ebay find: hood struts 2005+
Discussion in '2nd Gen. Tacomas (2005-2015)' started by meeestirg, Jan 15, 2011.
  1. Jan 27, 2014 at 7:56 PM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    This is one of my favorite mods on the truck. I really hate prop rods and the RedLines are a good product. They were an easy install, just measure carefully, twice.
  2. Jan 27, 2014 at 8:24 PM
    chickdr
    chickdr Well-Known Member
    Atlanta, GA
    Tacoma 2.7l
    Yes you could. Most premium cars use struts to hold the hood up. My 06 Z4 has them and they still work perfectly after 8yrs. My 07 Q7 also had them with no issues in 7yrs. The only reason the Taco doesn't have them is cost. Other Toyota's and Lexus's have them... i would expect the Elite version of these to hold up for many years.
  3. Apr 11, 2014 at 5:09 AM
    crusader1
    crusader1 Well-Known Member
    Al
    SC Upstate
    06 PreRunner TRD#1/'73 Datsun 240Z Orig. Ownr
    None yet...just warmin' up
    It is a tight fit, I agree. I press the stock cable to the LEFT side of the strut cylinder each time I close the gate, or else it doesn't like to close. The tight fit comes from interference with the swaged end of the factory cable. If it were straightened out, it would clear better...however, that would lengthen the cable and make it longer than the Right side one. Solution? Probably remove the factory cable as an earlier writer did.
  4. Nov 4, 2014 at 7:06 PM
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
  5. Nov 5, 2014 at 4:15 AM
    crusader1
    Al
    SC Upstate
    I noticed the tight fit when installed with the stock tailgate stay, so removed the stay and it's much better. No reason for my truck to have both, as it doesn't get a ton of heavy weight on the tailgate. Still a tad of interference at one point between the strut and plastic tailgate liner, that a Dremel will solve when I get around to it...just a small relief should do it.
    I really love it, and plan to install the Plus hood struts when there's time in my day...lying there in box for over six months! My '73 Z-car has interjected itself and sucked all the air from my shop :)
  6. Nov 5, 2014 at 4:57 AM
    Poofyfoot
    Poofyfoot Well-Known Member
    Jordan
    Logan, Ohio
    89' Pickup and 2013 AC Sport
    I ended up with the PLUS model and I love these things, you won't regret getting them. If you're like me you will probably want to rivet both the top and bottom mounts on. I really don't like the idea of using self-tappers on my truck.
  7. Nov 6, 2014 at 5:30 AM
    crusader1
    Al
    SC Upstate
    Poofyfoot, Thanks for the great idea on rivets...I'm a sheet-metal fastener hater, also. Can't wait to get those hood struts installed. Every time I raise the bonnet, I think about not dropping it on myself before getting the rod up and locked...then, it's in the way!
    Don't know what kind of pipes you have, but I LOVE my AERO Exhaust Catback...SOUNDS!
