EASY tweeter upgrade! (3rd gen non-JBL)
Discussion in 'Audio & Video' started by IndyFastlane, Mar 1, 2017.
  1. Nov 1, 2017 at 8:15 AM
    #301
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    Reading mixed opinions here..
    Definitely will be doing the tweeter upgrade as it seems that's the biggest upgrade but I am also seeing people saying that upgrading stock front and rear speakers doesn't improve a lot(probably bottlenecked by the head unit) so should I just stick to the tweeter upgrade? an extra $150 for the crutchfield speakers doesn't seem like it's worth it if the difference is barely audible regardless of how flimsy the current paper speakers are.
    I have the entune premiun with nav head unit if it makes any difference.
  2. Nov 1, 2017 at 8:28 AM
    #302
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Do it. Pretty sure you'll have far more positive than negative reviews on my other thread:
    https://www.tacomaworld.com/threads...or-less-than-250.510424/page-51#post-16372848
    Capt Tacoma likes this.
  3. Nov 2, 2017 at 1:38 PM
    #303
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    Bro.....I know exactly what you mean !!!!!!
    Gonna be broke.....and deaf......but look good doing it, lol.
    bobrown14, bshammer0 and Moed[QUOTED] like this.
  4. Nov 2, 2017 at 1:40 PM
    #304
    DubfromGA
    Greg
    2017 Black SR5 4WD
    Excellent post.
    Just imagine.....if you got $5 from everyone that followed your lead......you'd have gas money, new tires and whatever else.
    Super thread. Thank you for the insight.
  5. Nov 2, 2017 at 1:52 PM
    #305
    DubfromGA
    Greg
    2017 Black SR5 4WD
    On occasion........I do.
    Day off work today. 70+ degrees and sunny outside.
    Windows down and enjoying the drive around time to run morning errands.
  6. Nov 3, 2017 at 5:13 AM
    #306
    drtyday44
    drtyday44 Member
    I believe I saw somewhere in this thread, asking if the Subaru tweeters are better than the JBL 3rd gen tweeters.
    I Attempted to install but the connectors are different.
  7. Nov 12, 2017 at 6:09 PM
    #307
    PoppinCorks
    PoppinCorks Well-Known Member
    must you remove the side panel bwfore the vent/tweeter cover?
  8. Nov 13, 2017 at 3:27 PM
    #308
    Toms 17
    Toms 17 Well-Known Mumbler
    Tom
    Central Ohio
    17 MGM DCSB TRD Sport
    New to the forum here and have ordered all the speakers and parts to do the swap soon. Has anyone installed the sound deadener directly over the existing plastic and felt insulation on the door? Thanks in advance guys for your help.
  9. Nov 14, 2017 at 6:59 AM
    #309
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    I did just that... see my post earlier in this thread. Worked fine. You could probably do better if you put it right on the bare metal, but I was looking for simple and did not need the sound performance to be perfect.
  10. Nov 14, 2017 at 7:35 PM
    #310
    TRDOBSESSED
    TRDOBSESSED Well-Known Member
    Blair
    Puyallup, Wa.
    2017 TRD ORAC
    OvTuned
    am i disconnecting both terminals or just the negative
  11. Nov 25, 2017 at 6:53 AM
    #311
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Tweeter mod for sure. Night and day difference. The clear highs are unbelievable.
    As for the door speakers, my local shop said he would recommend not upgrading the door speakers unless adding an amp because the difference would be negligible. In fact he said the best upgrade would be adding a small sub and amp.
    All in all, the stock system sounds great with the new tweeters.
  12. Nov 25, 2017 at 6:56 AM
    #312
    go2cnavy
    Yes. It’s really easy.
  13. Nov 27, 2017 at 2:41 PM
    #313
    Forge
    Forge Well-Known Member
    Rick
    Finally got around to doing the tweeter mod. Seems to be an improvement over the SR stock one. Easy quick mod. 15 min at most.
    Toms 17 likes this.
  14. Dec 19, 2017 at 9:26 AM
    #314
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Just finished installing the Tweeters and can’t believe the difference!! Thanks OP for schooling us on this awesome upgrade!
  15. Dec 19, 2017 at 11:29 AM
    #315
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    I would have to disagree with the local shop recommendation there. The stock Entunes Premium HU actually puts out decent and clean power which is why people are having success by just replacing the speakers. Will it be as noticeable of an upgrade like the tweeter swap is? No, but it's still very noticeable once you turn up the volume.
    Also, if you were to add an amp to the stock speakers, you will certainly hear distortion and they will bottom out quite easily...they are incredibly cheap and will not be able to handle much more than what the stock HU was able to put out. In fact, I wouldn't be surprised if you end up blowing a speaker after adding the amp...
    bobrown14 likes this.
  16. Dec 19, 2017 at 1:33 PM
    #316
    jsey21
    You can add an amp if you want, but definitely not necessary. Speakers alone are a vast improvement. If you want to keep going, have at it... it's all in how much time, money, and effort you want to put into it.
  17. Dec 21, 2017 at 4:30 AM
    #317
    quikrain
    quikrain Well-Known Member
    2017 Red Tacoma TRD SP DCLB
    I have a question, is the Subaru Kicker tweeters the stock speaker on a Subaru, or an upgraded speaker? Could I just go to a "u-pull" and yank 'em out?
  18. Dec 21, 2017 at 5:05 AM
    #318
    Big Dustin
    Big Dustin Well-Known Member
    Dustin
    Denver, Colorado
    '17 Tacoma DCSB SR 4x4
    5100's all around, OME 887 with 1/4" spacer, icon 3 leaf aal. 255/75/17 BFG KM's on 4runner pro's. Rigid led pods. Debadged and tinted.
    They are part of an upgrade package. I would say the majority of them don't have the upgrade.
  19. Dec 21, 2017 at 5:36 AM
    #319
    IndyFastlane
    IndyFastlane [OP] Well-Known Member
    Agreed.
    Back when I bought my WRX, the factory stereo/speaker choices were either standard or the Harmon Kardon system. The Kicker speakers were a dealer/consumer added option for the standard systems. Likelihood of finding those in a wrecked car is relatively low I would think.
    Big Dustin[QUOTED] likes this.
  20. Dec 26, 2017 at 9:32 PM
    #320
    Jrobb
    Jrobb Well-Known Member
    Jon
    SF Bay Area
    2017 Double Cab Lb SR5 Magnetic Grey Metallic
    Odd request here and I usually do my own research but I'm in a time crunch so need some help. I installed the OEM Audio system in my DCLB. Love it but Christmas Eve I got involved in a hit an run. Most likely totaled the truck with the front end damage. Other driver fled the scene while I was choking on airbag smoke...but he crash ripped their bumper off with plates attached.
    I'm fine, but I'm towing the truck to my house tomorrow and removing my shell and OEM Audio system. I may use it in the new vehicle...not sure what that is yet.
    I need Tweets, Front and Rear speakers to put back in as I didn't save the Originals. I don't have much time so I'd like some recommendations for easy install parts. I don't want to cut and solder ( I can do that but want to save the hassle). I just need pieces to put in so the stereo works for the adjuster when they check it out.
    J
