Ebay turbo kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by robblacktpre03, Jul 14, 2019.
  1. Jul 15, 2019 at 12:20 AM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    I'm not so sure. Thinking about oil lines and all that. Probably easier to leave the People's Republic and move to some place without those kind of restrictions, yeah? :)
    eon_blue likes this.
  2. Jul 15, 2019 at 12:21 AM
    eon_blue
    Azusa, CA
    Working on it lol.
    DetroitDarin[QUOTED] likes this.
  3. Jul 15, 2019 at 12:21 AM
    DetroitDarin
    York County PA
    usajobs.gov :D
    BeLance89 and eon_blue[QUOTED] like this.
  4. Jul 15, 2019 at 12:21 AM
    garetcurry
    garetcurry Well-Known Member
    I converted my 2rz Tacoma back to stock in a few hours when it was turboed.
    The 5vz might take a little longer, but should probably be converted back every now and then for maintenance alone.
    It's really not that complicated to undo once you've installed it. And a turbo has so much more going on that you're gonna remember how it went together, I can assure you of that.
    DetroitDarin and eon_blue like this.
  5. Jul 15, 2019 at 12:22 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  6. Jul 15, 2019 at 12:23 AM
    DetroitDarin
    York County PA
  7. Jul 15, 2019 at 12:24 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Such is life
  8. Jul 15, 2019 at 12:25 AM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    From what I’ve read 5VZ exhaust manifolds are something you only want to do once.
    BeLance89 likes this.
  9. Jul 15, 2019 at 12:29 AM
    garetcurry
    It's the cross-over pipe that gets you. I think they say you're supposed to drop your tranny to remove it. I cut mine off when I went turbo and didn't have to drop the tranny for the turbo cross-over because it has a flex joint in it. If I ever go back stock, I'm buying headers and welding a flex into them though.
  10. Jul 15, 2019 at 12:34 AM
    Shortman5
    Supercharged TRD
    You can just unbolt the tranny mount and jack it up from the rear a bit. Should slip out after that.
    garetcurry[QUOTED] likes this.
  11. Jul 15, 2019 at 12:38 AM
    garetcurry
    I could weld something up faster that would just slip out and be future proof from then on out. However, that's still good knowledge to have if I'm not feeling the fabrication that day.
  12. Jul 15, 2019 at 5:03 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    when most of the studs snap on your crusty truck it takes alot longer ahaha. had to jack motor up and drill a few out if they didnt come out with a nut welded back on.
  13. Jul 15, 2019 at 5:27 AM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Without derailment of thread point, that “law” is nation wide in various forms, it is supposed to keep people from running underground businesses.
    You can still work on vehicles registered and owned by you, just not your buddies, and you can not do things like motor swaps, and body work. Simple stuff, oil n filter, s plugs, air filter.... been there done that when I lived in CA... pull the vehicle in the garage and shut the door is how you get around it. What others can’t see they can’t report.
    Back to the regularly scheduled program...
    beez likes this.
  14. Jul 15, 2019 at 5:32 AM
    Gixerkiller
    Dennis
    Taylor, TX
    OP, don’t use cheap turbos.
    Make sure the turbo is a good mfg like Banks.
    Weak ass turbos cause more headaches than they are worth.
    If you are dead set on a turbo, ditch the air charged inter cooler and run a liquid intercooler. Increase. In boost and consistent charge are good things, the cooling rate also stays lower which helps preserve the engine.
  15. Jul 15, 2019 at 5:38 AM
    #35
    Shortman5
    Supercharged TRD
    That’s exactly why I’m taking mine to a shop for the headers.
  16. Jul 15, 2019 at 11:50 AM
    #36
    robblacktpre03
    robblacktpre03 [OP] 03 Tacoma Restore time
    Rob
    San Francisco, CA
    03 black pre runner
    k&n air filter, throttle body spacer, all pro UCA, 07 gun metal TRD FJ rims, blacked out interior trim
    Awesome info here. first off, I don't have to get a smog check, registered in fl - military
    second I'm going to hold of for supercharger - seems easier
  17. Jul 15, 2019 at 12:38 PM
    #37
    Indy
    Indy Master of all I survey.
    Get one of those electric superchargers. They're universal and require 0 fab to install. You just take it right out of the box and throw it away. Anyone can do it and it only takes a minute!
    Kevins60 likes this.
  18. Jul 15, 2019 at 4:02 PM
    #38
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    I got flunked on a Ca smog for running a Magnaflow cat!! It was even carb legal.. Went and spent 1k for a stock Toyota cat and passed at another smog shop. I went a half year later to the same spot to smog my Subie and they were pissed that I flunked and went to their spot to redo it as the first smog place was cheaper but ran by Nazi’s, long story short the place that passed me was pissed as a random referee came to their shop and questioned the shit out of them (family friends business). The worst is my motorcycle dyno tuner said the smog ref brought him his Harley with all smog blocked off and got a tune, my tuner was not amused as they can get away with it on their vehicles, Commifornia!?!
    BlackSportD likes this.
  19. Jul 15, 2019 at 4:10 PM
    #39
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    I laughed out loud on this one :rofl:
    Luv my yota likes this.
  20. Jul 16, 2019 at 3:45 PM
    #40
    Luv my yota
    00 turd lift 33's
    Me too! Let’s go weld some stainless to some T-6 aluminum heads. Should work perfectly, lmao..
    beez likes this.
