Easy Oil Extraction
Discussion in '2nd Gen. Tacomas (2005-2015)' started by monsterkx2fiddy, Apr 20, 2017.
  1. Apr 20, 2017 at 1:59 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    When you have to use your own hand....
  2. Apr 20, 2017 at 2:08 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    your
    I went the GF 6.9 rule, put out or get out.
    monsterkx2fiddy[OP] likes this.
  3. Apr 20, 2017 at 3:39 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    If these were effective or worthwhile in the least you would see them at dealerships, shops and oil change places.
    DGXR and knottyrope like this.
  4. Apr 21, 2017 at 9:10 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    My GF wants more too much pumping... now I'm trying to improve my cardio game LOL
  5. Apr 21, 2017 at 9:21 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Exactly!
  6. Apr 21, 2017 at 2:08 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    The gadget in the OP has served me well. Bought it about 10 yrs. ago and it's doing fine. I've siphoned oil a few times and many on an Isuzu Rodeo that did not have a transmission drain plug. Saved me from a Dexron shower when I pulled the tranny pan.
    Useful for siphoning brake/power steering fluid reservoirs. Turkey basters die a fast death when exposed to chemicals. Seal is eaten quickly by whatever chemical they are sucking out.
    The one car I used it on a couple of times for oil extraction was a Mercedes gas car. The first time I did that, I got down below to pull the engine oil drain plug after the extraction was done. There was about 2 oz. of oil left in the bottom of the engine. Results will vary with engine/pan designs.
    Navar and fla_sun like this.
  7. Apr 21, 2017 at 2:56 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
  8. Apr 21, 2017 at 3:05 PM
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    x 2. And with even a stock lift, I can use a cheap bucket to catch the oil which is easier to deal with than the short pans. I put down a piece of old cardboard to catch splashes and make it easier to roll and slide under the truck. Car is about 6 inches off ground, so even with ramps, it is not fun.
  9. Apr 21, 2017 at 3:14 PM
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    Nope. I'd be willing to bet if you did this then just out of curiosity removed the drain plug oil would still come out. This isn't going to get all the old oil out.
    Why would you want to put clean oil in with contaminated oil?
  10. Apr 21, 2017 at 3:16 PM
    Navar
    Corona CA
    The dealerships and repair shops do have these. They just don't use them for oil changes. Probably for a good reason.
    Typically they use them to bleed brakes
    NAAC3TACO likes this.
  11. Apr 21, 2017 at 3:17 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Our shop uses them to empty fluid out of transmission cores before they are sent back to the factory.
    Navar[QUOTED] likes this.
  12. Apr 21, 2017 at 3:18 PM
    Navar
    Corona CA
    That and PS systems
  13. Apr 22, 2017 at 4:32 PM
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    I like the idea of the Fumoto valve, what with after market skid plates and all. If there weren't for 11 bolts and the use of a floor jack required for removal, I'd stay with the old fashioned way. But the front four bolts are a challenge to install and remove on my APEX bumper.
    Navar likes this.
  14. Sep 22, 2017 at 1:09 PM
    Wadar
    Wade
    A few.
    Update:
    First oil change with the Fumoto today, and I'm quite pleased with this product. I simply installed the tube, flipped the lever and walked away. No skid plate removal, no floor jack, no worries! While the oil was draining I slid the pan under the filter and changed it, then flushed the engine. Less than half an hour for the process, it took longer to go to Auto Zone to buy supplies and recycle the old.
    On a side note the folks at AZ said that was the cleanest used oil they had seen in some time.
    Rockoma5 likes this.
  15. Jan 8, 2019 at 8:26 AM
    #35
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    I use the extractor on my wife's van and plan to use it on my PRO, which should be in this week. Makes oil changes fast and easy and gets 99% of oil out. Fumoto valves work awesome well as i have used them on my other past cars but the extractor is awesome. I need to find the info on the easy oil change for the oil filter as well as I saw someone replace it after the first time with a valve for no mess either.
  16. Jan 8, 2019 at 8:56 AM
    #36
    Lester Lugnut
    b_r_o likes this.
  17. Jan 8, 2019 at 10:18 AM
    #37
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    They're great for extracting fluids from diffs and such when the drain plug is stuck.
    Used a friends MightyVac for the first time this weekend for an oil change on a Volvo, 7.8 quarts. Wasn't that impressed. Cleaning the tubes afterwards, so oil doesn't get everywhere, was more work than doing an oil change the traditional way. Nice idea, has its place for sure, but I'm good...I'll do it the old fashion way and use that time to do a general undercarriage inspection every 5,000 miles.
  18. Jan 8, 2019 at 10:33 AM
    #38
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Be lazy and spend 80 bucks on a tool I don’t need, or take out my drain plug for free
    DGXR likes this.
  19. Jan 8, 2019 at 7:08 PM
    #39
    Rockoma5
    St Louis
    I don’t clean the tube i put paper towel in it so nothing comes out and put back in box. I can do an oil change within 10 min
  20. Jan 8, 2019 at 7:45 PM
    #40
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I have a 100% stock suspension and I have never had to jack up the truck... Or my wifes expedition.
