ebrake issues with lift
Discussion in 'Suspension' started by mixaro, Oct 7, 2009.
  1. Oct 7, 2009 at 11:53 AM
    mixaro
    mixaro [OP] Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    ok i've got an 02 4wd that has got the 5100 billys at 2.5" and a new rear leaf pack that gives me 1.5". well now i'm going to put a set of shackles on it that are 1" of lift. but heres my issue, i've already adjusted the the ebrake cable to as far as it can go on the nut up under the drivers side of the cab, so what do i do now because it's already border line to tight. also along with that has anyone ever run the Maxxis MT-762 Bighorn tires and if you have what do you think because they are only one of a few tire companys that make a 255/85/16 and thats what i want to replace my 265/75/16 with.
  2. Oct 8, 2009 at 5:39 PM
    mixaro
    maine
    bump bump i need some help
