ECGS Bushing - Is it a must?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Jan 9, 2018.
  1. Jan 23, 2019 at 7:44 AM
    #141
    Mrtoad25
    Mrtoad25 Well-Known Member
    Reno NV.
    2016 TRDSport
    Does anyone know if freezing the ECGS bushing helps with installing it. Or just oil it up and pound it in.....My wife prefers the second one......
    ssmith0480 and SaulGoodman like this.
  2. Jan 23, 2019 at 7:45 AM
    #142
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Freeze it for sure. I do that on all installs
  3. Jan 23, 2019 at 8:50 AM
    #143
    Rustytaco71
    Rustytaco71 [OP] Well-Known Member
    2018 4Runner
    The thing I’ve seen people do is get the tool stuck in the diff though and struggle to get it out, that could be a little nerve wrecking:bananadead:
  4. Jan 23, 2019 at 8:57 AM
    #144
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Getting it in is easy if you have a punch and a hammer. Just shove a plastic baggy in, then get the tool lined up and use a punch to tap it in past the needle bearing. Voila. What usually give me the most issues is getting the CV out. On a new truck it can be a bitch
  5. Jan 23, 2019 at 9:44 AM
    #145
    taco_boy
    taco_boy Antiplastidipper
    California/Land of the Fee
    2018 Tacoma TRD On Road MT
    Noob Taco owner
    A pry bar on the notches with a 4 lb. mallet does the trick. Same way going in.
  6. Jan 23, 2019 at 9:47 AM
    #146
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh I know, but once I had one that was so fucking stubborn, I had to have someone manning the prybar with all their weight on it, while I simultaneously make a "slide hammer" with a 3' pipe wrench and some cord that wouldn't stretch, and swung it like a golf club. After 15 seconds of hard swings the fucker popped out.
    taco_boy[QUOTED] and sdsurfer like this.
  7. Jan 23, 2019 at 10:15 AM
    #147
    Offroad505
    Offroad505 Member
    New Mexico
    18' DBCB TRDOF
    From my understanding this is only done on the drivers side why doesn't that passenger side have one?
  8. Jan 23, 2019 at 10:19 AM
    #148
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Good question, maybe because the tcase is on the driver's side?
  9. Jan 23, 2019 at 10:26 AM
    #149
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    For whatever reason Toyota didn’t use a needle bearing on the passenger side. You can kinda sorta see that here. This is a pic of my diff.
  10. Jan 23, 2019 at 10:33 AM
    #150
    Hank Heel
    Hank Heel Well-Known Member
    WA
    How likely am I to damage output seal?
    I know they’re pita to replace, at least on other car i have
  11. Jan 23, 2019 at 10:36 AM
    #151
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There’s a very real chance you’ll damage it, but if you’re cautious you’ll be fine. It’s not hrs to replace it, but it is hard driving it to the right depth so it doesn’t leak again. I’ve had to do my passenger side like 4 times over the last year and a half because apparently I suck at it.
  12. Jan 23, 2019 at 10:41 AM
    #152
    Hank Heel
    WA
    This I know lol, I had to replace 2 on an M3, I ruined 2. First you have to drive to right depth, then make sure it’s equally seated, so that coupled with space constraints made it for a pita. I’ll have to be real careful, then again I say that a lot..
    EatSleepTacos[QUOTED] likes this.
  13. Jan 23, 2019 at 12:13 PM
    #153
    Offroad505
    Offroad505 Member
    New Mexico
    18' DBCB TRDOF
    That's weird, I'm sure there's a logical reason for it, you'd think they would do the same because needle bearings are so fragile. Good to know! Thanks!
  14. Jan 23, 2019 at 7:51 PM
    #154
    Mrtoad25
    Reno NV.
    2016 TRDSport
    MT_TACO16 and taco_boy like this.
  15. Jan 23, 2019 at 9:15 PM
    #155
    taco_boy
    Noob Taco owner
  16. Jan 29, 2019 at 6:01 PM
    #156
    Mrtoad25
    Reno NV.
    2016 TRDSport
    Well its good to be back. Tacoma world gave me a 3 day vacation. Got my needle bearing out and ECGS in. Drives great with no vibes or humm. Anyone looking for the needle bearing puller let me know.
    Update. I no longer have the tool.
    Offroad505 likes this.
  17. Feb 2, 2019 at 4:11 AM
    #157
    Hydro915
    Hydro915 Member
    2018 Tacoma Sport DC SB MGM
    Leveling kit TRD wheels and KO2 and CBI rock sliders
    Mrtoad25 I could definitely use the bearing puller...
  18. Feb 3, 2019 at 1:41 PM
    #158
    HercDriver
    HercDriver New Member
    First post here, I've been reading a lot and did the ECGS install today on my '16 (50k miles)
    A few things I learned doing it:
    -I installed mine ahead of the lift I'm doing next weekend. I actually had a growl and some vibrations around 45-50mph even with stock suspension, and this bushing fixed it.
    -My CV axle was very hard to remove, had to end up using a slide hammer with a hook and some metal clamps. This worked in about 10 seconds whereas the pry bar/hammer method took about an hour with no progress.
    -Autozone rentals are great... torque wrench and slide hammer were clutch.
    -I had to grind an angle on the ECGS removal tool like many others, after the mod it was easy.
    -I had the bushing in the freezer for a day prior to install and it was still a pain in the ass to get in. I used a bearing/race driver kit from harbor freight.
    -Grease the clip on the axle before you put it back in just like others have mentioned. Grease will hold the open end facing down, otherwise it's a pain.
    If anyone else needs the ECGS removal tool, I can ship it out. Just ask that you pay it forward.
  19. Feb 3, 2019 at 2:14 PM
    #159
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Quality fuckin 1st post. Welcome. You’re one of many and why this place hasn’t been washed away in another flood.
  20. Feb 3, 2019 at 9:32 PM
    #160
    hrivera007
    hrivera007 Well-Known Member
    2017 Off Road Auto
    Good post. I'm interested on either borrowing the tool or getting the dimensions of the plate that goes inside the bearing. I think I can make one at work. Thanks
