easy subwoofer options
Discussion in 'Audio & Video' started by Otis1382, Dec 9, 2016.
  1. Jun 9, 2018 at 9:27 PM
    #61
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
  2. Jun 13, 2018 at 1:25 PM
    #62
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    How'd your install go? Need to buy anything extra?
  3. Jun 13, 2018 at 1:41 PM
    #63
    CJREX
    CJREX Well-Known Member
    Georgia
    I needed a cheap adapter, but depending on your head unit you may not need anything.
    The Kenwood will accept either low level or high level inputs.
    I had an aftermarket Pioneer head unit that had a single Sub out RCA jack so I had to buy a Y-splitter (~$8) for the sub's RCA input.
    You have to have both a left and right input or the sub power will be halved which is why I needed the Y-splitter.
  4. Jun 13, 2018 at 2:14 PM
    #64
    Dirty Harry
    Andrew
    SW Florida
    Does the sub pull power directly from the factory head? Cus that'd be awesome. I'm already running quite a few wires up in the engine bay due to some offroad lighting so I'd prefer to not have to run another hot wire to the battery.
  5. Jun 13, 2018 at 2:28 PM
    #65
    CJREX
    Georgia
    No, it has its own power line.
    You tap into the head unit for speaker input and the Remote or Power Antenna line to power the sub on.
    If you go to the Kenwood website you can download the manual which shows all of the connections.
  6. Jun 13, 2018 at 2:30 PM
    #66
    Dirty Harry
    Andrew
    SW Florida
    Did you end up running yours to the battery?
  7. Jun 13, 2018 at 2:32 PM
    #67
    CJREX
    Georgia
    Mine is in an F250 so I had many spare circuits for accessories.
    I just tapped into one of those, one of the trailer circuits if I recollect properly.
    Dirty Harry likes this.
  8. Jun 13, 2018 at 7:15 PM
    #68
    jmeitz
    jmeitz Audio Solutions
    Jeremie
    St. Louis, MO
    2016 Tacoma trd sport
    Remote Start Lift Stereo Leather LED lights
    I did a JL 12tw3 off a 5 channel amp
  9. Jun 19, 2018 at 10:27 PM
    #69
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    I finally finished installing the wiring for the amp and sub this afternoon and got it tuned. It sounds pretty good but I think I’m going to add a second sub. It fills in the low end pretty seamlessly as is, but is lacking in outright punch. Wiring a second sub and box in parallel will be extremely simple fortunately.
    Man of Steel TRD likes this.
  10. Jun 20, 2018 at 8:15 PM
    #70
    skierd
    David
    Fairbanks, AK
    I’d like to amend my previous review. Today I learned how important it is to have the proper source material for your audio when you go to evaluate its performance. Put simply, Bluetooth sucks for quality.
    With my iPhone wired in instead of streaming over Bluetooth, the pioneer sub and Kenwood amp combo is actually quite impressive. It doesn’t slam but there is definitely enough bass to balance out the kicker tweeters and the stock speakers on the stock head unit. It’s very “adult with a nice stereo” vs “teenager with giant rattling subs in the trunk”.
    It also goes deeper and hits accurately enough for metal (my favorite test is Metallica “Dyers Eve” due to all the double bass) while having enough boom for pop, electronica, hip hop and rap. It is *almost* a perfect balance for a system based around the stock head unit. I’m very happy with it, especially considering the overall cost and the fact that should I decide that too much is what I really want it’s as simple as adding a second pioneer sub+box. The only holes I had to drill was for the mounting screws for the amp and the small hole in the wiring harness plug on the firewall to run the 8ga power cable.
  11. Nov 14, 2018 at 4:17 PM
    #71
    skierd
    David
    Fairbanks, AK
    Another update: I’ve noticed that the subs responsiveness falls off pretty steep on deeper bass notes. Since the box is only 0.15cuft I made the assumption that’s it’s on the small side so I added some poly fill to see if I could help it out. Results so far are promising, the bass range seems to go deeper now and it’s a little bit louder.
