Ebay "OEM" black lugs?
Discussion in 'Wheels & Tires' started by MTB Mamba, May 4, 2021.
  1. May 4, 2021 at 9:27 AM
    MTB Mamba
    MTB Mamba [OP] Well-Known Member
    2018 SR5, KDMax 6.0
  2. May 4, 2021 at 8:44 PM
    Nick1999
    Nick1999 Well-Known Member
    Arizona
    2004 Red Tacoma S Runner
    No
    When you try to buy items at eBay, first of all check the seller's feedback. If you see "negatives", then run away. Second-ask the seller same question that you have in your mind and see how this seller will act. See how long this seller is on eBay. Bottom line: be skeptical.
    MTB Mamba[OP] likes this.
  3. May 4, 2021 at 9:01 PM
    Nick1999
    Arizona
    No
    I checked this seller. He has a lot of negatives. The price is just $20, but this makes me suspicious: OEM Factory Style Lug Nuts...means that they have only OEM style. It's up to you. My opinion is they are NOT OEM items.
    Key-Rei likes this.
  4. May 4, 2021 at 9:16 PM
    MTB Mamba
    2018 SR5, KDMax 6.0
    I appreciate the help, I think you’re right. Price is just too good to be true.
  5. May 9, 2021 at 8:42 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I have a set of 24 OEM black lug nuts on order from Amazon. Cost $40.
    12-1.5, 1.87 inch tall (not the 1.47 inch), mag seat with washer, black anodized, thru hardened to grade 10.9.
    Fleecebay is always a place to be very cautious and skeptical of product and seller.
  6. May 9, 2021 at 9:39 AM
    MTB Mamba
    2018 SR5, KDMax 6.0
    Got a link for the ones you went with? All the Amazon ones I’ve seen have picture reviews where the black paint chipped off and they were rusting.
  7. May 10, 2021 at 6:33 AM
    Knute
    Impact gun will destroy the paint. Common.
    Suggest to avoid any shop using impact gun to tighten.
    I was checking shops about swapping my rubber to the restored wheels. Asked about how they control the lug nut torque. The answer was they used "torque sticks" set at 110 lb-ft. My reply, "That is too much torque. The torque spec on my wheels is 83 lb-ft. Can you tighten by hand to that spec?" The answer was a bit soft and hesitant. That shop is out.
    Godzilla619 likes this.
  8. May 10, 2021 at 6:47 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    IIRC a full set of lug nuts from the factory are about $85 when I was selling them.
    These are certainly not OEM based on price, and even the black lugs we had were much much deeper in color depth.
    I suspected those will fade chalk or flake and may even fail.
    Decent lug nuts will set you back $50 or so at least.
  9. May 10, 2021 at 5:05 PM
    KA19Taco
    KA19Taco Well-Known Member
    2019 TRD OFFROAD
    Readylift 3/2 Icon Wheels LED Headlights
    I’d look at bimecc lugs. They are zinc and hold the proper torque when tightening the lugs. I’d be cautious about trying to save money on what holds your wheels on.
    Knute likes this.
  10. May 12, 2021 at 6:32 AM
    Knute
    Zinc lug nuts????
    Zinc has zippo strength. Are you sure those aren't zinc coated steel???
  11. May 12, 2021 at 8:12 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Once again. If you don’t walk out of the dealer with them or order from the dealer no way to guarantee they’re oe.
  12. Jun 26, 2021 at 5:02 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Warning, I bought these about 1 1/2yrs ago abs they are all starting to rust now. Will get some OEM ones to replace them.
  13. Jun 26, 2021 at 11:51 PM
    Zoohan
    Zoohan Well-Known Member
    Factory Level TRD CAI TRD Exhaust TRD 17x7 Wheels - Cooper ST Maxx 275/70 Behind Grill LED Bar
    OEM lugs are worth the spend - bit of a challenge finding black tho.
