ECGS Bushing - Is it a must?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Jan 9, 2018.
  1. Aug 24, 2022 at 2:47 PM
    #561
    zacinnc78
    zacinnc78 Well-Known Member
    Still deciding which taco to order
    thanks bud i thought not just wanted to make sure
    CygnusX191 likes this.
  2. Aug 24, 2022 at 8:14 PM
    #562
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Always better to ask now and look slightly dumb than to ask on the side of the highway with your wheel off in the woods And look incredibly dumb :cheers:
  3. Sep 19, 2022 at 6:16 PM
    #563
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
  4. Nov 16, 2022 at 7:29 PM
    #564
    TacoHungry
    TacoHungry Well-Known Member
    CO
    '22 AG DCSB TRD Off Road
    How many people replace the seal as well? Reading through this thread it seems like it’s not necessary if you’re careful?
  5. Nov 16, 2022 at 7:30 PM
    #565
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Just get it and replace it. If you fuck it up (you will) and dont have one, then your going to be waiting for one to show up.
  6. Nov 16, 2022 at 7:39 PM
    #566
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    I replaced the seal when I did my 2013 and it leaked. I was heartbroken and paid the dealer huge $$$ to replace it since I didn't have it in my to rip it apart and try and get the seal seated correctly. I had maybe 30,000 miles on the truck at the time. I used the ECGS seal, not an OEM one and I'm not 100% sure I seated it properly, but it leaked and I wept.
    I did not replace the seal when I did my 2016 with approximately 18,000 miles on it and I'm at 57,000 miles without a leak. If the truck is new / low mileage and there's no visible damage to the seal I'd be more apt to roll the dice and not replace it, but I might be crazy.
    That being said, I've said it before but I feel replacing the bushing should be SOP if you're doing a lift on these trucks. Outside of cost there's absolutely zero downside in my mind. If you don't you run the risk of having to blast apart your work rather than already being in there and just doing it.
  7. Nov 16, 2022 at 7:45 PM
    #567
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    My 3rd gen has a vibration in a very narrow speed range when applying the gas peddle: 40-43 mph. It's not constant but regular enough to be annoying. Is the a symptom of a needle bearing problem or just a random resonance in my truck? It seems to persist when I switch over to 4WD but tough to confirm since I don't have a lot of straight roads around me.
  8. Nov 16, 2022 at 7:46 PM
    #568
    TacoHungry
    CO
    Truck has under 5k miles, if I’m sure the seal is pristine afterwards I won’t replace it. Ordered the seal anyway, honestly $22 is a pretty fair CYA fee
  9. Nov 16, 2022 at 8:21 PM
    #569
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    If you turn 4hi on and the vibration goes away then it's your bushing.
    If that doesn't affect it, it is most likely something else. Could be a random resonance, could have lost a wheel weight, you might be running tires that are wearing a little funky. Who knows
    AZPhys13[QUOTED] likes this.
  10. Nov 16, 2022 at 8:24 PM
    #570
    la0d0g
    running for the hills
    For crawling not hauling
    I've done a few newer 3rd gens and never needed to replace the seal. Take your time extracting the bushing and it'll be fine.
  11. Dec 6, 2022 at 5:14 PM
    #571
    Chicago77
    Chicago77 Well-Known Member
    Thinking about doing this when I replace lift because I am replacing the axles anyway. Does anyone have the removal tool in MA?
    I will also venmo for a flat rate usps shipping and then pass it along if anyone has one to spare.
  12. Dec 6, 2022 at 6:08 PM
    #572
    Chicago77
    Alternatively, if anyone wants to do theirs and are near westernmass we can do both trucks at the same time in my garage and split the cost of the new tool/shipping. targetting Dec 15-17
  13. Dec 6, 2022 at 8:27 PM
    #573
    Andrew.arw
    Andrew.arw Chief Beer Officer
    South Carolina
    2018 Toyota Tacoma TRD OR 3.5 V6
    *** Current Setup - 2/27/24 *** - Wheels // Method 316, 17” - Tires // 275/70/R17 // Falken WildPeak A/T4W - Suspension // 2.5” lift // Eibach’s Pro lift, Stage One - front & rear // Eibach Pro Springs // Icon AAL // TC UCA’s - Lights // Rigid Industries Dual Pod’s [Grille] // Rigid Industries Dual Pod’s [Rear Bumper] // Rigid Industries 40” LED Bar [Roof Rack] // XenonPro Hi/Lo Beam // LASFIT Switchback Fogs - Auxiliary // Switch-Pro controller, SP-9100 Series - Audio // Rockford Fosgate R500X1D Amplifier // Dual Rockford Fosgate P1 10" Subs - Accessories // TRD Pro Grille // Prinsu Roof Rack // Rough Country Soft Tri-Fold Tonneau - Armor // Body Armor Rear Bumper, 4x4 Desert series // TRD Pro Skid Plate - Misc Mods // ECGS Bushing // Cali Raised AC Drip relocate // CMC
    Highly recommend it — Works like a charm.
    PS: Check your axel seal after 25 miles. If anything is prone to going wrong, it’s getting the seal back. Which usually isn’t an issue, but it happens. Gear oil flinging up on hot engine components smells.. oh so good.. let me tell you.
  14. Dec 6, 2022 at 8:33 PM
    #574
    Chicago77
    Ha, Im oiling the bottom of the truck when Im done to fight the rust so I will have that smell anyway. I am replacing the seals when I replace the axles. I figure I am there, they are 18 years old, and its $20.
    I am just adverse to paying $45 for the puller on the needle bearing. So much cost already with everything else I'm swapping.
  15. Dec 6, 2022 at 8:57 PM
    #575
    la0d0g
    There is a thread for passing the tool around.
  16. Dec 6, 2022 at 9:05 PM
    #576
    Chicago77
    Do you have a linke? I did search for that, but only found one in buy/sell that I cant post in.
  17. Dec 6, 2022 at 9:21 PM
    #577
    la0d0g
    I don't. I searched and can't find it so maybe it was a figment of my imagination.
  18. Dec 17, 2022 at 9:39 AM
    #578
    KevKev_22
    KevKev_22 Well-Known Member
    2021 Tacoma TRD Sport
    Getting ready to have Bilsteins installed. Should I request this bushing be replaced during the install? Is it cheaper that way? Is anyone willing to share what they paid to have it done, whether it was during their lift or after the fact? Also, is this bushing something that most shops carry or is it more of a special order? Thanks!
  19. Dec 17, 2022 at 10:08 AM
    #579
    Chicago77
    You have to buy it from ECGS.
    I would say it will add 20min-1hr depending on how they replace the shocks. They should be able to get the needle bearing out with the right size puller if they have it. I want to say it’s a 35mm but I used to the tool made by ECGS
    It took 5 minutes to pop it out and put the new one in after I pulled the driveshaft.
    I think $50 would be super cheap and $150 would be fair. I don’t know what people pay.
  20. Dec 17, 2022 at 1:28 PM
    #580
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Nailed it