    I should also note, the sub that comes in the box is not the Pioneer 8” DVC sub but some other single voice coil Pioneer branded sub. Since I will be buying a second box soon, I think, I may try to swap for the 8” TS-SW2002D2 in this box and put it in the new box I order to go with it. Other option is to get a JL CP108LG-W3v3 instead, I’ll check out my local audio shop for a test ride after the holiday maybe.
  12. Feb 11, 2019 at 9:38 PM
    #72
    skierd
    David
    Fairbanks, AK
    That sub and box won’t fit in a 3rd gen with the cubby in place, not sure about a 2nd gen. You’ll need power and ground for the amp of course, and an rca cable to run from those leads to the amp, and some speaker wire. But yeah I bet it’ll sound great!
    I reworked my pioneer sub a little this afternoon. I bought and installed the pioneer TS-SW2002 8” before Christmas and filled the box with polyfill. It was better, it not great. Today I spent a little bit of time rewiring the box (originally I reused the original 16ga wiring) and more time tuning then I had before. Low bass is no longer a problem, the sub is nice and punchy for bass and kick drums but can hold its own for rap and hip hop. With one sub it fills in the low end for a nice balanced setup with my new speakers. I definitely want to add a second one now, but for most a single will be a great setup.
    Bridge4 likes this.
  13. Feb 26, 2019 at 11:51 AM
    #73
    4bangerr
    4bangerr the little engine that could
    Hawaii
    2017 Mag Grey SR Access Cab 4 Cyl.
    -12" XFIRE 4 ohm dvc subwoofer 500 WATT rms w/custom ported box -600 WATT XFIRE amplifier -1 way viper alarm -LED lighting conversion interior & exterior -HID low beams & LED high beams -AVS front visors -5% tint all around -stainless steel truck tip -TRD sport wheels w/black mag lugs
    can't go wrong with a bazooka tube. i got a Alpine 10" bazooka with a 800 Watt CRUNCH amp.
  14. Feb 26, 2019 at 3:34 PM
    #74
    stec06
    stec06 Well-Known Member
    So far, this is my experience with a single 8" woofer. Really fills out the low end and takes the burden off the front 6x9s. Not super loud, but nice and clean.
    ready6delta likes this.
  15. Dec 10, 2019 at 9:56 AM
    #75
    TALLNDIRTY
    TALLNDIRTY Active Member
    Winnipeg Manitoba
    2015 Tacoma Access cab SR5 4cyl 5spd 4x4
    Screenshot_20191209-231451_Samsung Internet.jpg Screenshot_20191209-231519_Samsung Internet.jpg Screenshot_20191209-231608_Samsung Internet.jpg Screenshot_20191209-231711_Samsung Internet.jpg I added these to my 2015 Access cab 4x4.....all the while keeping my factory head unit. Sounds amazing..a bit overkill but I am happy with it
  16. Nov 3, 2022 at 8:41 PM
    #76
    Rydah
    Rydah Active Member
    Rob
    Houston, TX
    2014 TRD Off Road
    Why start a new one, when you can revive an old one, eh? I've got a 2nd Gen with a Kenwood DMX47S head unit installed. Specs say 50W x 4 for power output. I replaced the front door (non JBL) speakers with some Kickers, and it's already a nice improvement, but I'd like to add a non-intrusive sub for a better deep base (I need my back seat and foor space). I'm an old guy, so won't be "thumpin' the hood", but just want to bring out the lower frequencies without having to crank it up too much. I'm thinking an underseat, powered sub? Anyone with similar setup that they could recommend? Thanks.
  17. Nov 4, 2022 at 7:58 AM
    #77
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    https://www.kenwood.com/usa/car/speakers/ksc-sw11/
    This is what you want. Pretty easy to install, no need to run anything through the cab to the battery.
  18. Nov 4, 2022 at 10:49 AM
    #78
    Rydah
    Rydah Active Member
    Rob
    Houston, TX
    2014 TRD Off Road
    Thanks. That's one that was on my list, so great!
