Ebrake Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JonV, Jun 10, 2025.
  1. Jun 10, 2025 at 5:57 AM
    JonV
    JonV [OP] New Member
    So, a while back my ebrake light came on and I have not been able to solve the problem. It’s a 2007.
    Fluid level is good, master cylinder low sensor appears to be working, brake handle switch appears to be good. I’m starting to wonder if it’s ABS related (do get an occasional light), but not sure what to check next. Any ideas would be appreciated. Thanks!
  2. Jun 10, 2025 at 10:16 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There are only three things that I know that turn on the "Brake" LED on the Combination Meter.
    1. Low Brake Fluid.
    2. Parking Brake Switch.
    3. Skid Control ECU.
    Dm93 and TnShooter like this.
  3. Jun 10, 2025 at 10:45 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW..
    JonV[OP] likes this.
  4. Jun 10, 2025 at 1:49 PM
    JonV
    I’ve heard some mention the ABS module could be the culprit. Is that the same ECU you’re referring to?
    Jimmyh likes this.
  5. Jun 10, 2025 at 2:45 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Skid Control ECU = ABS module on Toyota
    You need to see if you have any codes in the ABS module, also look in data and verify PKB SW is off.
    Jimmyh likes this.
  6. Jun 10, 2025 at 4:13 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes.
    Get the codes read and see where it leads.
  7. Jun 11, 2025 at 5:56 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    If your parking brake cable is out of adjustment it can cause the handle to be pulled out a bit and trigger the light.
