ebay find: hood struts 2005+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meeestirg, Jan 15, 2011.
  1. Jan 15, 2011 at 10:45 AM
    meeestirg
    meeestirg [OP] Well-Known Member
    Vance County, NC
    QuickLIFT:
    http://www.ebay.com/itm/2005-2014-T...Strut-Shock-Damper-Springs-Prop-/310756109052
    QuickLIFT PLUS:
    http://www.ebay.com/itm/2005-2014-T...-Shock-Damper-Spring-Prop-Truck-/281175022495
    QuickLIFT ELITE:
    http://www.ebay.com/itm/2005-2014-T...-Shock-Damper-Spring-Prop-Truck-/310756115985
    Color Install Instructions PDF: http://www.redlinetuning.com/manuals/QL-TOYOTA-TACOMA_05+102.pdf
    not my product but i've had these on my previous car and they were bad ass. there is a 2 and 4 year warranty on these. the only thing holding me back from these going onto my tacoma is that for the tacoma it's not bolt on as it was for my honda. just thought some of you might be interested.
  2. Jan 15, 2011 at 12:22 PM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    What is the difference between the three kits? If there are others on the forum that have these, how are they performing? Thanks.
  3. Jan 15, 2011 at 12:41 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    [FONT=Verdana,Arial,Helvetica,sans-serif]Posted on a group buy about a year ago. Mine are still sitting on the bench....:confused:[/FONT]
    [FONT=Verdana,Arial,Helvetica,sans-serif][/FONT]
    [FONT=Verdana,Arial,Helvetica,sans-serif]BLACK IS PLUS [/FONT]
    [FONT=Verdana,Arial,Helvetica,sans-serif]RED IS ELITEQuickLIFT[/FONT][FONT=Verdana,Arial,Helvetica,sans-serif] QuickLIFT ELITE[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]ROD[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Gas-spring uses a stron[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]g annealed steel rod with a Nitride coating for added corrosion resistance (black in color).[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Cycle Tested by independent lab over 73,000 times - gas-springs deviated less than 1% of initial rated force.[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]The ultimate 316L stainless steel rod and tube, precision ground and highly polished (silver in color).[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Uses proprietary Hard Chrome plating with Passivation option for superior corrosion protection [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]TUBE[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]E-Coat black painted steel tube[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]E-Coat paint gives up to 480 hr. salt spray [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Heavy wall thickness for better dent resistance and low stress [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Full Stainless Steel construction. All stainless steel parts also have prepared surfaces to give additional hardness and corrosion resistance. [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Heavier wall thickness for better dent resistance and low stress [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]PISTON PACK[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Labyrinth design, uses carefully engineered oil passages. [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Uses threaded nut design and 100% tested [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Not temperature or viscosity sensitive. Consistent damping through the oil and Nitrogen gas. [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Self-cleaning orifice reduces clogging & prevents lockup [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Short Orifice [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Orbitally riveted & 100% tested [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]SEAL/ BUSHING PACKAGE[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Dynamic Seal [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Excellent at high pressures [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Accepts misalignment [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Tolerates some contaminates [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Stands up to vibration [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Withstands side-loading [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Multi-lobe Dynamic Seal [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Teflon washer acts as wiper [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Lubricated tapered bronze bushing prevents cocking and lockup [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Excellent at high pressure [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]GAS SPRING ASSEMBLY[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Gas springs cycle reliably at temperatures ranging from -40°F to 180°F[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Excellent at low temperatures [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Withstands 410F paint oven [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Low parts count (less error) [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Prevents cocking & sticking [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Patented assembly process [/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]All Metal Construction [/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]MOUNTING BRACKETS[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Zinc-plated Steel brackets with ball-stud end fittings for gas-spring attachment[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Black powder-coated brackets made from Zinc-plated Steel[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Each bracket has a ball-stud fitting for gas-spring attachment[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]MOUNTING HARDWARE[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]Steel rivets and hardened steel self-tapping screws (components vary based on Quick-Lift design)[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif]Warranty[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]2 years, all parts included.[/FONT]
    • [FONT=Verdana, Arial, Helvetica, sans-serif]4 years, all parts included.[/FONT]
    [FONT=Tahoma, sans-serif]Whether you choose the QuickLIFT, QuickLIFT PLUS or QuickLIFT ELITE, all of Hood QuickLIFT systems install and operate the same - you are paying for component upgrades in quality and finish as you work your way from the QuickLIFT to the QuickLIFT ELITE. Installation could not be easier with our full-color installation manuals - customers always comment on the simplicity and excellent function once installed - we engineer our systems specific to each vehicle. Whether or not your system comes with our black e-coated gas springs (QuickLIFT and QuickLIFT PLUS) or our full 316L Stainless steel (QuickLIFT ELITE) we include progressive spring valving to allow the final few inches of travel to be slow and controlled. Just start to lift your hood and let our hood QuickLIFT system finish the job.[/FONT]
    [FONT=Tahoma, sans-serif]Our base QuickLIFT system includes:[/FONT]
    [FONT=Tahoma, sans-serif]* Black e-coated gas springs, custom valved for slow release at end-of-stroke[/FONT]
    [FONT=Tahoma, sans-serif]* Zinc-plated mounting hardware (silver in color)[/FONT]
    [FONT=Tahoma, sans-serif]* Full-color installation manual[/FONT]
    [FONT=Tahoma, sans-serif]* 2 year warranty[/FONT]
    [FONT=Tahoma, sans-serif]Our QuickLIFT PLUS system includes (all-black system):[/FONT]
    [FONT=Tahoma, sans-serif]* Black powder-coated zinc-plated mounting hardware (black in color)[/FONT]
    [FONT=Tahoma, sans-serif]Our QuickLIFT ELITE system includes:[/FONT]
    [FONT=Tahoma, sans-serif]* 316L Stainless steel gas springs, custom valved for slow release at end-of-stroke[/FONT]
    [FONT=Tahoma, sans-serif]* 4 year warranty[/FONT]
    [FONT=Tahoma, sans-serif]Redline Tuning does NOT believe in universal hood lift systems - each of our systems is designed to be installed on the intended vehicle... we allow for variations in hood type and aftermarket hoods ARE designed to work with our QuickLIFT system. All of the required components are included in the package whether you have a stock or after-market hood.[/FONT] __________________
  4. Jan 15, 2011 at 3:01 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    I've seen these mentioned around the forums already before. It's definitely going into my Want category, for when I get some extra cash.
