Ecgs bushing install - in progress question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xxtavixx, May 18, 2019.
  1. May 18, 2019 at 1:48 PM
    xxtavixx
    xxtavixx [OP] Well-Known Member
    Jacksonville fl
    2018 6MT
    ARB rear locker OVtune Mobtown sliders Core-shifter short throw Trd bro-phony grill Caliraised bumper light bar Caliraised ditch lights Rigid ignite back up lights FN Five Star 16x8 Et0 255/85/16 cooper st maxx MesoJDM fuse box cover MesoJDM led interior lights Bilstein 6112 fronts Bilstein 5100 rears Headstrong 3 aal Toytec 3* shims Mesjodm dome and map lights Diode dynamix ss3 pro yellow Mobtown aluminum front skid 2lo mod SOS front recovery point
    Tool pic for those interested
  2. May 18, 2019 at 1:52 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    in person I cant really see much sticking out anywhere. I was real careful to use a socket that fit perfectly and flipped it so the closed side sat flush against the bushing proving a real solid matinf surface. I then used an extention clicked in to keep the pressure evenly distributed when I struck the extension with the hammer. There really isnt much chance of deformation like this.
  3. May 18, 2019 at 2:02 PM
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    Installed mine with a little more of 1/4” sticking out and no leaks or vibrations
  4. May 18, 2019 at 2:07 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Running my fingfer from the inside, and to the outside there is a small lip I can feel. I included some better pictures (headlamp charged enough to turn on this time), there is no potrusion that I can see or feel.
    The bushing at this point is damaged on the i side, when the tool broke it left a pretty good marring. Right now my priority is removing it, and I am uncertain if an ecgs tool will break again. I really dont want to drop the clamshell.
    I got te ecgs tool used, so I dont really fault ecgs for the tool breaking. I am still in belief that the bushing is out of spec.
  5. May 18, 2019 at 2:16 PM
    op9nf
    Nilo
    Bothell,Washington
  6. May 18, 2019 at 2:38 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    The idea of grinding out the bushing makes me nauseous.
  7. May 18, 2019 at 2:41 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    My only comments to this thread is simple. For anyone about to do this job in the future.
    1) make sure cv slides into bushing uninstalled.
    2) the bushing side going into diff clean up with light sand paper or file to put an ever - ever so small taper.
    3) throw the bushing in the deep freeze for an hour or two. While it’s dry and clean. It will shrink ever so slightly to help get the initial alignment going.
    Flash1034 and daks like this.
  8. May 18, 2019 at 2:44 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    sorry .
    but most likely way to snap the tool was not having it in the center and only grabing the bushing i think. That way you were pulling on the casting, that's the same way people crack the OEM bushing.
    my $.02
    trip to autozone for there puller may help .
  9. May 18, 2019 at 2:47 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Yea, i figured that was why. But how do you keep it in center if the bushing spins with the tool?
  10. May 18, 2019 at 3:13 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    The bushing should not spin with the tool, its a press fit. In this picture you posted it appears you chamfered (grinded) the tool to make it fit behind the needle bearing or bushing, were you pulling using the chamfered side? The chamfered side (as pictured) should face the spider gears and the other side (which is flat) should mate up against the bushing or needle bearing as you turn the tool.
    Nothing wrong with grinding the tool to make it fit, I had to do the same with mine. Several youtube videos showed the same thing.
    jerkwithkeyboard likes this.
  11. May 18, 2019 at 3:16 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    No, beveled side was inside. I had to bevel the tool it was not even close to getting through the ecgs bushing. When I got one end behind the bushing, i probably had 3/4” more to go on the top.
  12. May 18, 2019 at 3:18 PM
    xxtavixx
    Jacksonville fl
    2018 6MT
    Not an option at this point as the ecgs bushing is marred on the inside. Im not comfortable just sanding the marring down really
  13. May 18, 2019 at 3:24 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    What’s marred? Looks fine, put it back together, check for leaks
    Skydvrr, Flash1034 and whatstcp like this.
  14. May 18, 2019 at 3:28 PM
    MtnFisher
    ZeroDrift
    If you had a welder you could weld a nut (same thread size) against some heavy flat stock and you'd be back in business with the removal process. Just a thought
  15. May 18, 2019 at 3:31 PM
    #35
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    You smacked that
    bushing to hell, file the lip and be done with it.
  16. May 18, 2019 at 3:51 PM
    #36
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    This is probably the best place to start. But get a magnet in there to get the metal out and drain and flush the diff. Do you have calipers to measure the OD of the shaft and the ID of the bushing? I can’t imagine it’s more than a mm of clearance issue unless you got the wrong bushing.
    The removal tool isn’t designed to remove their bushing only the bearing. Even removing it with a slide hammer with a pilot bearing puller attachment is going to be difficult because there is very little material to get ahold of.
    For everyone else reading this learn the lesson and don’t use sockets as drivers. I know most DIY guys don’t have a proper driver set but they are pretty cheap and they are made from materials less hard than what they are driving. Sockets on the other hand are heat treated to be fairly hard.
  17. May 18, 2019 at 4:03 PM
    #37
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Clean out all the grease, use a small magnet to pull out metal filings, wipe it out with solvent then take some better pics, it may be better than you think.
    It's a bushing, not a bearing and not a seal.
    Take some better picks with it surgically clean and let us tell you what may or may not work.
    Then maybe some advice on how to fix it in place.
    To take it out you will probably have to use a professional inner bearing puller to remove the old bushing without doing further damage.
    https://www.youtube.com/watch?v=mACnDYAdY-o
    nartmot likes this.
  18. May 18, 2019 at 5:31 PM
    #38
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hell, you can rent them for free from the auto parts store.
  19. May 18, 2019 at 6:04 PM
    #39
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    did you remove that plastic stuffed in the diff before you tried putting the axle in?
  20. May 18, 2019 at 6:06 PM
    #40
    xxtavixx
    Jacksonville fl
    2018 6MT
    Yes, thats just to stop anything from getting back there
    gotblika[QUOTED] likes this.
