ECGS Bushing - Is it a must?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Jan 9, 2018.
  1. Mar 2, 2021 at 1:37 PM
    #341
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO2s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    Figured I’d add my data point to this thread. I lifted my truck in the Spring of 2020. I immediately noticed the dreaded vibration. Went ahead and installed the ECGS bushing and it’s been smooth sailing ever since.
  2. Mar 2, 2021 at 2:12 PM
    #342
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Is it pretty obvious when the bushing is the source of the vibrations? I've got vibrations that skirt the line of either being real or my paranoid self making them out to be. Can't really get them to consistently come and go and switching to 4WD doesn't appear to make a difference.
    CygnusX191 likes this.
  3. Mar 4, 2021 at 2:48 PM
    #343
    VTYoda
    VTYoda Member
    Nick
    2008 Black Tacoma AC
    TRD Off Road Suspension 1.5" front lift Rear Icon RXT leaf pack Falken Wildpeak AT3W 265/70/17 AR172 Wheels 17x8 0mm offset ECGS needle bearing replacement Leer camper shell Camping platform Ditch lights Front bumper hidden light bar Aftermarket tow hitch Sony Double Din D-ring bed tie downs All in one switch blade key fob
    I just finished changing mine out and could always get it to either go away or drastically reduce with 4wd on, if you cant get the vibes to go away with 4wd i'd recommend maybe checking wheel bearings.
    CygnusX191 and CAG Gonzo[QUOTED] like this.
  4. Mar 4, 2021 at 2:51 PM
    #344
    CAG Gonzo
    2018 OR DCLB BarRed
    Damn more hunting. Also gonna try some shims.
  5. Mar 4, 2021 at 2:56 PM
    #345
    VTYoda
    VTYoda Member
    Nick
    if it's a rhythmic vibration id say most likely needle bearing or wheel bearings. the vibes i had from my driveshaft felt a lot different to me than the needle bearing.
    CAG Gonzo[QUOTED] and CygnusX191 like this.
  6. Mar 4, 2021 at 3:13 PM
    #346
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    That's my problem I keep questioning whether it's the drive shaft or the needle bearing. Still going to swap out the needle bearing here soon when I finally have a minute.
  7. Mar 4, 2021 at 9:11 PM
    #347
    CAG Gonzo
    2018 OR DCLB BarRed
    This is what really drives me up the wall. Not knowing where the vibrations are localized or what causes them or how to trigger them. I'll go do some searching for wheel bearings. There's definitely been times where the vibrations make me feel like something is grinding, say particulates in bearings. Sometimes it feels...girthier which makes me suspect a different system. Could the wheels/tires themselves be causal? I'm getting close to needing to replace them and have some 275s for SEMAs sitting in my garage just dying to get mounted.
    Regardless of outcome, I will also replace the bushing if for no other reason than peace of mind.
  8. Mar 7, 2021 at 9:43 AM
    #348
    Wolfjesus
    Wolfjesus Member
    Colorado
    2001 Tacoma TRD
    OME 881's with nitro charger shocks and full Dakar leaf pack
    Anybody have an ECGS needle bearing removal tool for the 7.5" calmshell (1st gen) they want to offload? I am planning to do this replacement soon to address the vibration issues I am experiencing in my 2001 taco after putting on an OME lift (881's up front).
    TACO TM and CygnusX191 like this.
  9. Mar 12, 2021 at 4:28 PM
    #349
    JHannibal
    JHannibal Well-Known Member
    2014 DCSB 4X4
    I am also looking for an ECGS needle bearing removal tool but 8" for the 2nd Gen if anyone has one they don't need for sale. Gonna do a lift and the ECGS bushing in about a month and figured someone may have the tool. Message me if you have the removal tool and want to sell it thanks!
  10. Mar 12, 2021 at 5:44 PM
    #350
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
  11. Mar 12, 2021 at 7:45 PM
    #351
    Bossman14
    Bossman14 Well-Known Member
    2016 white Tacoma TRD OffRoad access cab
    Stock
    I installed the bushing after my lift and it still made the the noise, there is a TSB for a new front diff. The dealer replaced my front diff and it went completely away
  12. Mar 12, 2021 at 7:50 PM
    #352
    JHannibal
    2014 DCSB 4X4
    Any chance you are wanting to sell the removal tool? I'm going to be doing a lift and bushing install soon.
  13. Mar 14, 2021 at 11:28 PM
    #353
    Bossman14
    Stock
    I threw it way sorry
  14. Mar 15, 2021 at 8:48 AM
    #354
    VTYoda
    VTYoda Member
    Nick
    i have the tool but it got a little damaged during use. still worked though
  15. Mar 15, 2021 at 9:25 AM
    #355
    D Soulman
    D Soulman Well-Known Member
    Dan
    Fargo, North Dakota
    Mine was a very slight humming that appeared immediately after lift. Replaced the bearing with the bushing and it is now gone. If I were to do it over, I would just plan it with the lift install.
    VTYoda and CygnusX191 like this.
  16. Mar 25, 2021 at 5:06 PM
    #356
    banjoGrampa
    banjoGrampa Well-Known Member
    David
    East Tennessee
    2019 TRD Sport 4x4 DCLB
    OME/ Bilstein 2" lift, Deaver aal Pro/Heritage grill TRD PRO wheels w/ Goodyear Ultraterrain 265/70/17 Westin HDX DROP NERF STEP BARS LEER 100R shell Custom bed platform High flow air filter/air accelerator Marine Corps graphics A-Premium mud guards Emblem black-out Rove R2-4K Dash cam
    I installed a 2" lift and it felt fine for a few days. Then I started to notice a pulsating vibration in my steering wheel at around 45-50mph. I took it out on the hiway and tested it out at varying speeds and it repeated. I put it in 4wheel-hi and it stopped- Took it out and it started again. I will be replacing it next week.
  17. Mar 25, 2021 at 8:26 PM
    #357
    TacoBoutNothing
    TacoBoutNothing Well-Known Member
    2019 White TRD Pro
    Same boat. Slight lift at 1500 miles. I'm at 10k now with vibration between 45-55. 4WD makes it stop. I'm scheduled for a bushing install next week. Hope that fixes it..I swear every single mod on these things leads you on a goose chase for another mod...:spending:
  18. Mar 25, 2021 at 9:02 PM
    #358
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's all part of the experience
    SEVtaco likes this.
  19. Mar 25, 2021 at 10:21 PM
    #359
    Racerchoi
    Racerchoi Well-Known Member
    Racer
    Orange County
    2018 Tacoma TRD OR / BMW S1000R
    Started noticing vibrations as soon I began reading this thread. Darn you guys!
  20. Mar 25, 2021 at 10:23 PM
    #360
    SEVtaco
    SEVtaco Well-Known Member
    Orange County
    2021 Tacoma TRD OR
    king2.5s/33s/Deaver/SCS wheels
    I have mine I'm in California tho Ill sell it to you if you still need it obviously not for 45 but let me know.
