ECGS bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TJN2015, Jun 13, 2020.
  1. Jun 13, 2020 at 2:22 PM
    TJN2015
    TJN2015 [OP] Active Member
    Tyler
    Corona, CA
    2015 TRD Off-road DCSB 4x4
    I recently did the ECGS bearing on my 2015 and it took out all the play in the cv until I drove it. I checked today it’s it’s back to how it was before with a pretty significant amount of play both up and down and side to side. Anybody experience this before or have any idea what could have happened. Truck had no noises or vibrations while driving so far.
  2. Jun 13, 2020 at 2:38 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Are the vibes gone? My CVs always had a bit of play. Before and after.
  3. Jun 13, 2020 at 2:45 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    The CVs are somewhat flexible by design at each end of the axle so if you’re just grabbing the axle and moving it, that’s normal. The ECGS bushing is meant to reduce play at the axle entering the diff. There’s no way to manipulate it to test for movement without removing the inner boot. If you’re vibes are gone then I’d say your install was successful.
    dk_crew likes this.
  4. Jun 13, 2020 at 3:15 PM
    TJN2015
    Tyler
    Corona, CA
    There is movement when I grab it where it enters the diff which I thought the bearing would get rid of. I don’t have vibrations so I guess it worked for that
    dk_crew likes this.
  5. Jun 13, 2020 at 6:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you have no vibes, noises, or leaks.
    Then I’d just drive it and call it good.
  6. Jun 13, 2020 at 7:29 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    Mine moves inwards and outwards. Passenger does the same
  7. Jun 13, 2020 at 7:34 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    Is it the stock Toyota CV axle or is it an aftermarket replacement?
  8. Jun 13, 2020 at 7:56 PM
    Skada
    Skada Well-Known Member
    Carey
    Corral de Tierra, CA
    Tacoma 2015 DCSB
    My 2015 has the same play as everyone else has described. Apparently it is normal. I did the same as you and was worried that something was wrong but all research led me to believe that it is normal.
  9. Jun 14, 2020 at 5:25 PM
    TJN2015
    Tyler
    Corona, CA
    Alright thanks. Yea it’s the stock CV.
