Easy way to stiffen suspension on my 2017 TRD Sport?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brettcp, Aug 28, 2017.
  1. Aug 29, 2017 at 9:06 AM
    JazzTaco
    JazzTaco Member
    I'd try different tire pressure settings. Also try adding some weight in the bed and see what that does for the ride quality.
  2. Aug 29, 2017 at 12:56 PM
    brettcp
    brettcp [OP] Active Member
    Brett
    2017 Tacoma TRD Sport
    I ordered the 5100's, thanks for all of the advice. If I were to set the front adjustables to the .85" lift setting, would adding the SuperSprings in the rear be advisable (as I've read they lift the rear up about .5") ?
    Thanks!
    shakerhood likes this.
  3. Aug 29, 2017 at 2:16 PM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    Stiffness and strength are two different things. A Unibody car has significantly more stiffness vs weight. Take a look at a semi tractor when pulling away from a stop light. One front corner of the chassis will rise a few inches. The entire frame twists due to driveshaft torque reaction. The entire chassis is a spring with no damping. A frame style chassis will "wind-up" similarly when one corner hits a bump and the suspension loads the frame.
    Here is a propaganda video made by Ford. It shows how the frame stiffness affects handling and performance. It also shows the lack of Toyota expertise in truck frame engineering....
    Woofer2609 likes this.
  4. Aug 29, 2017 at 2:44 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Ive seen that video and i just dont see it translating to real world anything. Heres a test: put your fingers inbetween the window glass and seal of your truck and swerve. As you feel the gap open and squeeze on your fingers, this is cab flex. Do the same in any sedan. Bet the sedan is worse for 2 reasons. A. It doesnt have a frame so the chassis is the only point it can flex. Truck has cab and bed mounts between frame and cab/bed.
    B. Its payload isnt designed to carry as large a variation in weight
    Not saying i dont agree but i dont. Not in real world. Op's issue does not lie in the fact his truck has a frame thats acting like a spring over bumps. It has to do with the pathetic excuse for dampeners toyota installed in his truck.
    I did parts for years and i dont think ive ever come across a shittier feeling shock that was not legitimately broken. Those blue hitachi are pure junk, others maybe slightly better but still mediocre at best compared to even a 5100. I encourage everyone to grab a couple wrenches and take a rear shock out. Its super easy. Just compress it with your hands and come back here to research good rear shock options. (I like 5160 until i go extra flexy spring)
  5. Aug 29, 2017 at 3:15 PM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    If your truck is bouncing.. then what is your tire pressure??
  6. Sep 1, 2017 at 7:24 PM
    brettcp
    Brett
    Picked up the Bilstein 5100's yesterday and installed them today. Used the method to install without using a spring compressor (which I found on this forum) which super easy - felt much safer than using a spring compressor. First one took me an hour, second one took me about 15 minutes (you all know how that goes). I did have to remove the front skid panel for access to loosen the bolts for the front control arms so it would swing down far enough to remove the shock/spring assembly. I tried to maintain the factory alignment as best as I could but I can tell it needs a proper alignment just after a few minutes of test driving post-install.
    I set it to the lowest lift setting in the front which was .65". Will see if its noticeable after they settle in.
    Thanks for all of the help and suggestions! Much appreciated.
  7. Sep 1, 2017 at 7:59 PM
    Austin09
    Austin09 Well-Known Member
    Austin tx
    2016 Barcelona Red TRD access can LB
    T-Rex grill with black bezel. Blacked out all the badges and added the Tacoma on the tail gate. The windows have been tinted to the darkest law will allow.
    I've been thinking of doing the same thing, op let me know how it turns out. Thanks
  8. Sep 2, 2017 at 2:15 PM
    brettcp
    Brett
    So far so good, I took it in to get aligned today and the truck rides great.. definitely less "roll" which is what I was aiming for.. but I know they need to settle in for a bit. I set the front shocks to a .65" lift (and the rear is still at stock level) but I can't really tell by looking at the truck that the front is sitting any higher.. Visually it looks level.
    shakerhood and Oldman808 like this.
  9. Sep 12, 2017 at 4:20 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Sorry it took me so long to see this we were closed last week and I am just now getting around to alerts. Thank you for the recommendation. :thumbsup:
  10. Sep 12, 2017 at 4:22 PM
    tcjacado
    tcjacado Well-Known Member
    As always you are completely welcome. Please check out the "Roads Less traveled thead" a great team could use the support. @Redeyejedi
  11. Sep 12, 2017 at 5:55 PM
    HeadStrong Off-Road
    I sure will :cheers:
    tcjacado[QUOTED] likes this.
  12. Jul 16, 2018 at 7:23 PM
    Nunya Bizness
    Stiffen? Jesus man... I am tryn to soften up my 18 sport. its way to stiff for my liking, sooo much more stiff than my 08 sport was(supposedly the same shocks but huge difference to me). Damn near undriveable. I bought it to be my new daily driver and have since parked it and went back to my old optima until I get a fully adjustable chambered kit ordered and put on. Gonna toss the stock setup.
  13. Jul 16, 2018 at 9:09 PM
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    5100s ftw
  14. Jul 16, 2018 at 10:19 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I just put 5100s on my truck. They are great.
    Oldman808 likes this.
  15. Jul 16, 2018 at 10:27 PM
    #35
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Airbag suspension will certainly stiffen your suspension as needed. Easy enough to regulate just add or take away air...better shocks for better damping for sure.
  16. Jul 17, 2018 at 7:05 PM
    #36
    Nunya Bizness
    The easiest way to stiffen up (also the cheapest option and can be done fairly quickly) is just weld up the suspension... go to a fab shop and ask for a few quick welds on the part of the shock thats shinny directly to the housing... pretty straightforward Id say... however you will likely go through several Tacomas due to damage to everything.... everything...
    Actually if you have a friend with a Tacoma try it on his first... just incase you have second thoughts....
    kgilly likes this.
  17. Jul 17, 2018 at 8:06 PM
    #37
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Might as well weld up the diff while you're at it!
    Nunya Bizness[QUOTED] likes this.
  18. Jul 19, 2018 at 6:51 AM
    #38
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    I added SS to my truck and they don't actually touch the frame. The tops are about 1/2-3/4" below the frame. They just touch when I am hauling and it does not impact anything with the ride.
  19. Jul 19, 2018 at 9:50 AM
    #39
    Velequez
    Velequez Well-Known Member
    Austin
    2020 TRD Sport DCLB - Quicksand
    Which SS's do you have? I am looking for the same setup you mentioned but have read many places on TW that the SS's they installed touched at all times and actually increase the rear ride height. I am good with how my TRD Sport rides empty but want some better support with a load.
  20. Jul 19, 2018 at 10:30 AM
    #40
    Baerskin
    Baerskin Rocking in the Free World
    Manitoba
    TRD Sport Premium 4x4
    Stock
    You find the Sport ride is "bouncy" hmm interesting
