ECGS Bushing install questions.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by REDdawn6, Apr 16, 2018.
  1. Apr 16, 2018 at 10:23 AM
    REDdawn6
    REDdawn6 [OP] Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Hey guy. So , I am going over my options. I have a small leak on Dr side ft diff. If I change the seal , I might as well do the ECGS bushing.
    What parts exactly need to be replaced on he seal? (is there an inner and outer seal?)
    What are the Toyota part numbers Id need to buy ? So, my google fu and searching is shit today. Thanks. RED
  2. Apr 16, 2018 at 10:24 AM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    IIRC you can get the seal from ECGS when you order the bushing.
  3. Apr 16, 2018 at 10:28 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
  4. Apr 16, 2018 at 10:29 AM
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Stemmy[QUOTED] and REDdawn6[OP] like this.
  5. Apr 16, 2018 at 10:34 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Thanks guys!!
    gunn_runner likes this.
  6. Apr 16, 2018 at 10:38 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    I did see that but I was unsure if it was OEM. I am seeing that seal on Amazon for $13.70
  7. Apr 16, 2018 at 10:40 AM
    replica9000
    2019 T4R ORP
    Just be careful not to install the new seal backwards like I did, or you'll be buying a second one.
    Stemmy likes this.
  8. Apr 16, 2018 at 10:41 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    I might just buy two and if I dont use ,I have a back up when my front wheel bearings go out..
  9. Apr 16, 2018 at 1:48 PM
    poseytaco
    poseytaco Well-Known Member
    Nicholas
    Indiana
    2012 Off-road
    I bought the seal when I did mine, but didn't end up using it. The existing seal was in like new condition and the tool I bought with my bushing didn't hurt the seal a bit. I guess I could have replaced it, but it didn't seem necessary. 2,000 miles later with no leaks. FYI, I read another member struggled getting the cv out and he suggested tapping it out underneath the truck. Think his member name is Olaf. This method worked very well for me. Took about 3 taps and it was out.
    REDdawn6[OP] likes this.
  10. Apr 16, 2018 at 2:35 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    CV comes out easy if its positioned properly. There is a C clip that needs to be compressed to get through the spider gear in the diff. The opening of that C needs to be facing downward to be compressed easy. If the CV doesnt come out easy at its current point in rotation, push it inward (to relieve pressure on the C clip so it can move) then rotate the CV 1/6th of a turn n try again. Repeat this process till it comes out.
  11. Apr 16, 2018 at 2:51 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Thanks guys. Appreciate the information
  12. Apr 16, 2018 at 8:51 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    @REDdawn6 after seeing your seal leak I decided I didn't want to wait until mine did the same thing. I got a bushing coming only, no seal or tools.
    Are you intent on getting a factory seal because of quality or do you just think ecgs wants too much for one? Just curious. I'd buy the ecgs seal, it's probably just as good. And you know they'll send you the right size!
    Rob MacRuger and REDdawn6[OP] like this.
  13. Apr 16, 2018 at 9:03 PM
    Sprockethead
    Sprockethead Member
    Travis
    San Diego
    2006 Tacoma TRD 4x4
    King Performance RR Shocks, Total Chaos upper control arms, OME Dakar Leafs, 2.5 Degree axle shim, carrier bearing drop
    Don't buy the seal or tooling from ECGS, they rip you off. I bought the seal from NAPA for $8 and made the tooling as I am a machinist by trade. I have the tooling for sale way cheaper on a new post if you'd like it. DM me. Get the bearing from them though!
    sierra141, Stemmy and REDdawn6[OP] like this.
  14. Apr 16, 2018 at 9:32 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Not sure what happened here.
    b_r_o[QUOTED] likes this.
  15. Apr 16, 2018 at 9:36 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Id rather give my money to ecgs than Amazon, but that's just me:rolleyes:
  16. Apr 16, 2018 at 9:39 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    I heard the aftermarket seals are not great lasting quality!? Just asking man, not busting balls @Sprockethead
  17. Apr 16, 2018 at 9:56 PM
    Sprockethead
    Sprockethead Member
    Travis
    San Diego
    2006 Tacoma TRD 4x4
    In my experience, and I've done a ton of seals, most all seals are of similar quality. I prefer National brand, but Napa's has worked well for me in a pinch before. Never tried store brand stuff before, so I wouldn't necessarily recommend them.
    REDdawn6[QUOTED][OP] likes this.
  18. Apr 17, 2018 at 12:58 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That’s what they say but it kicked my ass until I used a prybar and popped it out. No amount of pushing, turning, pulling, repeat worked on that thing.
    gmc8 likes this.
  19. Apr 17, 2018 at 4:23 AM
    Stemmy
    Rob
    Pennsylvania
    :thumbsup: same here, 14 years in so far.
  20. Apr 17, 2018 at 6:58 AM
    nd4spdbh
    SoCal
    I should rephrase, it comes out "easy" with some leverage. I used a prybar as well. but couldnt for the life of me pry it out till i did my method above and got the c clip opening oriented down and then with the prybar it almost fell out .
