ECGS Bushing - Is it a must?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Jan 9, 2018.
  1. May 13, 2022 at 10:16 PM
    #541
    jruiz555
    jruiz555 Well-Known Member
    Yea i was tempted to just fill with what i had already at home and i didnt want to drain it. Toyota puts the diff oil in a can that you have to open with a can opener or something . Geez they gotta be rebels all the time and do crazy stuff like that
  2. May 14, 2022 at 5:49 AM
    #542
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Well guys finally getting this done on my 2017 yota original owner with 158k miles. parts are shipped doing this next Saturday along with new upper and lower ball joints + new wheel hub assemblies. My passenger wheel bearing is starting to go . Too much high speed cornering lmao
    JDSmith and CygnusX191 like this.
  3. May 18, 2022 at 3:56 PM
    #543
    Aje0010
    Aje0010 Well-Known Member
    Alec
    2019 Quicksand TRD-OR MT
    Anyone have a bearing removal tool and/or a bushing install tool they'd be willing to sell?
    CygnusX191 likes this.
  4. May 18, 2022 at 4:53 PM
    #544
    la0d0g
    running for the hills
    For crawling not hauling
    There is a "pass it around" thread on here. You might want to search for it. Could save you some bucks.
  5. Jun 7, 2022 at 4:05 PM
    #545
    wicked1
    wicked1 Well-Known Member
    Couple questions...
    Is everyone who has had vibrations, and removes the bearing, seeing a broken bearing? Or, can it look fine, but you still get the vibrations?
    And, how much play is OK in the CV shaft? Where it enters the... transfer case, I think. The drivers side definitely has more than the passenger side. Both up/down, and in/out. But, not horrible. The passenger side moves a little, and the drives side is about twice as much..
    I don't get any growling or vibrations that go away in 4wd.. But, I am replacing my CV axle due to a torn boot.. so while I'm in there... Thinking about this bushing.
    Thanks a lot!
  6. Jun 7, 2022 at 4:49 PM
    #546
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Differential.
    What truck are you driving?
  7. Jun 7, 2022 at 6:26 PM
    #547
    wicked1
    Yeah, differential, thanks.
    The in-out play there seems large on the drivers side.. I want to say 1/8th of an inch, but I don't know.. I wasn't thinking about measurements when I was looking at it earlier. It has a little up/down, left/right wiggle.. I don't want to try to guess the degrees at the moment, but could measure it tomorrow. It's not much, but like I said, about twice what the passenger side wiggles.
    2012 Tacoma standard model (not trd offroad or anything). It does have the towing package, from what I can tell.
    CygnusX191[QUOTED] likes this.
  8. Jun 7, 2022 at 6:40 PM
    #548
    wicked1
    Well, I decided to search, and it seems the in/out play is normal. Even people w/ the bushing are saying they have it.
    I'm still wondering if there was visible damage to the bearing, when people who had noise/vibration issues, replaced it.
    thanks
  9. Jun 7, 2022 at 7:04 PM
    #549
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    In and out play is nothing to be concerned about. It is a spines shaft into the side gear. And the whole axle is captured between hub and diff. It isn't coming out unless something serious goes wrong. The up and down play (or side to side... they are the same) is where the bushing changes things. The bushing has tigher clearances and after the install, the drives side has about the same play as the right side. There are millions of Toyota's out there with the factory needle bearing that have run for decades without a problem. Even factory lifted Tacoma's in recent years. Unless you are lifted and having issues changing it is completely up to you.
  10. Jun 8, 2022 at 6:46 AM
    #550
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    It's also a cheap enough piece of insurance that I would say go ahead and do it. I've been running with a 2-in OME lift for years before I put mine in and the needle bearing came out looking better than factory. Think I still have it in a box come to think of it. But I put the bushing in as insurance for the future.
    No doubt on the 4th gen Toyota will fix the driver side wheel bearing issue (by moving it to the passenger side) :anonymous:
    CAG Gonzo and Speedfreak like this.
  11. Jun 8, 2022 at 8:28 AM
    #551
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Exactly why I changed mine, especially since I was already in there doing the lift and upper control arms... only a couple more bolts.
  12. Jun 8, 2022 at 8:43 AM
    #552
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Mine looked absolutely mint when I removed it.
  13. Jun 8, 2022 at 5:59 PM
    #553
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I've got a little in/out play on my driver's CV (more than the passenger) after installing the bushing. I replaced the seal while I was in there and haven't had any leaks or explosions.
    Yet.
  14. Jun 9, 2022 at 12:21 PM
    #554
    Old Salt
    Old Salt Well-Known Member
    Virginia
    2020 Tacoma TRD Offroad
    3” sst lift, 285/75r16 Cooper AT3, 16x8 XD series Bully wheels, TRD PRO Grill, TRD PRO skid plate, ECGS bushing, GFC V2 PRO, Martin Offroad Camper Rack, Caliraised Ditch Lights, Caliraised 40" Lightbar, raptor lights, Overland Equipped Fuse Block, Kicker CS 6x9 doors, STI tweeters, Kicker 10" Comp RT subs, Kicker CX400.1 amp
  15. Jun 11, 2022 at 5:38 PM
    #555
    Aje0010
    Alec
    I have a set of ECGS tools for sale.
    Bushing install and removal tool, plus seal Install tool.
    Pm me
  16. Jun 11, 2022 at 6:19 PM
    #556
    Joe in Tennessee
    Joe in Tennessee Member
    Joe
    2012 TRD Off Road Nautical Blue
    I had to replace mine in my 2012 Gen2
  17. Jun 11, 2022 at 9:03 PM
    #557
    Bigmatt503
    Bigmatt503 Well-Known Member
  18. Jun 12, 2022 at 3:55 AM
    #558
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I might have to check this out
  19. Aug 24, 2022 at 2:35 PM
    #559
    zacinnc78
    zacinnc78 Well-Known Member
    Still deciding which taco to order
    does this apply to 2wd models?
  20. Aug 24, 2022 at 2:45 PM
    #560
    wicked1
    no
