ECGS bushing didn't fix the vibe...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 13srt8, May 22, 2017.
  1. May 22, 2017 at 3:42 PM
    13srt8
    13srt8 [OP] Active Member
    2017 Inferno TRD DCSB
    So as the title states I still have the vibe that goes away with 4 wheel engaged. I have a 3/2 leveling kit with a diff drop, all MotoFab. Any thoughts on the issue?
  2. May 22, 2017 at 3:58 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Who did the install and what gear oil are you using?
  3. May 22, 2017 at 4:25 PM
    13srt8
    Toyota did the install and probably used stock oil.
  4. May 22, 2017 at 4:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Is it coming from the drivers side?
  5. May 22, 2017 at 4:40 PM
    13srt8
    Yes
  6. May 22, 2017 at 4:42 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Very odd. Go under the truck and wiggle each CV axle. If there's more play in the drivers side than the passenger side, then that would explain the vibrations. Odd that the bushing didn't fix it.
    13srt8[QUOTED][OP] likes this.
  7. May 22, 2017 at 4:43 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Just want to make sure I'm clear, you sourced and provided the ECGS bushing and a Toyota dealership installed it. They didn't just install another stock needle bearing that has now failed?
  8. May 22, 2017 at 4:45 PM
    13srt8
    That's correct. I did have to pay for the install.
  9. May 22, 2017 at 4:46 PM
    G.T.
    G.T.
    CONUS
    Take the diff drop out and run it for a hundred miles.
    Heepspo and JDAM like this.
  10. May 22, 2017 at 4:48 PM
    13srt8
    I was thinking about doing that. Do you think it'll make a difference?
  11. May 22, 2017 at 4:51 PM
    G.T.
    G.T.
    CONUS
    By doing it you will have a better chance to isolate the source.
  12. May 22, 2017 at 4:51 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    I don't think it will hurt anything and may be the source. From what I'm told the 3rd gen doesn't need a diff drop for anything 3 inches and under.
    G.T., wirenut and 13srt8[QUOTED][OP] like this.
  13. May 22, 2017 at 4:59 PM
    G.T.
    G.T.
    CONUS
    I follow the same logic but each situation is different. I've experienced the diff bearing issue but ended up resolving it with a locker. But while we are taking about diff drops, take a moment to read this thread.
    13srt8[OP] likes this.
  14. May 22, 2017 at 5:02 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I hate when people link that thread as if it relates to anyone else on here. That dude had a shit design for his skid and was asking to get it messed up.
    jmaack and 13srt8[OP] like this.
  15. May 22, 2017 at 5:04 PM
    G.T.
    G.T.
    CONUS
    It's worth reading and considering. I agree that the arrangement was less than ideal but as I stated, each situation is different.
    You're mileage may vary.
    speedtre and 13srt8[OP] like this.
  16. May 22, 2017 at 5:04 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Jesus.....
    Yep, remove the diff drop OP.
  17. May 22, 2017 at 5:06 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Diff drop no good
  18. May 22, 2017 at 7:17 PM
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    Yup, when you change more than one thing at a time you don't know what is causing the problem.
    Clay7160 and G.T.[QUOTED] like this.
  19. May 28, 2017 at 11:37 AM
    Sr5_Tacoma
    Sr5_Tacoma Well-Known Member
    Kyle Silva
    Easthampton, MA.
    2008 SR5 Access Cab on 35s
    -6 inch lift. -35×12.50r17 mastercraft MXTs. -17×9 FUEL Hostage black wheels. -20 inch RGB LED light bar mounted in the grill. -RGB rock lights -Led spot light ditch lights on Rago Fabrication ditch light brackets. -Tom Woods custom 1piece driveshaft. -Color matched guage trim. -Pioneer touch screen radio. -12" sub in custom box (between rear seats and center counsel) -Custom made hidden winch mount, with superwinch TS9500 winch. -10,000k HID fog lights. -Fog lights for reverse bulb mod. (Very bright) -Custom retrofit headlights, with switchback turn signals/DRL halos, and RGB demon eyes. -Back up camera. -Onboard air, with auxiliary 5 gal. Tank. -Dual battery (huge 8D mounted in the bed) -JBA UCAs. -Icon front coilovers for 6-7" lift with remote resi and CDCV adjusters. More to come (Icon 13" travel temote resi rear shocks ordered 3 to 5 weeks out) Working on a custom utility bed trailer for camping/overlanding.
    Just curious how much was it tobhave toyota install the ecsg bushing?
  20. May 28, 2017 at 7:25 PM
    13srt8
    I only paid $130 but had a deal to receive the employee labor rate.
    Sr5_Tacoma[QUOTED] likes this.
