. i purchased the truck with the deal that the trucks engine light is out. it had the same code as yours does. i got it with the light off and within 75 km the light came back on. the mechanic replaced both the upstream and the downstream and still no fix. then i went to an older friend who gave me the lowdown. when the emissions are not up to specs through the readings from the sensors, the ecu will cut the spark to a selected cylinder every once in a while to dump extra fuel into the cat, or cats in my case, in an effort to get them to light up and burn. what is happening is that the cat, or cats is unable to light up and burn the unburnt hydrocarbons coming out of the motor, and the downstream is sensing that there is no change in the exhaust hydrocarbons. if you plug in your obd 2 and can look at live data, get the truck up to full operating temperature and look at the o2 sensors. im not shure what they are referred to on the live data screen, but the upstream (closest to the motor) sensor resistance will jump around a bit, whereas with the downstream (after the cat or cats) should maintain a constant reading, even as the motor is revved. if the reading is jumping around, the cats have "bit the cookie" and are not burning the unburnt hydrocarbons. after the cats were replaced, it was like a whole different truck. it was more powerful, smoother and quieter, but i did not moniter that much of a change (if any)in fuel economy. good luck!!:)
  11. May 27, 2012 at 12:39 PM
    koco
    Bay Area Ca.
    '01 Taco
    This explains my misfire.
  12. May 27, 2012 at 1:02 PM
    bzwarts
    brad
    ontario
    i replaced both of my cats and it completeley fixed the problem. the guy i bought it off of left the old sensors in the truck when i bought it, and when i installed the new cats i put in the old sensors just to see and the light went off after a bit of driving. i then sold the new sensors on kijiji. the pair of cats were about 600$ up here in canada. luckily the seller offered to pay half for me .
    my experiance is on a 2001 tacoma trd with a v6 3.4l. good luck
  13. May 27, 2012 at 1:13 PM
    bzwarts
    brad
    ontario
    oh and as well laquer thinner will definitley light up the cats, but it would light them up too much and melt them out. inside the cats are hundreds of platinum honeycombs that the hot gasses blow through. and make red hot. the red hot combs light up anything burnable. once they get too hot (by dumping obscure burnable substances through) theyll just burn out some of the combs inside, therefore making them useless. i would also assume it would melt out the exhaust valve??!!
