EASY tweeter upgrade! (3rd gen non-JBL)
Discussion in 'Audio & Video' started by IndyFastlane, Mar 1, 2017.
  1. Feb 17, 2018 at 8:04 PM
    #341
    IndyFastlane
    IndyFastlane [OP] Well-Known Member
    I believe the JBL system tweeters use an entirely different connector (a two pin vs a four pin).....so the Subaru kicker tweeters will not work on the JBL.
  2. Feb 21, 2018 at 11:26 AM
    #342
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    was thinking about getting these tweeters... but don't know if the filters will fit under the dash.
    Any pics of the dash when its open?
    I plan to get the harness from ********* and make the adapter myself to mount the tweeter.
    I believe that these tweeters are a bit better than the kickers because I've heard them before.
    Any advice? at the end of the day, excluding labor, the tweeters will end up costing the same amount.
    https://www.amazon.com/Alpine-SPR-1...qid=1519239826&sr=1-3&keywords=alpine+tweeter
  3. Feb 21, 2018 at 11:35 AM
    #343
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    They may be better, but the others are complete drop-in replacements. I'm not sure about fit under the dash covers since you'd have to come up w/ a mounting bracket, so there are more variables to what you are wanting to do.
  4. Feb 21, 2018 at 11:54 AM
    #344
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    yeah making the braket is not a big deal.
    My main concern is mounting the filters somewhere. Maybe along the pillar? is there any room there when you take off the pillar cover?
  5. Feb 23, 2018 at 10:08 AM
    #345
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    has anyone found out the part number for the tweeter plug/harness?
  6. Feb 23, 2018 at 11:13 AM
    #346
    jsey21
    Can't exactly remember, but you may have room under the speaker if it's not mounted too deep in the corner.
    James_Bond[QUOTED] likes this.
  7. Feb 23, 2018 at 1:33 PM
    #347
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    If that picture is correct (meaning the filters aren't much bigger than the tweeters), then you will have plenty of room in the dash for it. I just used "industrial" velcro for my filters (but I put mine in under the kickpanel trim since my filter is for a component set that also goes to the woofer inside the front door).
    It's a deep hole under the tweeters, so make sure you don't drop it...otherwise you'll have a helluvatime trying to get it back out!
  8. Feb 23, 2018 at 1:47 PM
    #348
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    awesome. I didn't know that there was empty space under the tweeter.
    Now the only thing I need is the harness for them. I don't want to splice the OEM cable. I just want to plug and play....
    FOUND IT!!!!!!!!!!!!!!!!!! $6.08
    https://www.ebay.com/itm/For-Toyota...ash=item1a3bdcc7a5:g:aEAAAOSwy~BaJj7O&vxp=mtr
    ToyoDrew[QUOTED] likes this.
  9. Feb 24, 2018 at 3:33 PM
    #349
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    Also found this great do it yourself video on YouTube. Besides the removal and installation it would help someone figure out how to reuse the factory harness.
    I’ll be holding on to the factory speakers for a while so I bought the harness on eBay already. Hope it helps someone in the same boat as me who doesn’t want to use the kicker plug and play and use a different brand or better model.
    https://youtu.be/MUqoq195Clw
  10. Feb 24, 2018 at 9:48 PM
    #350
    Deathray
    Deathray Are we there yet? ...Are we there yet?
    Jeff
    Central Illinois
    2021 Mazda3 AWD Hatchback
    Just ordered my Subaru tweeters! Thanks for the info, @IndyFastlane, and Tacomaworld for helping me spend that pesky disposable income (again).
  11. Mar 1, 2018 at 7:09 PM
    #351
    Deathray
    Jeff
    Central Illinois
    Got my tweeters today, installed them after work! Definitely improved the clarity from lower volume, all the way to cranked!
    Installation was pretty easy, just awkward, due to limited space right next to the windshield.
  12. Mar 3, 2018 at 9:23 AM
    #352
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Ordered full set of all 6 speakers.
    Went with the subbie tweets
    Front door - Kicker 44KSC6904 (2 way)
    back door - Kicker 43CSC674 (2 way)
    2 sets of Dynamat 10x10 sound deadening
    2 rollers for Dynamat install!
    Went with Crutchfield since less that A-zon and free door adapters and wires!
    Saw mention about tweets being wired out of phase.. anyone confirm that it's supposed to be wired that way? I'm an audiophile and build my own equipment
    (home stereo), I would never wire out of phase UNLESS I did something wrong wiring up my amp.
    Given the crappy speakers installed, doesn't seem to me that they (Toyota) would have spent a great deal of effort trying to "phase" crappy speakers..??
    IF they wired them out of phase - could be a reason they sound so bad... just a thought!
