ECGS Bushing - Is it a must?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Jan 9, 2018.
  1. Jan 9, 2018 at 4:33 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    It’s a 2nd gen thing also
  2. Jan 9, 2018 at 4:35 PM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    It applies to all Tacomas...they use the same needle bearing.
    OG_Tacoma, sierra141 and 2016Tacoman like this.
  3. Jan 9, 2018 at 4:43 PM
    Rustytaco71
    Rustytaco71 [OP] Well-Known Member
    2018 4Runner
    From what I’ve read it’s been a problem since the 2nd gen and it’s carried over to the 3rd.
    Mr-Paul likes this.
  4. Jan 9, 2018 at 4:44 PM
    Rustytaco71
    2018 4Runner
    The needle bearing is where the shaft from the transfer case connects to the diff correct? Its not where the drivers axle connects to the diff?
  5. Jan 9, 2018 at 4:46 PM
    NeonHeights
    NeonHeights Well-Known Member
    Its the drivers side where the CV axle goes into the diff. If you pop off the CV Axle on the drivers side its right behind the oil seal. It is NOT a 30 minute job to change it. Youre talking several hours if you dont have the right tools and are inexperienced with removing & reinstalling wheel hubs/cv axles
    541taco, trabo, C41n and 8 others like this.
  6. Jan 9, 2018 at 4:47 PM
    Rustytaco71
    2018 4Runner
    Oh no kidding? Damn. Makes me rethink the whole scenario! I might as well take it apart this weekend. I thought it was where the transfer case connects to the diff and I didn’t want to split all that apart. Sweetness, I’ve changed out multiple CV shafts and CV shaft seals so I know how to get it apart. Now to learn something new!
    BlueFalconActual likes this.
  7. Jan 9, 2018 at 4:49 PM
    Rustytaco71
    2018 4Runner
    Definitely not a 30 minute job even for an experienced guy.
    541taco, tacoman45, C41n and 3 others like this.
  8. Jan 9, 2018 at 4:50 PM
    NeonHeights
    Tell me about it. I didnt have a slide hammer strong enough to pull it. So I had to tie a rope onto one end of a sledge hammer and the other end on the CV, and took a couple swings facing away from my truck. Took multiple solid swings before it popped out. Had to get under there and pry it the rest of the way out too.
    Its also super difficult to put it back in without a second helping hand, nobody thinks about re installation haha
  9. Jan 9, 2018 at 4:50 PM
    Rustytaco71
    2018 4Runner
    What was your method to pop it out? From my previous experiences it’s just wiggling it’s way out till it decides to pop.
  10. Jan 9, 2018 at 4:52 PM
    Rustytaco71
    2018 4Runner
    Gotta be careful with yanking them out! Last thing you wanna do split the bearings inside haha.
  11. Jan 9, 2018 at 4:53 PM
    NeonHeights
    Youre gonna want to have several tools with you. Your truck might not be an issue cause its so new but it never hurts to have multiple options if something fails. You could rent a slide hammer with a puller attachment, or do the sledgehammer + rope trick that I did, or try prying it out with a big ass prybar. Or use a combination of them. All I know is mine was a massive pain in the ass, but also a much older truck
  12. Jan 9, 2018 at 4:53 PM
    NeonHeights
    That method was actually recommended by a mechanic haha, The CV never popped out with the yank. Had to pry it the rest of the way out, the sledge just managed to get it un-stuck
  13. Jan 9, 2018 at 4:54 PM
    Rustytaco71
    2018 4Runner
    I just drove it and it sounded fine, no odd vibration. My alignment tech was lazy as hell and I have bad camber so I have to go in and get that aligned. I wiggled the hell out of the CV shaft and it’s right as can be in the diff so at this point I’ll just keep an eye on it. Once I notice it becomes an issue I’ll go ahead and try to have Toyota replace it under warranty, but if all else fails I’ll know what to do.
    NeonHeights[QUOTED] likes this.
  14. Jan 9, 2018 at 4:56 PM
    Wakecoach
    Wakecoach Kiwi in FL
    Kurt
    2015 White TRD Sport 4x4 2001 Subaru Legacy Wagon Bilstein Touring Edition
    King ext, res/adj...3leaf Aal. ECGS bushing. Bullaculla relocate bracket. Pelfrey bilt skids. TC UCA. K+N, Weathertech Mats, TRD side steps, BROV Tacoma Attic, Prinsu Cabrac, TRD OR Tow Hook
    I did my ECGS bushing on install of my 2in lift. There were a ton of people on here saying things like "wish I'd done it while I had everything a part"
    Read enough of those and it convinced me to just do although it seemed crazy doing it on a part that was only 26k miles on it ..
    Anyways. Stoked I did. Install was easy
    gsubioguy, JKU3000 and NeonHeights like this.
  15. Jan 9, 2018 at 4:56 PM
    #35
    NeonHeights
    I wouldnt bother if you arent having any vibrations to be honest. Its a pretty big headache if you arent already having issues. Some people never experience any problems at all, and theyre running way higher lifts than you. And the vibrations are usually very noticeable if they happen. So you can just fix it if it ever becomes a problem
    sierra141 likes this.
  16. Jan 9, 2018 at 4:57 PM
    #36
    NeonHeights
    I only did mine because I had to replace my axle oil seal, it was right there and ready to be done. Way too much work otherwise
    OG_Tacoma likes this.
  17. Jan 9, 2018 at 5:00 PM
    #37
    Rustytaco71
    2018 4Runner
    I appreciate everyone’s insight to the situation. Set my mind at ease. I was over thinking it by a mile and almost regretting lifting it. Th repair sounds simple and straight forward, it’s just a matter of getting the parts apart:benchpress:
  18. Jan 9, 2018 at 5:02 PM
    #38
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    I was super anxious about it but I have no vibes after my lift.
  19. Jan 9, 2018 at 5:03 PM
    #39
    Rustytaco71
    2018 4Runner
    Same boat. I had 10k in my truck before I lifted it too and everything is still in proper working order. The back is a little bouncy but that might be due to my E rated tires and having a block in the rear.
  20. Jan 9, 2018 at 5:04 PM
    #40
    Rustytaco71
    2018 4Runner
    One quick question, anyone know the estimated cost at a shop? Did anyone try going that route before changing it? I’ve been told the ECGS part runs for about $95.
    snowtaco2 likes this.
