ECG needle bearing question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by handwerk, Apr 11, 2019.
  1. Apr 11, 2019 at 9:08 AM
    handwerk
    handwerk [OP] Well-Known Member
    Would a good professional mechanic with normal tools still need to have the tools specific to installing the needle bearing from ECG?
  2. Apr 11, 2019 at 9:17 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There's various bearing/bushing puller kits out there. Ive got a few in my toolbox. The tool from ecgs is made (obviously) for this specific job. Its a pretty thin bearing, not a lot of surface available to grab onto. Even the ecgs tool only gets a fingernail on it when pulling it out.
    Long story short, im sure a crafty mechanic could make something else work but the tool definately makes it easier
  3. Apr 11, 2019 at 12:02 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Better and safer if you have the tool,you can always resell the tool here on TW.
  4. Apr 11, 2019 at 12:08 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I'm not a pro mechanic but I was able to pull the needle bearing and install the ECGS bushing without using their tools. The puller needs to grab a thin bearing without hitting the housing but this would be the case regardless if you're going to the ECGS bushing or not when you replace the bearing.
  5. Apr 11, 2019 at 1:23 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
  6. Jun 29, 2019 at 9:30 PM
    DalTrd
    DalTrd New Member
    2008 TRD Sport DC
    Do you know which size puller you used out of that kit? I found one for less that has 4 sizes only. But if it has the size I need then perfect
