Easy Transmission Cooler Install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ernscott, Jul 29, 2021.
  1. Jul 29, 2021 at 3:52 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    RIPP also is coming out with a kit that uses a new cooler for the trans and re-pipes the old one for steering. I was thinking about it before but saw that is about to come out. As long as you don't have an extra heat exchanger for a S/C easy setup. The setup here is nice since it would give ample room for the S/C heat exchanger.
    Skydvrr likes this.
  2. Jul 29, 2021 at 3:59 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Looks like its just 05-15 Tacomas, no 3rd gen love?
    Skydvrr likes this.
  3. Jul 29, 2021 at 4:03 PM
    caribe makaira
    Caribbean, Puerto Rico
    So 2 coolers for the steering on your Taco? 'cause you already have one...
    Skydvrr[QUOTED] likes this.
  4. Jul 29, 2021 at 4:04 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    The OEM one is wack.
    ernscott[OP] likes this.
  5. Jul 29, 2021 at 4:13 PM
    ernscott
    ernscott [OP] Well-Known Member
    2021 Tacoma
    I've done many coolers in my career. Used to buy large AC condensers and braze ends on them and install them in small busses. Might have easily done 200 of them and it for sure increased tranny life. Worked on a large fleet. This one was easy for me and kinda fun to see just how clean it could be done. I was told that with the connects pointed down - it reduces potential air pockets. But I have done them in just about every direction with never an issue. Now my "tech" experience could use some work. I'm more of a hands on guy with brakes and suspension and frame replacement or repairs. Sure did my fair share of leaf spring rebuilds and ball joints !!
    nudavinci64 and Skydvrr like this.
  6. Jul 29, 2021 at 4:16 PM
    Mike402
    Palm Springs, CA
    Your honor the defense rests
  7. Jul 29, 2021 at 4:17 PM
    ernscott
    2021 Tacoma
    Skydvrr likes this.
  8. Jul 29, 2021 at 4:57 PM
    ernscott
    2021 Tacoma
    Just want to say a big thank-you for the nice words on here. It makes the time spent on a job totally worthwhile and satisfying. Kindest Regards to all Scott
  9. Jul 29, 2021 at 5:42 PM
    nudavinci64
    Robert
    Pretty sure it would work on 3rd gens too. Maybe some mounting adjustment. It wouldn’t be Shocked if a third gen version was coming
  10. Jul 29, 2021 at 5:43 PM
    nudavinci64
    Robert
    Nice I can see that that was a lot of the reasoning behind the directional ones. Nice to see more options
  11. Jul 29, 2021 at 5:54 PM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    I literally just installed a trans cooler today lol
  12. Jul 29, 2021 at 6:33 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I'm putting my old OEM one on my Kubota lol.
  13. Jul 29, 2021 at 7:30 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Idk why, but retro fit was never in my mind with the oem. Last year my buddy replaced the whole AC system in his 02 Accord. Snagged the evaporator and used it for my tig cooler. Way overkill, but works well! Needless to say, the mind is schemin
  14. Jul 29, 2021 at 8:16 PM
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    nic work... looks clean... remember to check the tranny fluid before driving... its a bit of a pain since theirs no dip stick for it...
  15. Jul 30, 2021 at 4:10 AM
    #35
    ernscott
    2021 Tacoma
    I should have mentioned - that was the hard part !! Thanks
    Illini Tacoma likes this.
  16. Jul 30, 2021 at 6:25 AM
    #36
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Glad this was easy for the OP. For me, you might as well ask me to install a Flux Capacitor in my truck. Both have about the same chance of success with me doing the installation. Zero :sawzall:
  17. Jul 31, 2021 at 5:25 AM
    #37
    ernscott
    2021 Tacoma
    Well I say it was easy because there was so much room in there. Normally with the older automatic transmissions - I would have gone much bigger or even doubled them - but there is so much controversy about keeping a hotter temp. range in the newer stuff, that I did not want to overkill this one. My 56 Chevy wagon has two of them stacked and has been working great for many years with the two speed power glide. Regards Scott
    Illini Tacoma and Skydvrr like this.
  18. Jul 31, 2021 at 7:28 AM
    #38
    caribe makaira
    OP, would you so kind and answer post #12...:popcorn:
  19. Jul 31, 2021 at 8:45 AM
    #39
    ernscott
    2021 Tacoma
    Hi That is actually my "out" side going back to the trans. On this cooler - it does not matter which port is in or out, as it is "by-Directional". It can be mounted in any direction that best suits your needs - downward, upward, or sideways.
    I chose the Derale Series 9000 Part #13624, If using another type cooler best to fine read the instructions to see if this still applies. Most will. Regards Scott
  20. Jul 31, 2021 at 10:09 AM
    #40
    caribe makaira
    So since the radiator input (hot & high) is also on the passenger's side and flows horizontally to the Driver's side and exit (cold & low) It would seem thermally beneficial if you inverted the ports of the transmission oil cooler, maybe.:pccoffee:
