EASY tweeter upgrade! (3rd gen non-JBL)
Discussion in 'Audio & Video' started by IndyFastlane, Mar 1, 2017.
  1. Jul 24, 2017 at 7:38 PM
    #121
    jsey21
    jsey21 Well-Known Member
    2016 Black Tacoma Sport DCSB V6 4x2
    OVTuned https://www.tacomaworld.com/threads/rear-diff-vent-behind-the-tail-light-mod.286097/ https://www.tacomaworld.com/threads/rust-on-frame-with-a-c-drain-mod-fix.444138/ https://www.tacomaworld.com/threads/ultimate-led-turn-signals.486423/ https://www.tacomaworld.com/threads/premium-audio-upgrade-for-less-than-250.510424/
    That's what I was hoping to hear. I am putting in some high efficiency JBLs in the doors and think these will be a great fit along w/ those.
    I appreciate the feedback!
  2. Jul 24, 2017 at 7:48 PM
    #122
    jsey21
    I went a step down from the ones you got (GT7-96 & GT7-6)... didn't think that the base unit had that much power anyway, the sensitivity was equal to what you had, and was a bit less expensive. I am going to add a ton of sound padding around the doors to help seal out some road noise, so I'm hoping that adds to the improvement.
  3. Jul 24, 2017 at 8:13 PM
    #123
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    Keep us posted on how this works out! I have been thinking about getting those speakers myself
  4. Jul 25, 2017 at 2:21 PM
    #124
    THATCH11B
    THATCH11B Well-Known Member
    Limerick Pennsylvania
    2017 Tacoma TRD Pro - SOLD
    Mobtown sliders, bed extender, Extang Encore tonneau cover, Husky x-act fit mats, 3M FX Premium 25 tint, Bedrug mat, 255/85r16 ST MAXX’s, Rok Blokz, Rigid Industries 30 inch bumper mount and ditch lights, Subaru tweeter upgrade, MESO LED turn signal upgrade, TRD CAI, MESO LED map/dome, VLED’s exterior LED’s, Weathertech window vents, Redline struts, engine bay LED’s, seat spacer mod, 3x remote start, Mobtown CMC, Mobtown locking storage doors, Prinsu Cabrac, SPC UCA’s, ADS 2.5 remote reservoirs w/adjusters front /rear, 700 # springs, OME Dakar HD leafs, extended brake lines, u bolt flip, bump stops front(Plastic guy’s)/rear(Timbren), ECGS bushing, sway bar delete. Yotaled’s raptor light kit, Method Racing MR701’s, Rondo radio knobs
    So glad I did this! Worth the $88 I paid and install was soooo easy!
    IndyFastlane[OP] likes this.
  5. Aug 2, 2017 at 3:33 PM
    #125
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    Just purchased the tweeters. Thanks OP for sharing this with us all. I haven't installed them yet and had a quick question. The video posted by ********* (https://youtu.be/YXRE7fuk36o) mentions removing the A-pillar panel before removing the tweeter cover. Is this necessary? For those of you who have performed this install, did you remove anything other than the tweeter cover?
    genotekate likes this.
  6. Aug 2, 2017 at 3:44 PM
    #126
    IndyFastlane
    IndyFastlane [OP] Well-Known Member
    Glad you got use from my tip!!
    Yes, you have to remove both a-pillar covers because the tweeter cover goes under the a-pillar cover. The tweeter cover pops off in an upward direction....so the a-pillar cover is in the way. A-pillar covers are super easy to take off, though. It's two 10mm (if I recall correctly) bolts on each side. The only issue I had was when popping the little covers off of the grab handle, one of the little plastic stays that keep the cover from coming completely off broke.....which is not a problem. Just be careful and use a plastic trim tool if possible or something that won't scratch plastic.
    Good luck and enjoy the new tweeters!
  7. Aug 2, 2017 at 4:52 PM
    #127
    poopshute
    Colorado
    Thanks! In the video I posted above, they mention removing the battery as to not accidentally trigger the air bag. Did you end up disconnecting the battery? I'll probably do it just to be safe but I was wondering what others have done. It would be nice to not have things reset.
