EBC Brakes ( shims or no shims ) ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OldDog, Jun 2, 2015.
  1. Jun 2, 2015 at 7:34 PM
    OldDog
    OldDog [OP] Well-Known Member
    w.mass
    2010 reg cab 4X4
    Going to install a EBC brake kit ( pads and rotors ) . Just want to know if I use the original pad shims that came on the Tacoma or not.
    thanks for looking
    Olddog
  2. Jun 3, 2015 at 9:07 AM
    OldDog
    w.mass
    2010 reg cab 4X4
  3. Jun 3, 2015 at 9:09 AM
    OldDog
    w.mass
    2010 reg cab 4X4
    pads are on the way . I got the 7000 Green pads
  4. Jun 3, 2015 at 5:18 PM
    OldDog
    w.mass
    2010 reg cab 4X4
    I called EBC . They said I could use them if I want to ,But don't have to . there sending me new shims (no charge) just in case I do.
  5. Jun 3, 2015 at 5:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    While you have a specific answer for your pad of choice, I thought I'd share some experience.
    I've used a lot of aftermarket pads, including Hawk, EBC, Raybestos, Wagner and parts house labeled bits, either on my own stuff or helping other folks with theirs. I've found that if the braking system is stock, the pads you are buying have always fit and installed the same way as OE bits. Even when they are a 'performance' pad with a more aggressive compound, they still fit the same. I've always found them to be the same in all dimensions, and nuances like little holes for anti chatter springs, etc.
    Of course there may be some that don't meet my experiences. I've certainly not worked with them all. But one thing is almost bound to be true. If you install a set of pads w/o shims, and you hear lots of sounds that don't seem right, you can always go back and add them. For the most part their purpose is noise control, so you shouldn't hurt anything.
  6. Jun 3, 2015 at 6:28 PM
    jonkassidy
    jonkassidy Well-Known Member
    Huntington Beach Ca
    08 PreRunner SR5
    Limo tinted windows
    I just put on the Yellowstuff pads and used the stock shims with no ill effect.
  7. Jun 4, 2015 at 1:54 PM
    OldDog
    w.mass
    2010 reg cab 4X4
    Thanks to all of you for helping me out . Hope to put the kit in next week .
    Thanks again
    Dennis
    DoorDing likes this.
