Easy way to tell if cam bolts are seized?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by harris.greg62, Apr 4, 2018.
  1. Feb 11, 2019 at 1:17 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    start spraying them with 50/50 aceone/atf, or Aerokroil every other day.
    You won't know if the front LCA cam sleeves are seized until during installation. The LCA won't swing downward. It will spring back up and fight with swinging downwards if its stuck.
    Weissenheimer and TacoYankee like this.
  2. Feb 11, 2019 at 4:05 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Get under there and try to move'em. They move, you're good, they don't budge, you're cutting. Either way the lca's will come out.
    TacoYankee and abqnurse80 like this.
  3. Feb 11, 2019 at 4:40 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Maybe a dumb question: When you replace the LCA and the cams, what’s the trick to get the new cams close to where the old ones were so I can get to the alignment shop without too much trouble?
  4. Feb 11, 2019 at 4:42 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    What would you want for the cams? I’ve got an ‘04.
  5. Feb 11, 2019 at 4:49 PM
    mbrogz3000
    Northern NJ
    Use a grease pen and carefully make 2-3 witness line markings across the cam to mounting gussets. As long as those witness lines all are returned to where they were, you’ll maintain the majority of existing camber and caster.
  6. Feb 11, 2019 at 4:58 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    But I’d be replacing the cams as well. I guess I can make a witness mark on the new cam in the same place as the old one, so long as they’re the same, it should be close enough to get there.
    abqnurse80 likes this.
  7. Feb 11, 2019 at 5:05 PM
    08TacoTrD
    08 TRD Offroad
    That's what I did. I also took a pic of the witness marks before I started so I had a better idea of where I needed to be.
    TacoYankee[QUOTED] likes this.
  8. Feb 11, 2019 at 5:07 PM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Pm'ed
  9. Feb 11, 2019 at 5:09 PM
    abqnurse80
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Yeah, it'll be close enough to get you to an alignment shop!
  10. Feb 11, 2019 at 5:23 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Each alignment cam has a pointer, mark the pointer to the frame with a paint pen.
