Ebay Wheel Spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Swank, Apr 14, 2013.
  1. Apr 14, 2013 at 7:48 PM
    Swank
    Swank [OP] Certified Mall Crawling Instructor™
    Steven
    Greenville NC
    SOLD :(
  2. Apr 15, 2013 at 6:30 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    They don't mention if they are hub-centric or not, and the pic does not show the hub-centric lip that should be there. They need to be hub-centric.
  3. Apr 15, 2013 at 6:38 AM
    THE SCHIRMINATOR
    THE SCHIRMINATOR Well-Known Member
    Mid Mo
    06 TRD Tacoma
    For not that much more money you can
  4. Apr 15, 2013 at 6:41 AM
    THE SCHIRMINATOR
    Mid Mo
    06 TRD Tacoma
    for not that much more money you could pick up a set of used name brand ones that you know will work. But hey, if you can get a "no name" set to work just fine for less money then I say go for it.
  5. Apr 15, 2013 at 6:55 AM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport, 1994 Pickup
    3" Leveling Kit with AAL, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    Don't get those, I had them and they are not hub centric. You will never have balanced wheels and a lot of stress will be placed on the studs. Get a set of spidertrax and you will have zero issues, really they're only $100 more.:)
  6. Apr 15, 2013 at 7:14 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    BORA also has hub-centric spacers that are a bit cheaper, they can be found directly or via eBay.
  7. Apr 15, 2013 at 7:19 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'd say play it safe and just save up a little more money and get some spidertrax. Also keep an eye out on here cause there is usually spidertrax used ones for sale every so often.
