ECGS bushing diff oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NBourque, Sep 4, 2022.
  1. Sep 4, 2022 at 9:21 AM
    NBourque
    NBourque [OP] Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Hey guys do most of you use the 85/140 diff oil after installing the ECGS bushing? What about Lucas 80/90? I live in Maine so temps regularly dip below zero. Thanks
  2. Sep 4, 2022 at 9:41 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Stick with the FSM recommendations. For a colder environment go with the lighter weight, the front ring gear isn’t moving until you’re in 4wd anyhow.
    Ricardo13x likes this.
  3. Sep 4, 2022 at 10:35 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    FSM?
  4. Sep 4, 2022 at 10:41 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    33yrsoftoys likes this.
  5. Sep 4, 2022 at 10:42 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Factory Service Manual
    I also agree stick to the factory weight.
    I used 85w-140, I don’t recommend it unless you are ok with the possibility of some diff oil puking out the breather in cold weather:eek:
    And Yes, before you ask, Mine did this more than once. The remedy is to let it puke and then leave it alone. :thumbsup:
    Again this happened with 85w-140 and not 75w-90
  6. Sep 4, 2022 at 11:10 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    Good to know guys. Thanks. Am I reading the manual right that the transfer case only takes one quart?
  7. Sep 4, 2022 at 11:41 AM
    TnShooter
    Deogee
    STOCK
    I don’t remember exactly. I go by the old school way. Pour it in until it starts to come out the fill hole.
    Yes, technically you will be 1/4-1/2” over full. But I haven’t found any issues doing it this way.
    Superdave1.0 likes this.
  8. Sep 4, 2022 at 11:50 AM
    NBourque
    Nick
    Maine
    ‘21 PRO
    Guess I’m wondering if buying 2 quarts of MT 90 is necessary?
  9. Sep 4, 2022 at 1:08 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Diffs: front 1.6 qts and rear 3.1 qts
    Xfer: 1.1.qts
    Yes Lucas 80w-90 works in all 3
  10. Sep 4, 2022 at 1:17 PM
    TnShooter
    Deogee
    STOCK
    Yeah, but the differentials use GL-5 oil.
    The transfer case can use GL-4 or 5.
    Buy #5 and call it a day:thumbsup:
  11. Sep 4, 2022 at 1:38 PM
    NBourque
    Nick
    Maine
    ‘21 PRO
    I confused the transfer case with the tranny oil. Tranny takes just under two quarts.
    TnShooter likes this.
