ECGS Bushing - Is it a must?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rustytaco71, Jan 9, 2018.
  1. Feb 3, 2019 at 9:43 PM
    #161
    Nimbostratus
    Nimbostratus Well-Known Member
    Tuscaloosa, AL
    2019 Toyota Tacoma TRD-OFFROAD
    Pm sent .
  2. Feb 5, 2019 at 7:03 AM
    #162
    Trdinout
    Trdinout New Member
    Utah
    14 trd dcor
    2 inch leveling in front. 275/65 18
    How do I figure which bushing to order? My vibration feels like passenger side so I’m just going to do both.
  3. Feb 5, 2019 at 7:10 AM
    #163
    Rustytaco71
    Rustytaco71 [OP] Well-Known Member
    2018 4Runner
    Passenger side has a different bearing and to my knowledge shouldn’t give you any issues. For the drivers side bearing just got on ECGS’s website and they’ll have a menu to chose from for appropriate bushing and you’ll be able to find it.
  4. Feb 5, 2019 at 7:19 AM
    #164
    Trdinout
    Trdinout New Member
    Utah
    14 trd dcor
    Ok I found it. Thanks. I just searched the bushing itself originally and pulled up three different ones.
    Wakecoach likes this.
  5. Feb 5, 2019 at 7:37 AM
    #165
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    What size bushing do I need for 17’ OR? I also have a removal tool that I used for a 2010 Tundra. Could I use this tool as well? Thanks!
  6. Feb 5, 2019 at 10:51 AM
    #166
    Wakecoach
    Wakecoach Kiwi in FL
    Kurt
    2015 White TRD Sport 4x4 2001 Subaru Legacy Wagon Bilstein Touring Edition
    King ext, res/adj...3leaf Aal. ECGS bushing. Bullaculla relocate bracket. Pelfrey bilt skids. TC UCA. K+N, Weathertech Mats, TRD side steps, BROV Tacoma Attic, Prinsu Cabrac, TRD OR Tow Hook
    Did u get it sorted ? If in doubt call @ECGS .. Their customer service is amazing
  7. Feb 8, 2019 at 2:01 PM
    #167
    fl_taco
    fl_taco Well-Known Member
    manny
    Central Florida
    2020 Cement DCSB Off-road 4x4
    Stock
    Hey guys i just got the bushing. Wanting to see if any of you have a tool i can barrow or buy. Thanks for the help!
  8. Apr 2, 2019 at 6:13 PM
    #168
    mgmdclb
    mgmdclb Well-Known Member
    The Maritimes, Canada
    2018 MGM DCLB Sport
    Are guys getting this vibration with no lift and stock tires? I’m familiar with it on my 2nd Gen that was lifted. I swear I feel it in my 3rd on a recent highway run at fairly high speed for a few hours. 4000km on the odo
  9. Apr 2, 2019 at 8:11 PM
    #169
    Toyoland66
    Toyoland66 Well-Known Member
    Colorado
    09 GX470
    Mostly stock on 35s
    Since the diff is on the drivers side there is an axle tube that extends to the passenger side (not sure the exact term)
    If you look at the parts diagram you can see that Toyota uses the same needle bearing in the carrier on both sides of the diff, supporting the shaft where it enters the spider gears:
    https://parts.toyota.com/a/Toyota_2...T-AXLE-HOUSING--DIFFERENTIAL/674470-4301.html
    The difference being that the passenger side has a half shaft that rides on its own roller bearing within the axle tube, the CV shaft interfaces with this half shaft assembly and therefore has additional bearing support on the passenger side. On the drivers side the CV interfaces directly with the spider gear, being supported solely by the needle bearing.
    KingZee and deanosaurus like this.
  10. Apr 21, 2019 at 3:11 PM
    #170
    FiveStripes
    FiveStripes Well-Known Member
    Cliff
    2018 Tacoma TRD Sport Inferno
    Nitto Terra Grapplers on American Racing AR901
    I really want to complete this on my 2018 prior to my full suspension install next month. However, I dont feel comfortable doing this myself. Any members in the north Atlanta area that would be willing to provide an assist on this?
  11. May 11, 2019 at 5:01 AM
    #171
    Sootytom
    Sootytom Well-Known Member
    Tom
    I just completed the ECGS bearing upgrade.
    I've got a like new needle bearing removal tool
    Selling for $35 shipped. Pm me.
  12. Aug 22, 2019 at 4:38 AM
    #172
    salisbury4573
    salisbury4573 New Member
    Aaron
    2008 Tacoma SR5
    Just did the ECGS bushing upgrade last night on my 08, pretty easy job. 2 hours from start to finish. A 2 jaw puller with a slide hammer takes that needle bearing out quick and easy.
    rowdy1244 likes this.
  13. Oct 9, 2019 at 10:39 AM
    #173
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    because it will give you issues later. You can wait until it happens or do it while you are lifting the trk or whatever. I was not aware of this issue until my 2007 started this when it was around 80-90k miles. I thought that it was the wheel bearings but after so many times being under my trk, I've come to realize is the damn CV bearing. I've ignored it for at least 25k miles. The trk has 100k and it has become more annoying...aka noise is worst! I do not have the vibes. I've just ordered the part and Toyota should pull the head out of their ass for a F'd up design on this area.
    YMMV. You can wait until it comes up or you can do it next time you are working in that area of your trk. Good luck!
  14. Oct 9, 2019 at 10:41 AM
    #174
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Just a heads up. MANY people in 2nd and 3rd gens have reported the needle bearing issue even without lifts. It's not just a lifted problem
  15. Oct 10, 2019 at 11:47 PM
    #175
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    I’ve had several Tacoma’s in the past 20 years and never had an issue after being lifted. Sure it can happen but so can many other things.
  16. Oct 17, 2019 at 10:54 AM
    #176
    Quickdraw08
    Quickdraw08 Well-Known Member
    Andrew
    2019 White Tacoma TRD OR
    I was wondering if Toyota replaced/fixed the needle bearing on the 2019 ORDC model. I will be installing a lift (2") in a few days and don't want to replace something I don't have to, if the issue has been already addressed. Thanks in advance.
  17. Oct 17, 2019 at 11:31 AM
    #177
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    No they have not.
    Quickdraw08[QUOTED] likes this.
  18. Oct 31, 2019 at 10:02 AM
    #178
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    Has anyone here had a clunking issue at lower speeds/slowing down to a stop that was cured with the ECGS bushing? Taking it in in two weeks to have it done because it's too damn cold to do it myself. Have the vibe issue and this clunking started at the same time that I'm hoping will go away at the same time.
  19. Oct 31, 2019 at 10:05 AM
    #179
    Quickdraw08
    Andrew
    How big is your lift? Over three inches? Suspension lift?
  20. Oct 31, 2019 at 10:32 AM
    #180
    TurdTaco64
    Brandon
    Fort Collins
    888's on 5100 @ 0 clip so 2.5-3"
