EASY tweeter upgrade! (3rd gen non-JBL)
Discussion in 'Audio & Video' started by IndyFastlane, Mar 1, 2017.
  1. Aug 29, 2019 at 6:45 AM
    #381
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Negative. The tweeters aren't plug and play for the 2nd gen.
  2. Oct 2, 2019 at 12:36 PM
    #382
    TacoWithBacon
    TacoWithBacon New Member
    Doug
    2017 TRD Sport Access Cab, 6-speed manual
    I am planning to upgrade my 2017 TRD Sport Access Cab speakers and learning about this website and thread has been a godsend having never attempted such a thing.
    I have a couple items I’d like to clarify. When I look at Crutchfield to see what replacements they offer for the dash speakers, all I see are 3” midrange speakers. Yet from this thread I understand that tweeters are being installed in that location. Is that correct or have I missed something?
    Also, if installing the tweeters does that imply the front door 6x9’s should not be 3-way’s? I think one of the Kickers quoted earlier in the thread were 3-way’s but that seems like it might be redundant if the Subaru tweeters are also in the mix.
    Thanks!
  3. May 6, 2020 at 3:46 PM
    #383
    P-Dawg
    P-Dawg Factory 2 Seater
    Pete
    Chicago
    2020 SR AC MGM Utility Pckg.
    Are these the only tweeter option for 3rd Gens? I noticed Crutchfield sells midrange speakers for the Dash, not tweeters.
  4. May 6, 2020 at 5:59 PM
    #384
    tgarza74
    tgarza74 Well-Known Member
    Mario
    2016 SSM TRD OR
    OvTuned
    These are the only plug and play straight out of the box option, you can hook up any tweeter or appropriate sized speaker just need to rig the wiring and mounting bracket.
  5. May 26, 2020 at 10:17 AM
    #385
    tall_paul
    tall_paul Well-Known Member
    Paul
    Denver, CO
    '16 DCSB OR M/T MGM
    Thanks for the write up. I had ordered some noico mat for my doors and rear wall. Figured I should upgrade the speakers at the same time. I ordered the Subaru tweeters off of Amazon with Kicker 43DSC69304 and Kicker 43DSC6704 from Crutchfield.
    After talking to the Crutchfield support, I went with the DSC speakers over the CS. They should have the same sound quality with a lower power requirement. I do not plan on installing an amp, so this seemed fine to me. I should add that the CS rears were out of stock. Here is what Jasan at Crutchfield had to say on it "The CS series you had your eyes on handle up to 100 RMS watts....which means for them to perform really well, you need an amp. But with the DSC series, they stop at 60, and we don't need as much power. So they will sound MUCH better because they are not being under powered." It seems like folks on here want to say the stock entune unit puts out a good deal of power, but I have no idea on anything quantitative in terms of a measurement. I think these should be fine, and took Crutchfield's advice.
    I will report back on the install and sound quality improvement. All in all, I'm in for about $330 including the 36 sqft noico mat, a roller to help install it, and all the speakers mentioned above. Doesn't seem too bad for the rave reviews on here.
    One more note, I wasn't able to find the sensitivity of the subaru tweeters. Anyone have any clue what it is?
  6. Jun 10, 2020 at 10:26 AM
    #386
    tall_paul
    Paul
    Denver, CO
    '16 DCSB OR M/T MGM
    Wanted to post a follow up after installing the speakers mentioned above and some noico 80mil mat. It noticeably reduced the amount of noise in the cab (still nowhere near silent) and the speakers have MASSIVELY improved the sound clarity. I can hear notes and sounds that were just muffled in all the distortion of the factory speakers. Money well spent if you are on the fence. Not much (if any) louder but very distinct improvements in sound quality.
  7. Sep 13, 2020 at 3:07 PM
    #387
    Albertaktm
    Albertaktm Active Member
    Alberta Beach
    2020 TRD Sport
    So what is a good 6x9 speaker for the door if you are going to do the Subaru/Kicker drop in tweeter? Every post I’ve seen, guys are using 3 way 6x9 front speakers. Even the famed Post 112 he is using 3 way kickers with tweeters in the 6x9. I would have to think you don’t want any tweeter in the front door. If you have the Subaru tweeter in the dash.
  8. Dec 17, 2020 at 1:45 PM
    #388
    LazloCO
    LazloCO Well-Known Member
    Brian
    Morrison, CO
    2019 Cav Blue TRD OR DCSB
    Rock Lights, Sliders, Softopper, Fox 2.0 shocks F/R, AAL
    Ok So.... I am a bit confused. I have read all the posts... so I spent a long time here on this. haaa. But, this Subaru tweeter. I have been hearing about this thing for a year now. I have been doing other mods though. I never seem to see any model number or anything regarding this tweeter. And, it seems there is a similar kicker tweeter or the Subaru tweeter is made by kicker... or...?
    See.. confused ! Anyone willing to help me out?
    And, also someone chimed in on this thread or maybe more than 1 person, asking about this whole thing with regards to the JBL/subwoofer setup for those of us who have that setup right now. I never saw an answer or acknowledgement to any of those questions. Nobody has any info on that setup or how these recommendations work for the JBL setup? Or, they got lost in the shuffle?
    THANKS!!
  9. Dec 17, 2020 at 5:23 PM
    #389
    Unresolved Taco Issues
    Unresolved Taco Issues Well-Known Member
    Jeff
    FINALLY off the island!
    2020 Gray Tacoma Access Cab
    I was wondering like you, but I discovered once I scrolled to the bottom of the page there's a 'Products Discussed in Thread:EASY tweeter...' link to Amazon(at least for me anyways). If it's not there for you here you go:
    https://www.amazon.com/dp/B00PV6F8I2
    I'll probably start with just the tweeters myself. It was embarrassing when I was showing-off my NEW truck to a buddy and he made a o_O face when we turned up the radio. Otherwise, he was impressed. Easy fix!:thumbsup:
    nDub likes this.
  10. Dec 18, 2020 at 5:29 AM
    #390
    LazloCO
    Brian
    Morrison, CO
    Ahhhh. Damn, I have NEVER even paid attention to that. I habitually ignore ads so it does not even come into my field of vision! ha
    Thanks man
  11. Jun 6, 2021 at 2:03 PM
    #391
    2001Tacoma
    2001Tacoma Well-Known Member
    2019 SR I4
    I have a 2019 SR with the dash tweeters. I plan on replacing the tweeters and speakers. With there being a dash tweeter should I stick with the coaxial speakers ? Thinking that a three-way with the tweeter in the dash may be too much high range. Any help/thoughts ? thank you.
  12. Oct 28, 2023 at 11:57 AM
    #392
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    THIS is the info I was looking for...glad to hear the stock entune doesn't have an integrated HPF...
