Easy turn off annoying beep chime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trojan8975, Mar 23, 2015.
  1. Mar 24, 2015 at 11:46 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Well, shit, it doesn't work with the fob. In other words, I can't lock / unlock the truck while it is running with the fob, even with this mod done. Arrggg.
    Does work with the manual or power lock buttons though. I'll just cut a second key and keep it on a small clip on my keys to remove as needed to manually lock the running truck. Better than it was, fo' sho'!
  2. Mar 24, 2015 at 12:11 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I found the OP's directions a little hard to follow, overly simple for a retard like me.
    Here's a more thorough explanation and pics:
    Turn engine on.
    Turn steering wheel left, exposing the screw behind the steering wheel on the left front of the steering column plastic. Remove that screw.
    Turn steering wheel right, exposing the screw behind the steering wheel on the right front of the steering column plastic. Remove that screw.
    Turn wheel back to center.
    Turn engine off. Remove key.
    Press in on the sides of the bottom piece of trim pastic surrounding the steering column and kind of wiggle, squeeze, pry on it. It will disengage from the top plastic and you can remove it. This is a little awkward with the tilt adjuster but you can maneuver the column around and move the plastic off.
    Look at ignition / key switch. The white two prong connector on the front side of it is the target. Pic 1, below.
    Unplug that connector. Pic 2.
    Test by installing key in ignition, there should be no beep.
    Reassemble the steering column plastic, screws; in reverse order of above. This is a good time to defunk the plastic and the rubber flange that covers the top of the column as mine was nasty.
    Done.
    Also, the seat belt chime and light disconnect worked for me, I unplugged the black with green stripe connector under the driver's seat. Pic #3 below. Yellow cased wiring is for the airbag.
    Thanks to OP and (some) other posters.
  3. Mar 24, 2015 at 1:44 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I have the 2013. Took a pic. Can you point out which one you pulled to deactivate the seatbelt chime? THanks man.
  4. Mar 24, 2015 at 3:20 PM
    Trojan8975
    Trojan8975 [OP] Member
    I have manual locks, windows and tranny so idk about fob. Thanks meefzah for further explaining. Heres pic of seat sensor
  5. Mar 24, 2015 at 4:14 PM
    Neutral
    Neutral Well-Known Member
    Guy
    Alabama
    14 DCSB SR5 4x4
    RCD 4.5", rims & tires (17s with 33s), Pelfreybilt Hybrid Bumper, Rigid lights, Superwinch Tigershark, Wet Okole's, 4.56 gears.
    interesting, Would unplugging the sensor under the seat disable anything else other than the seat belt alarm?
  6. Mar 25, 2015 at 4:43 AM
    TacomaMike37
    13' DCLB MGM
    Cool, thx. So I'll try the one I circled on the pic attached.
    Also... I wonder if this would work as well, granted its a tundra.
    https://www.youtube.com/watch?v=Bx7S-tX3twk
  7. Mar 25, 2015 at 4:56 AM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    On the drivers side it should be just the seat belt chime.
    On the passenger side it will make it so the passenger airbag stays off as it is tied in with a weight sensor. With the plug undone the weight sensor can't turn on the passenger airbag.
  8. Mar 25, 2015 at 5:02 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Beep and dash light
  9. Mar 25, 2015 at 1:12 PM
    Neutral
    Guy
    Alabama
    14 DCSB SR5 4x4
    Thanks guys, +1 to y'all!
  10. Mar 25, 2015 at 1:30 PM
    Neutral
    Guy
    Alabama
    14 DCSB SR5 4x4
    On my '14 it was the smallest plug in the middle under the seat. You should be able to see 2 wires going into the plug, black wire and a white wire with a black stripe on it :)
  11. Mar 26, 2015 at 5:57 AM
    TacomaMike37
    13' DCLB MGM
    This worked on my 2013. Nice not to have the nanny beep anymore.
    Its the plug I have circled in yellow on one of my previous posts.
  12. Jun 20, 2015 at 4:51 AM
    Vidal28
    Vidal28 New Member
    Charleston
    Prerunner
    Would this screw up your air tho?
  13. Jun 20, 2015 at 6:55 AM
    JADaus
    JADaus JD
    JD
    Minneapolis
    '13 Tacoma TRD Sport
    Here's what I've done: Bestop 76308-35 Black Diamond Supertop N-Fab T124LB Light Bar 2, Hella 700FF driving lights with 100w bulbs 2, Turbo SII CREE Pair 9 Inch 160w LED lights 17" Black Rock Series 997 Type 8 Matte Black Wheels 265/65-R17 Cooper Discoverer A/T3; (E class) Blue Sea Systems 5026 ST Blade Fuse Block Blue Sea Systems 285-Series Surface Mount 50A Circuit Breaker Vinyl decal by ruggedT: http://tinyurl.com/qg9bw7v Firestone W217602407 Ride-Rite Kit Daystar KU09140BK Air Bag Cradle Dog platform mod Fog lights anytime mod LED interior lights 886 Backup light mod Supreme Suspension Tacoma Lift Kit 2" Front Suspension Lift Carbon Fiber Seat Heater Kit Here's the Plan: El Cheapo Heated Mirrors mod Bilstein 24-239370 Shock Absorber (front)
    Not recommended with ice fishing
  14. Jun 22, 2015 at 5:32 AM
    TacomaMike37
    13' DCLB MGM
    Not that I know of. From my understanding if there were ANY issues with the airbag system the dummy light would come on like a christmas tree.
  15. Jun 22, 2015 at 5:47 AM
    #35
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    There's already a few threads about this...
  16. Jun 22, 2015 at 10:53 AM
    #36
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    It is the one closest to the center console. It is 2 wires - one black and one white.
