Ecgs bushing, diff oil and you
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitepony04, Aug 2, 2019.
  1. Aug 2, 2019 at 12:36 PM
    whitepony04
    whitepony04 [OP] The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    It’s getting closer to lift time and I’m doing the ecgs bushing while I’m there. I know u lose some fluid in the change. What type of gear oil do I add? Or do I need to change all of it? 2500 miles.
  2. Aug 2, 2019 at 12:37 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    A trick to not lose any diff oil, is just jack up the drivers side so it's a bit higher than the passenger. That way all the oil shifts over, and you won't spill a drop. I prefer this to cracking open the diff, unless it's time for a fluid change anyways.
  3. Aug 2, 2019 at 12:49 PM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    I used the weight ECGS recommended and that others also use. It's a heavier weight than what is called for in the manual. I've had no issues.
    To answer your question, you don't need to change it at 2500 miles. I would just top it off if you have some fluid loss.
    EDIT: ECGS recommends 85w140 Non-Synthetic Lucas differential oil.
    Silentshredr likes this.
  4. Aug 2, 2019 at 1:31 PM
    whitepony04
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    So just add the weight the manual recommends.
  5. Aug 2, 2019 at 1:41 PM
    eon_blue
    Azusa, CA
    If you're topping it off then yes, if you're changing it out then go with the stuff ECGS recommends
    Camel89 likes this.
  6. Aug 2, 2019 at 1:46 PM
    jerzsubbie
    jerzsubbie Well-Known Member
    Davidson, NC
    ‘13 GX460
    When I did mine, I jacked up both sides since I was doing my entire lift and it was just easier. I lost a little bit of oil, but not even 1/2 quart.
    Which gear oil to use is a whole ‘nother thread!