  13. Mar 3, 2018 at 12:27 PM
    #353
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    https://www.ebay.com/itm/For-Toyota-Car-Radio-Speaker-Wire-Harness-Plug-Aftermarket-Adapter-Cable-4-Pin/112673474469?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
    In case you want to wire your own tweeters like I am.
    Not really a fan of kicker but I do know they last a long time.
    I got the Alpine SPR-10TW. Will be installing when I get the wire from eBay.
  14. Mar 4, 2018 at 6:12 PM
    #354
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    Completed my installation today !
    Took my time - Bout an hour or so. Didn’t want to break anything. I did disconnect the negative to be safe.
    Sound - much improved.
    Bout 96 Dollars off of Amazon. Delivered in one day with Prime. Also purchased plastic removal trim kit which was delivered today.
    ToyoDrew and James_Bond like this.
  15. Mar 6, 2018 at 10:21 AM
    #355
    James_Bond
    Southern California
    '16 TRD Sport DCLB
    All stock
    I 3D printed my Alpine Speaker adapters.
    What is cool is that the alpines have a thread in the casing at the bottom.
    I'll document and create my own thread and link it.
    (the things I do because I'm an audiophile lol)
  16. Apr 7, 2018 at 5:18 AM
    #356
    el_burro
    el_burro Well-Known Member
    2018 TRD OR DCLB
    I've been searching and reading these threads and would like to get new speakers for my truck. I have the non-JBL Entune Premium head unit. I get that these Subaru Kicker tweeters are plug and play, and have read through this entire thread about several recommendations for the door speakers. Still, I'm unclear about the component speaker setup and how it would work if I wanted to install speakers with separate tweeters and woofers. I'm tempted to go with the Subaru tweeters and Kicker 3-ways for the front doors. However, I wanted to consider all the options if I'm going to the trouble of making this change.
    I am confused about the compatibility of component systems and how the wiring would work. Are there just 4 channels coming from the head unit, or do the door and dash speakers have dedicated lines from the head unit (6 channels)? Apologies if this has already been answered somewhere. I've installed many head units and speakers in the past, but when I did there were only 4 channels total and the components were new/not replacements of different components.
    I've been looking at a component setup like the recommended Focal IS 690TOY:
    https://www.crutchfield.com/p_091IS690TY/Focal-IS-690TOY.html?search=Focal_IS_690TOY&skipvs=T
    and this JL Audio component system:
    https://www.crutchfield.com/p_13699046/JL-Audio-C1-690.html?search=JL_Audio_6x9_component&skipvs=T
    Would these be "plug and play" with Crutchfield's included adapters if I purchased them? Or would I need to re-wire to make them work? For the rear doors I'll go with 2-ways so those aren't an issue. Thanks in advance for any help or suggestions here.
    genotekate likes this.
  17. Apr 7, 2018 at 12:24 PM
    #357
    ToyoDrew
    Texas
    There are only 4 channels coming from the non-JBL headunits. The tweeter and the front woofer are wired in series and the tweeter has a simple capacitor that acts as a basic HPF. If you take out the tweeter, the woofer will not work unless you add your own wiring (or splice them to bypass it). If you are not worried about cutting/splicing a couple wires, then I'd recommend getting proper components that come with a dedicated crossover. You just have the stock speaker wires go to the crossover and then run some new speaker wires to the new speakers in the OEM locations.
    TreeFortRichard likes this.
  18. Apr 11, 2018 at 8:11 AM
    #358
    econwatch
    econwatch Well-Known Member
    Utardia/Kanook Eh
    Naranja 7545
    The tweeter upgrade provides a much cleaner and punchier sound! Thanks for this thread, was well worth the cost.
    Used an extra bicycle plastic tire lever slightly filed down thinner to get the parts off. Also a well placed fingernail helps to get the lever started.
    Broke one of the tabs off the first speaker cover due to bad technique. Learned to twist the lever and move it around more often.
  19. Jun 6, 2018 at 10:58 PM
    #359
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    Installed mine tonight, purchased on eBay from a Subaru dealer with a coupon that got them down to $77 shipped. Took maybe a 1/2 hour to install including disconnecting the battery. Only listened to a few songs so far but these sound so much better than stock. Tomorrow I’m driving 200 miles so I’ll get a better feel.
    Surprised I haven’t seen mentioned how much heavier the stock speakers are than these. Maybe it’s all in the bracket?
    I should be installing a subwoofer next weekend too, but that’s a different thread.
  20. Jun 7, 2018 at 10:10 AM
    #360
    Skruf
    Skruf Well-Known Member
    Utah
    2017 QS TRD OR 4X4
    I just finished the job and it sounds soooo much better. Way crisper its awesome! The only pain I had was getting the bolts back into the passenger A pillar, that stunk. But its all back together now and would definitely recommend to do this for anyone. Also, I did not disconnect the battery.
