Ebay headlights? Crap or $75 ehhh...?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1 Limited Toyota, May 13, 2023.
  1. May 13, 2023 at 7:37 AM
    1 Limited Toyota
    1 Limited Toyota [OP] ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    No need for halos or leds. Just need new lenses.
    Personal experiences?
  2. May 13, 2023 at 7:43 AM
    Sasquatchian
    Sasquatchian Well-Known Member
    I think you already know the answer but are looking for someone to tell you they are going to be great to help you justify not spending the money on genuine OEM replacement units, which, of course, is the only thing you should be considering.
  3. May 13, 2023 at 7:54 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    You can find many after market head lights on eBay 100/pr or so, it is all what you want in f it is only the housing
  4. May 13, 2023 at 7:57 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'd do the TYC CAPA certified ones from RockAuto before doing the eBay roulette.
  5. May 13, 2023 at 10:27 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    They’re only good for retrofits and even then it’s risky.
  6. May 13, 2023 at 12:42 PM
    1 Limited Toyota
    California
    08 XRunner
    No not looking for justification, just experiences good or bad. No contest Im sure O.E.M. is much better.
  7. May 13, 2023 at 12:42 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I got a pair for my daughter. Her first car and no real need to spend a bunch of cash on lights for a 2004 Pontiac. Got them from RockAuto about 2 years ago. No condensation or seal issues no discoloring of the lenses. I think they were around 150 give or take. Definitely worth it in my opinion. I would have no problem with getting a set for the truck. You could always upgrade later if you wanted to.
  8. May 13, 2023 at 12:49 PM
    1 Limited Toyota
    California
    08 XRunner
    Deal is it appears to have aftermarket and the slightly fogged lenses are really the only issue. That said this truck is a back up 2nd vehicle. It may just sit in the garage and never see another active street light. Im not cheap but is O.E.M.10x's the & worth?
  9. May 13, 2023 at 12:52 PM
    1 Limited Toyota
    California
    08 XRunner
    I'll look into it
    thx
  10. May 13, 2023 at 12:57 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    Oem are higher quality but they are so expensive to me no they are not worth the prices. Some things I won’t compromise on. Drivetrain parts and important electrical I always go oem. Headlights I wouldn’t pick the cheapest but there are good reliable options for a hell of a lot cheaper then what Toyota wants for them.
  11. May 13, 2023 at 1:01 PM
    1 Limited Toyota
    California
    08 XRunner
    Front sight likes this.
  12. May 13, 2023 at 2:56 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Check am-autoparts.com they have sets for a good price with 10yr warranty and are TYC brand.
  13. May 13, 2023 at 3:55 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    When mine fogged I read every thread on here I could find about aftermarket lights since the OEM are like $185/each (or were at the time)- almost all of them had issues and every reply was that the factory headlights had better patterns and throw. I ended up polishing mine but they've fogged again so probably just time to bite the bullet and buy new ones. Being able to see well, especially at night, is one of the greatest safety features of any vehicle.
  14. May 13, 2023 at 3:56 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I had cheap ebay housings on my tacoma for a year or two before I sold it they never leaked or had any problems
  15. May 13, 2023 at 3:59 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Any cheap brand like 100 you have to reseal the main seam with good sealant and hope for the best. Lenses will discolor faster so lenses will have to be rubbed out in a few years too.
    Been there and are still there but I beat them up offroad and get brush scratches so do a quick sand/buff/seal every year. Nothings perfect on mine.
    Most of the cheap sets warranty costs more and thru 3rd party who always question the claim so ...
    No issues OEM is the way to go.
  16. May 13, 2023 at 4:20 PM
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    I went OEM. Not worth the price. Could of bought 3 sets of TYC and been fine. Definitely not the same quality as my originals from 03'
  17. May 13, 2023 at 5:12 PM
    Sasquatchian
    If you don't drive at night none of this matters but if you do then your lights are your first and best line of defense for driving at night. When you start to look at it that way, the OEM's start looking like a bargain, plus, if you put these cheap, non legal lights in your truck and they cause you to get in an accident, your insurance company might just decide to not cover you.
  18. May 13, 2023 at 8:48 PM
    Christmas
    Christmas Well-Known Member
  19. May 13, 2023 at 9:24 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    How long are you planning on keeping the truck? I went through the same thing a few months ago. I got 14 years out of the factory headlight housings. I polished them 3 times to prolong the life, but they were just too far gone to try that again.
    I couldn't find anything aftermarket that I trusted long term. If I'd planned on only keeping the truck 3-5 more years I may have gone aftermarket, but I plan to pass this one down to one of my grandkids.
    The local Toyota service department quoted me $700 for a set. I could order the same thing directly from Toyota for $600. I have a BIL who owns a local body shop and out of curiosity asked him to check on a price. The same service department that quoted me $700 sold him a set on his commercial account for $450. He had Toyota deliver them to his shop and I paid him.
    To be fair, I wouldn't have paid $700 for OEM. I'd have gone aftermarket and planned on replacing them sooner. But it was worth $450 to get OEM.
