ECGS Bushing - Is it a must?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Jan 9, 2018.
  1. Feb 22, 2022 at 11:06 AM
    #421
    andersen24
    andersen24 Well-Known Member
    Andy
    Pismo Beach, CA
    2021 Tacoma SR DCSB V6 4X4
    I had an alignment, it’s not balance (vibration started on old tires that had no vibration before I put the 5100’s in). All was good and it drove perfectly before the 5100’s. Two hours later after doing it, the vibration is there. U-Joints good too. Im going to do the ECGS, but my money is on the driveline.
    CygnusX191[QUOTED] likes this.
  2. Feb 22, 2022 at 11:56 AM
    #422
    SpeySquatch
    2016 TRD OR DCSB
    shims should be the change before dropping the carrier bearing. That is a last resort since the front driveline going into the transmission should never technically be anything but straight how it was stock. Tacomas have 2-piece drivelines that allow the rear to be addressed without touching the carrier bearing (again, a last resort fix).
    I chased vibes forever on multiple Tacomas.
    needle bearing being fixed with ECGS clamshell bushing and shims in the rear always fixed the problem when needed after a lift
    71tattooguy and andersen24 like this.
  3. Feb 22, 2022 at 5:34 PM
    #423
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    The carrier bearing isn't a "last resort" lol. It's a very simple fix to head off *possible* driveline vibrations.
    Agree with the shims, that's a good starting point.
  4. Feb 22, 2022 at 8:22 PM
    #424
    Beaglesridefree
    Beaglesridefree Well-Known Member
    2018 Tacoma DBL cab 4x4 TRD Sport, Premium and Tech Pkgs
    Looking at the particular kit, it doesn’t look like any carrier bearing or diff drop is included. Calling my shop to ask. Easy enough to add it now. My off road will be more like dirt roads/ fire roads. Thanks for the heads up.
  5. Feb 22, 2022 at 8:26 PM
    #425
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I have a bunch of washers on my CB. And the CB is flipped as well.
    CygnusX191 likes this.
  6. Feb 23, 2022 at 5:35 AM
    #426
    la0d0g
    running for the hills
    For crawling not hauling
    The key to fixing this is knowing what your DL angles were before you lifted. You can compare those to the angles after the lift and then shim to get them back in spec.
  7. Feb 23, 2022 at 6:13 AM
    #427
    SpeySquatch
    2016 TRD OR DCSB
    I have spent some pretty significant time with drivelines vibes. If you read up on driveline issues with Tacomas you will find that the front piece of the driveline should only change from its stock angle/location if it has to. The rear driveline piece is the one that moves
    it is the proper way to do it
    https://www.tacomaworld.com/threads/driveshaft-angles-what-size-shims.377558/#post-10363382
  8. Feb 23, 2022 at 7:02 AM
    #428
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Yup, that pic represents the best way to correct driveline angles. Another way to fix the angle from trans output to center support bearing is replacing motor mounts and trans mounts. When the motor mounts wear, the trans output rises creating more of an angle.
  9. Feb 23, 2022 at 7:26 AM
    #429
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    SpeySquatch[QUOTED] likes this.
  10. Feb 23, 2022 at 8:20 AM
    #430
    SpeySquatch
    2016 TRD OR DCSB
    great point! Although, an obnoxious task
  11. Feb 27, 2022 at 2:30 AM
    #431
    4x4NorthStar
    4x4NorthStar Member
    I have an intermittent hum that is most noticeable going around 30 mph (hum half a second, quiet for 2 seconds).
    Started after a 2.5 inch lift in front. Should I try a diff drop first? Seems like an easy thing to test out before getting into replacing the bush.
    Curious on any success stories with front diff drops.
    CygnusX191 and Montana_Actual like this.
  12. Feb 27, 2022 at 6:20 AM
    #432
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    If you off road even the tiniest bit, skip the diff drop.
    Intermittent hums.... Check your tire wear (chalk test) also inspect your CV boots. Sometimes they can wear prematurely before a moderate lift settles. (Ask me how I know). Also did you get an alignment done after your lift? (And what lift is it)
    Any lift in the rear?
  13. Feb 27, 2022 at 6:55 AM
    #433
    4x4NorthStar
    4x4NorthStar Member
    I do off road, so I get your point. Though I would try this before anything since it’s easily reversible.
    Rotating tires and trying out different pressures did not get rid of the hum.
    I tried getting an alignment but shop told me they rather do it with new set of cam bolts since mine (they said) are probably seized.
    I probably should be prioritizing the alignment since I do have observable positive camber.
    The lift is all Eibach stage one. I have a 2.7 so got between 2.5 and 3 inches in front. It has probable settled to 2.5.
  14. Feb 27, 2022 at 7:09 AM
    #434
    ClimbMaintain
    ClimbMaintain Well-Known Member
    2020 Tacoma TRD OR DCSB AT
    What you are describing is pretty much exactly what I had after I my Ironman lift was installed. The ECGS bushing cured it completely.
    Have you tried switching to 4hi while the humming is happening?
    If the humming stops in 4hi that is fairly diagnostic and typically means the ECGS route is the way to go.
  15. Feb 27, 2022 at 7:29 AM
    #435
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Sounds like it's time for new cam bolts since they're "probably" seized (and a new shop because of those guys didn't know by looking at them.....)
  16. Feb 27, 2022 at 7:55 AM
    #436
    BTH1
    BTH1 Active Member
    Bill
    Ocala Fl.
    2022 SR5 4x4
    TRD dealer installed lift
    One of the reasons I went with factory approved dealer installed lift when I purchased the truck
    Montana_Actual and CygnusX191 like this.
  17. Feb 27, 2022 at 9:07 AM
    #437
    4x4NorthStar
    4x4NorthStar Member
    Is that even an option for a bloke like me with a 2014?
  18. Feb 27, 2022 at 9:16 AM
    #438
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    No but you're fine with the 16,000 aftermarket offerings.
    Montana_Actual likes this.
  19. Feb 27, 2022 at 9:17 AM
    #439
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    For 99% of Tacoma owners, that factory lift is perfect. Had it been an option when I bought my truck I probably would have gotten it as well knowing I would eventually upgrade down the line but having the piece of mind of warranty covered factory lift giving me room to run a little bit larger tires for quite a while
  20. Feb 27, 2022 at 12:04 PM
    #440
    la0d0g
    No. Consider yourself lucky.