  8. Aug 2, 2017 at 5:01 PM
    #128
    THATCH11B
    I did not disconnect the battery but not saying it is the correct way. I had no problems. Loving the speakers by the way!
    shakerhood and poopshute like this.
  9. Aug 2, 2017 at 5:12 PM
    #129
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
  10. Aug 3, 2017 at 6:23 AM
    #130
    IndyFastlane
    I also did not disconnect the battery.
  11. Aug 3, 2017 at 4:49 PM
    #131
    Railrider
    Railrider Member
    2017 dlbcb trdor
    I chose to disconnect, cheaper than being wrong. Great upgrade for minimal work I might add
    poopshute likes this.
  12. Aug 3, 2017 at 4:51 PM
    #132
    mrproduxn
    steve
    Retired DoD SE VA
    I have never disconnected a battery for speaker installation in the past 42+ years. Head units absolutely disconnect.
  13. Aug 4, 2017 at 10:10 AM
    #133
    JaggedJimmyJ
    JaggedJimmyJ Member
    So if i put this tweeter in and then some aftermarket 2 way 6x9's in the front... wouldn't it make sense to cut out the tweeters on the 6x9's? from what i see the both share the same channel (door and dash). Every watt counts when your using the stock head unit, and the tweeter on the 6x9's are not going to be doing a whole lot really.
    What do you guys think?
  14. Aug 4, 2017 at 10:17 AM
    #134
    jsey21
    That's a good question... not sure if the added tweeters help. I'm doing the same thing, so I'm wondering what folks think as well.
  15. Aug 4, 2017 at 10:41 AM
    #135
    poopshute
    Colorado
    I'm assuming you're talking about a 2-way aftermarket speaker? If so, I think you might run into some problems as I believe those 2-way speakers that have the extra tweeter have a built-in crossover. I would just find a mid-range speaker that doesn't have the tweeter mounted separately.
  16. Aug 4, 2017 at 11:12 AM
    #136
    JaggedJimmyJ
    JaggedJimmyJ Member
    Ive looked and there are no low rms 6x9 speakers that are not coaxial that would work with the stock head unit... or none that ive found. I plan on getting the Rockford Fosgate Prime R169x2.
    The only low powered 6x9 that is component would be the new jl audio c1-690, and cost quite a bit to just toss out the tweeter and crossover and use the kicker tweeter. You be better off getting an adapter plate for the jl tweeter and running wires and all that mess for the crossover they make for it. Which is exactly what i dont want to do... i just want a nice easy clean install with no messing of the wiring.
    Im pretty sure on the 2 way 6x9 it is pretty easy to snip the wires for the tweeter and then just the woofer works.
  17. Aug 4, 2017 at 11:21 AM
    #137
    IndyFastlane
    My suggestion is to just replace the tweeters in the dash only and see if you want to go further. I know the door speakers are cheap, but they put out a surprising amount of bass and ive never experienced any distortion. The tweeters transform the sound of the stereo so much you may decide its not worth going any further.
  18. Aug 4, 2017 at 12:31 PM
    #138
    jsey21
    I've already got all the speakers and I wanted to add some sound deadening material to the door to help reduce road noise, so I'm going to roll w/ what I started with. I figure it can't be any worse and if what you say is true about the tweeters, I should have a huge upgrade between the tweets, door speakers, and road noise reduction.
  19. Aug 4, 2017 at 1:09 PM
    #139
    JaggedJimmyJ
    JaggedJimmyJ Member
    Ya thats probably a good idea IndyFastlane. I will save the money and add a subwoofer system. I already have JL audio amp jx500/1d from previous vehicle, just need to get Audiocontrol LC2iB as the Line out converter. Now for discrete sub and box (preferably 12' and ported)... saw a setup at ********* with Image dynamics sub, but to ship into canada is pretty crazy. Ill wait till more offerings come around.
  20. Aug 4, 2017 at 4:11 PM
    #140
    mrproduxn
    steve
    Retired DoD SE VA
    I have 2 way Kickers in the front and rear doors with these tweeters. Sounds amazing as is.
