Eccracer104's Finally a 4x4 TRD OR AC Build
Discussion in '2nd Gen. Builds (2005-2015)' started by eccracer104, Apr 12, 2018.
  1. Jun 15, 2020 at 2:00 PM
    #1461
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    What have you found to be more noisy?
  2. Jun 15, 2020 at 2:04 PM
    #1462
    eccracer104
    eccracer104 [OP] O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Good to hear! They come in at 68# per tire. 9 more than the 285/75R16 Toyo RTs I had before.
    Ooof...
    Was it the combo just wasn’t enough? Was it at least less bad with the AAL?
    I’m still thinking that might be a good route for me to go to gain a little capacity to compensate for the shell without shelling out for a new pack, but also curious what you have to say about it.
    Slashaar and Drainbung like this.
  3. Jun 15, 2020 at 3:58 PM
    #1463
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    My hankook dynapro were extremely loud.
  4. Jun 15, 2020 at 3:59 PM
    #1464
    anthony250f
    Anthony
    San Diego, CA
    I didn’t try it without the aal. But it sat super super low. It was very very soft too. The AAL is worth a shot since it’s super cheap. I didn’t like how long the all pro leafs were either. Pushed the shackle pretty far back.
  5. Jun 15, 2020 at 4:37 PM
    #1465
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Gotcha. Good to know!
    We’ll see. It needs something, but it’s not an issue, would just be nice to have a little more height and spring rate in the rear.
  6. Jun 15, 2020 at 4:45 PM
    #1466
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Just move to 63 swap! :D
  7. Jun 15, 2020 at 5:11 PM
    #1467
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    That’s really not a bad idea :sawzall::welder:
    I’ll need to look into it some more since @Titus94 has his welder up and running now.
  8. Jun 15, 2020 at 5:27 PM
    #1468
    Slashaar
    Josh
    Kansas City, MO
    @Casper66 @ovrlndkull 63 swap tips tricks and info.
  9. Jun 15, 2020 at 5:29 PM
    #1469
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Take the bed off after you tack in I think it's the passenger side shock tower. Be prepared for lots of cutting and grinding. Skip knows more about the numbers as far as shackle length and stuff.
  10. Jun 15, 2020 at 5:55 PM
    #1470
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    It's not for the faint at heart have everything you need and some extra for just in case. Good springs, shocks, relocation, etc. The swap is only as good as the effort and parts you put into it otherwise you can get away with stock stuff and just as much flex
  11. Jun 15, 2020 at 6:14 PM
    #1471
    desertjunkie760
    Shane
    Check My Sig.
    what relocation do you recommend to run with Chevy 63s?
  12. Jun 15, 2020 at 6:14 PM
    #1472
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Thank you :fistbump:
    Just helped @hoarder23 with his bed, so I’m familiar-ish with pulling the bed. Definitely would help to get up in there for proper welds. Thanks!
    Cutting and grinding is to be expected haha.
    I’ve read up on them in the past, and was there when @YumaTRD 63 swapped his pickup. Definitely more involved than a regular pack.
    A shock relocation is also on my “want” list, if I went to 63s I would time it with a relocation so I could cycle the pack matched to the shocks.
    When you say “everything you need and extra” - Short of jacking up the mounts and hangers, what extra stuff is recommended?
  13. Jun 15, 2020 at 6:17 PM
    #1473
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    I think we installed Archive ones on Skip's truck. Nothing but pure quality there Eric makes nice stuff.
  14. Jun 15, 2020 at 6:20 PM
    #1474
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    We also dropped Skip's gas tank. At first I thought it was uneccesary but in the end for the small amount of extra work involved it is well worth it. We did box the rear section of his frame with 1/4" plate as well though. Kinda had to drop the tank for that. Deffinately made me feel safer having it out of the way while I was welding
  15. Jun 15, 2020 at 6:23 PM
    #1475
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    I hear ya. I saw @hoarder23 ’s dmz frame kit when him and @desertjunkie760 finished it up. They dropped the tank as well, and after seeing that forward driver side plate it was definitely worth dropping the tank.
  16. Jun 15, 2020 at 6:25 PM
    #1476
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Just think through everything you might need then have extra stuff on hand tools, steel, bushings, etc. You never know what may end up sidelining the project. So prepare for it to not go smoothly. Extra bolts, grinding discs, flap discs etc. We had to run to Lowe's a couple of times which could of been preventable if we had thought through more.
    @ARCHIVE is the only one in my eyes unless you want to do some sort of hacked up bedcage thing.
  17. Jun 15, 2020 at 6:28 PM
    #1477
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    A kit, LOL Skip made me some rough templates from cardboard from which i had to cut and fit the plates. It was a fun project. Hell that was an incredible weekend. We removed the bed and tank, did the '63 swap and relocate th Skip's truck. We also did a Cab mount relocate to his truck. Then we did my rear suspension.
  18. Jun 15, 2020 at 6:31 PM
    #1478
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    piddly stuff
    What was it y'all had to go get the big drill bits for?
  19. Jun 15, 2020 at 6:32 PM
    #1479
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Oh the stupid different length shackles had a different bolt dia. compared to the 5" ones
  20. Jun 15, 2020 at 6:38 PM
    #1480
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Is it really a mod if you don’t have to run to the hardware store? Haha.
    Thank you for the reminder on the little things. Get the tools and consumables ready in advance. Check!
    Dude I have to cut metal with a grinder and cutting wheel. It’s a pain in the ass haha.
    But yeah, DMZ makes a really well done dimple died weld in kit. Solid option for those like myself ill equipped to cut that much metal.
