ECGS Bushing - Is it a must?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Jan 9, 2018.
  1. Apr 25, 2020 at 8:42 PM
    #221
    Jrabbit987
    Jrabbit987 Member
    Jess
    2016 Toyota Tacoma Sport
    Maybe check ur steering rack, there is a TSB on them.
    Did you check the basics? Alignment, balance in tires ect. I also have spacers for my diff and carrier bearing
  2. Apr 26, 2020 at 3:07 AM
    #222
    imjohn
    imjohn Well-Known Member
    I have not check the steering rack or checked the TSB for it, but will definitely look into it!
    I've gotten my alignment done about a year ago when I first lifted my vehicle but none recently.
  3. Apr 26, 2020 at 3:08 AM
    #223
    imjohn
    I lifted my truck 2.5 inches about a year ago. I did not change out the upper control arms. and alignment was done a year ago along with the lift.
  4. Apr 26, 2020 at 5:54 AM
    #224
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    I think it’s your UCA. I had the same issue, but I knew it was the UCA since my stock UCA was preventing the alignment to get more caster. It showed green, but if you are running larger tires with lift, you may need more caster. After I swapped out the UCA and redid alignment, the shaking stopped.
    I already had ecgs bushing when they did my suspension, but the shaking was still there until I swapped my UCA.
  5. Apr 26, 2020 at 1:18 PM
    #225
    imjohn
    what UCA did you end up buying?
  6. Apr 26, 2020 at 1:21 PM
    #226
    ZekeR7
    JBA, they are pretty popular on here. There's even a thread specifically for them because of how easy it is to lube bushings (they have zerk fittings).
    imjohn[QUOTED] likes this.
  7. Apr 26, 2020 at 2:02 PM
    #227
    imjohn
    Thank you I’ll give it a shot
  8. May 1, 2020 at 8:16 PM
    #228
    imjohn
    so I came to the conclusion that the reason it still vibrates is that there’s still play on my driver side cv axle after installation. Another person did maintenance on installing the bushing and I was wondering if it was correct?
    [​IMG] [​IMG] [​IMG]
  9. May 2, 2020 at 6:14 AM
    #229
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Does vibe go away in 4wd?
  10. May 3, 2020 at 1:51 PM
    #230
    imjohn
    Yes it does
  11. May 3, 2020 at 2:30 PM
    #231
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Something wrong then. I wonder if they even did the work. I haven't had a case where the vibe remained after bushing replacement.
  12. May 3, 2020 at 11:04 PM
    #232
    imjohn
    I showed the picture of it, I’m not sure if that helps.
  13. May 4, 2020 at 3:50 AM
    #233
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    It looks set to the correct depth. Did you have it regeared as well?
  14. May 4, 2020 at 8:23 AM
    #234
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    After lifting the front end about 2-1/2" i got the vibration around 40 to 50 miles per hour, the vibration goes away when i shift into four wheel drive. so yes, i think the ECGS bushing needs to be replaced. this is next on my list to do...
  15. May 4, 2020 at 8:58 AM
    #235
    Sungod
    Sungod Well-Known Member
    St Augustine
    I'm really surprised in this copycat world that ECGS is the only game in town. Nothing wrong at all with ECGS, but odd that there are not 15 different knockoffs.
  16. May 4, 2020 at 9:37 AM
    #236
    imjohn
    Yeah he regeared it and added in the bushing while he was doing it. He said he changed the factory seal aswel
  17. May 4, 2020 at 10:19 AM
    #237
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Did he give you the specs on the regear for it? Pinion preload, carrier preload, total preload, backlash, bolt torques, and/or any pics of the gear pattern?
  18. May 4, 2020 at 11:20 AM
    #238
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    I can't remember where, but I did find a second version when I was shopping for them recently. Just one more version and it wasn't a lot cheaper if I remember right.
    Sungod[QUOTED] likes this.
  19. May 4, 2020 at 7:35 PM
    #239
    imjohn
    Yeah I have all of that. As he was working on it, he sent me information and pics about what he did
  20. May 5, 2020 at 3:56 AM
    #240
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Your image isn't showing on my phone.
