ECGS Bushing - Is it a must?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Jan 9, 2018.
  1. Mar 14, 2022 at 9:42 AM
    #521
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    i have the TRD lift on my truck. I put it on myself and the dealer really wouldn't do anything for me with the needle bearing. If anything they are just going to replace the needle bearing with another needle bearing.
    CygnusX191 likes this.
  2. Mar 14, 2022 at 9:43 AM
    #522
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    This just seems like a huge oversight on toyotas part. To sell something that is known to cause a failure of another part without offering a remedy for the failed part.
  3. Mar 14, 2022 at 9:50 AM
    #523
    16TacomaSport
    Jon
    Pittsburgh PA
    i 100% agree. I tried to see if they would replace the bearing and then just use my ECGS one but they wanted $700 to install and claimed 5hr for the replacement. i have seen videos of people do them on the ground with a floor jack in under an hour.
  4. Mar 14, 2022 at 9:54 AM
    #524
    5nahalf
    Erik
    Minnesota
    Would be nice if they had a updated part, mine needs to be replaced, and mine also falls under the TSB thats covered under powertrain warranty. But if they are just going to to put the same trash in i'll do it myself.
  5. Mar 14, 2022 at 9:58 AM
    #525
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yep, I timed myself at 33 minutes yesterday. First time using the ecgs seal driver/bearing driver as well, instead of just using random sockets that fit to drive the new bearing/seal in.
  6. Mar 14, 2022 at 10:02 AM
    #526
    5nahalf
    Erik
    Minnesota
    Without me reading any instructions was it like this?
    Remove wheel
    Remove 2 bolts for spindle to lower control arm
    Yank axle out of diff while still attached to wheel bearing
    Pull needle bearing, install bushing
    Put axle back in
    Bolt spindle to lower control arm
    Install wheel.
    jruiz555, CygnusX191 and satburn like this.
  7. Mar 14, 2022 at 10:07 AM
    #527
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    We know. For some unknown reason they refuse to use a bushing.
    Not really .... Other than jeeps sway bar disconnect, no manufacturers really have any 4x4 tech that's more advanced than any other.
    No. The lifts put premature wear on the needle bearings but they don't wear them out at 10k.
  8. Mar 14, 2022 at 10:19 AM
    #528
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Toyota has that hydraulic sway bar system in the 4Runners and Landcruisers.... possibly Lexus Atwell... sort of a sway bar disconnect system... in a way. It certainly has it advantages and it's draw backs... but yes you are correct... 4×4 tech is pretty universal. It is just implementation of the tech that differs from on brand to the next.
    CygnusX191[QUOTED] likes this.
  9. Mar 14, 2022 at 10:42 AM
    #529
    jdmjustin
    jdmjustin Well-Known Member
    Justin
    SW MO
    2018 BBP Tacoma Sport
    Motegi MR149 17x8.5 Falken Wildpeak 265/70/17 Toytec Aluma 2.0
    That's exactly how I did mine. I couldn't find a 35 mm socket to save my life, I just used this method.
    Key benefit is not having to mess with tie rods or upper ball joints is a plus.
  10. Mar 14, 2022 at 12:00 PM
    #530
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Kinda forgot about that. By comparison the Tacos are primitive.
    But primitive.... Works. And is reliable.
  11. Mar 14, 2022 at 5:22 PM
    #531
    banjoGrampa
    banjoGrampa Well-Known Member
    David
    East Tennessee
    2019 TRD Sport 4x4 DCLB
    OME/ Bilstein 2" lift, Deaver aal Pro/Heritage grill TRD PRO wheels w/ Goodyear Ultraterrain 265/70/17 Westin HDX DROP NERF STEP BARS LEER 100R shell Custom bed platform High flow air filter/air accelerator Marine Corps graphics A-Premium mud guards Emblem black-out Rove R2-4K Dash cam
    Let us know what your experience with them is and what they charge. I had a really good experience with both customer service and price. It would be good to know if they are consistent.
  12. Mar 31, 2022 at 10:41 AM
    #532
    5nahalf
    Erik
    Minnesota
    Finally order my bushing today. Got the whole deal, bushing, seal, install and removal tools. Going to put it in as soon as it shows up.
    I put in the comments "Can you draw a picture on the box?" too. Hope I get something cool :)
    CygnusX191 and jdmjustin like this.
  13. Apr 5, 2022 at 7:47 AM
    #533
    scoomas
    scoomas Well-Known Member
    Scott
    2006 Silver Tacoma TRD/OR
    I have a new bushing and a tool that I made I’m looking to get rid of. Already used the tool once when removing my needle bearing so it does work. $70 shipped for anyone in the lower 48
  14. Apr 10, 2022 at 6:29 AM
    #534
    SuperAir
    SuperAir Well-Known Member
    Maine
    19 TRD ORAC Cement
    Eibach Stage 1, 17x8.5 Ray 10s, 265/70-17
    I gambled on the bushing install yesterday when I did my Eibach stage 1 kit. I lost. Looks like I’ll be digging back into it lol. Should have known……
  15. May 11, 2022 at 12:46 AM
    #535
    jruiz555
    jruiz555 Well-Known Member
    Challenge accepted lol
  16. May 11, 2022 at 3:32 AM
    #536
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I installed the Tacoma OEM lift kit myself last summer using the topmost ring on the front shocks and a 2" AAL for the rear. Don't have any felt or audible needle bearing failure as of yet. Still have the ECGS bearing and install tools standing by if needed. I think I may be one of the few 'Taco owners here that doesn't have issues with the stock needle bearing.
  17. May 13, 2022 at 4:17 PM
    #537
    jruiz555
    Alright ill admit it, it took me 1.5 hours. About 30 mins to smack the bushing in, an hour to clean up my mess.
    I installed it without removing the skid plates and axle nut. Also i didnt remove the out seal i found that an old tensioner pulley fit right over the seal so i didnt damage it when using the ecgs tool kit.
    I only remove the stabilizer bar tie end and 2 lower ball joint bolts.
    Fyi Toyota diff oil is 30 bucks for a liter geeeez.
    I lifted the truck on the driver side so it didnt spill much oil
  18. May 13, 2022 at 7:19 PM
    #538
    Mystery252
    Mystery252 Well-Known Member
    Really cool group of guys at ECGS and a fair price for the work they do. I live an hour and a half away so it was easier for me to have them do it than to pay for all the tools and risk screwing something up myself. They have a nice big sign by the front door that says no photos or videos so the sign at the end of the driveway was the best I could get.
    la0d0g and CygnusX191 like this.
  19. May 13, 2022 at 7:51 PM
    #539
    jruiz555
    Cool the work isnt difficult, if you have a lift im sure it would take like 20 mins
  20. May 13, 2022 at 8:59 PM
    #540
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    You buying the wrong diff oil then lol. Damn... 30 bucks a liter...
