ECGS Bushing + New Seal = Leaking Diff - HELP?! (NOW WITH SOLUTION)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveo27, Jul 8, 2017.
  1. Oct 8, 2019 at 9:34 AM
    #101
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    Installing thebushing this weekend. What diff oil should I purchase?
    Stupid question, where do I fill the diff oil into?
  2. Oct 8, 2019 at 9:41 AM
    #102
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Any 75w90 reg or syn will suffice. People get all pissey about brands, etc, but honestly it'll run on almost whatever. Fill plug is right behind the drives side CV axle. 10mm hex socket required.
  3. Oct 8, 2019 at 9:42 AM
    #103
    Dr. Emmett Brown
    Just noticed this was 2nd gen forum, will this oil also work for 3rd gens?
  4. Oct 8, 2019 at 9:46 AM
    #104
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yup. And a quick search here looks like the fill plug is in the same location.
  5. Oct 8, 2019 at 9:47 AM
    #105
    Dr. Emmett Brown
    Very nice. Appreciate the help :hattip:
  6. Jun 6, 2021 at 12:50 PM
    #106
    lefty9206
    lefty9206 Well-Known Member
    Jarrod
    2021 gray TRD off road
    None yet
    I ordered the 47027 and received the 47012 will it still work? Gonna be doing this to my 3rd gen soon.
  7. Oct 8, 2021 at 1:21 AM
    #107
    Nv90
    Nv90 Member
    Nigel
    2008 Tacoma Double Cab V6
    Heres some specs i found for setting that diff seal
  8. Dec 5, 2021 at 5:57 PM
    #108
    GeekFrog
    GeekFrog New Member
    Alex
    2007 White Tacoma OR
    2" lift: Bilstein 5100 OME 885 ICON AAL ECGS Bushing
    Thank you so much for this thread. I just noticed everything near the driver's side CV is coated in gear oil. After reading your thread I'm certain I put the seal in backwards. Wish I had noticed it sooner though since it's been about nine months since I installed the bushing and new seal. I drained the fluid and there was probably less than a quart in it. There were no large metal bits and only a small amount of shavings. Any chance my differential is going to be fine if I put the seal in correctly and refill it with fluid? Is the bushing potentially damaged from being run low on oil? Again, thanks for the post because I might have never figured out I put the seal in backwards.
    steveo27[OP] likes this.
  9. Dec 13, 2021 at 11:08 AM
    #109
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Put it back together and see what happens.
  10. Sep 5, 2022 at 1:39 PM
    #110
    lo2hi
    lo2hi Well-Known Member
    Chiro
    Portland, Oregon
    2006 Impulse Red Tacoma 4.0L 6-Speed 4WD
    265/75R16 Falken Wildpeaks AT3W & KMC Enduros AFE air intake Bilstein 5100 & Eibach Springs & Ironman4x4 performance leaf Magnaflow 12866 muffler
    Bro is the bearing backwards? I thought flat side should be out.
  11. Sep 5, 2022 at 2:12 PM
    #111
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The flat side is supposed to be out.
    But I’m not sure it’s an issue anymore, since that was posted back in 2019:thumbsup:
    lo2hi[QUOTED] likes this.
  12. Nov 21, 2022 at 7:32 AM
    #112
    ShawaiianS
    ShawaiianS Active Member
    Shawn
    Seattle
    Taco Time, Hawaiian style
    6" RCD lift, 5.11 ECGS front and rear, 33" Grabbers
    I know this is old, but I have a leak drivers side now after prolly 1k mi doing the 5.29 ecgs gears w/needle swap. The gap from the end of the cvs into the diff is slightly larger drivers side than pass and appears to be getting slightly larger and now a small amount of oil can be seen. Could the snap ring be bound up or could I have maybe not set the cv all the way in after swapping out the clamshell? I'll snap a pic this morning to update, thanks guys
  13. Nov 21, 2022 at 8:58 AM
    #113
    TnShooter
    Deogee
    STOCK
    All the CV axles I’ve seen on these trucks have maybe 1/8” play in and out. You can grab the cv at the diff and slide it in and out. You’ll feel it stop when it hits the snap ring.
    If you don’t feel it “clunk” when you pull out on it. You probably didn’t get the axle seated all the way in.
    Also, the axle seal should be seated flush with the differential, it doesn’t need to be set back into the differential. The further in you seat it, the more chance it will leak.
  14. Nov 21, 2022 at 9:12 AM
    #114
    steveo27
    Pittsburgh
    Pull the axle.
    Double check the seal.
  15. Nov 21, 2022 at 9:27 AM
    #115
    ShawaiianS
    Shawn
    Seattle
    I did the complete 3rd member/clamshell core swap from ecsg along with all new bearings (including the needle delete) and seals with the 5.29sc already installed. Didn't mess with any of the seals. It was a bitch getting the drivers cv back in, as I think I was fighting the snap ring not knowing the trick about putting grease on it to hold it in place. Also on the drive over the 90, I realized the vibration seems to go away when going around turns. Def noticeable more straight ahead
  16. Nov 21, 2022 at 10:11 AM
    #116
    TnShooter
    Deogee
    STOCK
    I’d check and see if the cv is still locked in.