    On another note, I've seen the tailgate assist has a negative review on here, simply because it's a VERY tight fit for our tailgates.
  5. Jan 15, 2011 at 3:16 PM
    pinktaco808
    pinktaco808 Hot Steppa
    chee heee
  6. Jan 15, 2011 at 3:18 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    I have the elite(stainless steel) hood struts, they're sick
  7. Jan 15, 2011 at 3:21 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    x2 :thumbsup:
  8. Jan 15, 2011 at 6:04 PM
    meeestirg
    Vance County, NC
    thanks bb609 for explaining everything cause i wouldn't know. lol
  9. Jan 15, 2011 at 7:30 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    Thank you for your contribution.
  10. Jan 15, 2011 at 7:48 PM
    ycart1201
    ycart1201 Well-Known Member
    Nathan
    Oregon
    2016 DC TRD Sport 4x4 - My build is underway
    Current Project: 2016 DC TRD Sport 4x4
    my 08 4runner came from the factory with hood lifts... strange the taco doesnt.
    Nathan
    ycart1201
  11. Jan 16, 2011 at 2:16 AM
    meeestirg
    Vance County, NC
    think they'll fit the taco? are they bolt on or riveted? :)
  12. Jan 16, 2011 at 4:52 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    Yup, they'll fit.
    http://www.redlinetuning.com/QL-TOY-TACOMA-95+.html
    I like the idea of the EZDown tailgate assist, but as I stated above, it's had negative reviews on here because it's a really tight fit for us.
  13. Jan 16, 2011 at 6:47 PM
    Vandy
    Vandy Well-Known Member
    Jake
    Pasadena, MD
    2008 DC-LB, 4x4 SR5, Indigo Ink
    Redline Hood Struts, Blacked out Badges, Blacked out SR5 Wheels, BFG All-Terrains, aFe Pro Dry Air Filter, Wicked Flow Muffler
    Just so you know - i bought mine a month ago directly from redline a month ago. You can get them cheaper through redline tuning: http://www.redlinetuning.com/products_quicklift.html
    Install was easy and they are awesome. Wish I had got them a couple years ago. I'll be installing these on any vehicle I own from now on that comes with a prop rod.
  14. Jan 16, 2011 at 9:54 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    One blows out in the box before you put it on... the others blow out in 6 months.. then a year for the "elite".
  15. Jan 16, 2011 at 10:04 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    I take it you've had a negative experience with these?
    Mind sharing details?
  16. Jan 17, 2011 at 12:20 AM
    island808
    Jedediah
    hawaii
    Not those in particular.. but both junk from ebay and typical extenders.
    Stuff sold on ebay either only or as an add on to crappy drop ship sites is on there for a reason. It sucks. It wouldnt stand up to scrutiny in a store and isn't worth retail space. Parts like that are frequently aiming at low end car customizers. Probably the 2nd best target for crap sales next to shut-ins. Usually under educated, young, and poor. WHich sucks if your hobby crosses paths with theirs.. or you happen to be them.
    As for extenders other than A FEW factory installed air oil extender dealies like that... they are usually crap. My tool box is full of oil from them, half the used cars that come with them on the hood or lift gate are done in a couple years.. an that's oem quality.
    Compressed under the hood with hundreds of degrees of engine heat will destroy them in short order. Thres a reason they're not on cars often. Do they do them on anything anymore? They were popular for a bit in the 90s.
    I could be wrong.
  17. Jan 17, 2011 at 8:03 AM
    meeestirg
    Vance County, NC
    if you read the post that i quoted, i was asking if the toyota OEM gas hood dampers for the 4-runner would fit and work on the tacoma. and if they were bolted on or riveted.
    hahaha i don't like making aftermarket holes into my vehicles.
  18. Jan 26, 2014 at 8:28 PM
    dhthompson1
    dhthompson1 New Member
    01 TRD SR5
    I know this is an old thread, but I haven't seen recent conversation regarding redline tuning's hood struts. Are there currently any group buys or promotions going on?
    Thanks!
    Dan
  19. Jan 27, 2014 at 5:51 PM
    ImpulseRed008
    Susan
    SC
  20. Jan 27, 2014 at 6:52 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Got the basic one directly from redlinetuning. Still holding up for about a year or so now. Highly recommend it.
    As for the DeeZee easy tailgate assist, I got one that I installed about a week ago. Pretty much agree with all the negative reviews. I ended up removing the cable support on the driver side and just kept the strut in place. I think the one flaw is that the strut is to thick. If they had it with a thinner strut, then it'll work.
