ECGS Bushing Poll
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jcareyDFW, Mar 19, 2020.
Has your needle bearing failed and needed replacement?
  1. I have no lift and my NB failed
    4 vote(s)
    3.5%
  2. I have no lift, NB fine
    29 vote(s)
    25.2%
  3. Lifted, diff drop, NB failed
    7 vote(s)
    6.1%
  4. Lifted, diff drop, NB fine
    10 vote(s)
    8.7%
  5. Lifted, no diff drop, NB failed
    21 vote(s)
    18.3%
  6. Lifted, no diff drop, NB fine
    44 vote(s)
    38.3%
  1. Mar 19, 2020 at 5:55 AM
    jcareyDFW
    jcareyDFW [OP] Well-Known Member
    2017 Tacoma TRD Offroad
    Eibach Pro Kit 265/75r16 Buckshots on Stock OR Rims
    I realize the topic has been beat to death but I hadn't seen a poll on the topic yet. I'm mostly curious about needle bearing failure rates on trucks lifted 2"-3". There is no doubt that the ECGS bushing is an upgrade from the needle bearing. Sorry if there is a similar poll out there somewhere.
  2. Mar 19, 2020 at 5:58 AM
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    If you pull your front left axle. Do the bushing. In the mean time, if it ain’t broke, don’t fix it.
  3. Mar 19, 2020 at 6:22 AM
    Evomike1
    Evomike1 Well-Known Member
    Glenwood Springs, CO
    2017 Tacoma Off-Road
    small lift here no issues yet, went from 20.5" hub to fender and 22" post front lift. So I am not really your target market, did not vote... Sometimes I think I hear it but hard to tell with all the other noises :)
  4. Mar 19, 2020 at 6:35 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    There’s been a few polls on this so you may not get the best results.
    Another contributing factor is many people replace the needle bearing during their lift install prior to it ever failing, that’s a big group not voting.
    LoMa and Freegolf like this.
  5. Mar 19, 2020 at 7:03 AM
    jcareyDFW
    Regarding the first sentence: I figured that was the case, just wasn't having much luck finding a thread with a poll.
    On the second note, I agree, there is a subset with no option to select. Although the data set will not be large enough to form a definitive conclusion I'm curious about a couple things in reality. a) The needle bearing is an inferior design and I wonder if there is a similar failure rate between lifted and stock vehicles
    b) If somebody did lift their vehicle and kept the needle bearing, was the needle bearing failure rate mitigated by using a diff drop.
    Seems like if you read threads on the subject you will basically die if you don't replace NB. I'm a numbers guy so I created the poll to satisfy my curiosity. Thanks all for humoring me.
  6. Mar 19, 2020 at 7:12 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    1.5” lift all around no problems. Every truck is different. I do have the bushing so if it does fail my bro will install for me. I also installed diff drop , carrier bearing.
  7. Mar 19, 2020 at 8:33 AM
    jcareyDFW
    Not sure if anybody is interested or not but I can post up results as they roll in, the more respondents I have the more accurate the results become. That being said, the sample size will doubtfully ever become large enough to draw any kind of accurate conclusion.
    As it stands:
    Regardless of lift or not 33% or respondents reported NB failure
    With a lift, failure thus far is 36%
    Stock configuration failure is 29%
    Of those respondents with a lift:
    No diff drop NB failure is 27%
    With diff drop installed NB failure is 9%
    I will update these figures as the data grows.
  8. Mar 19, 2020 at 8:49 AM
    hellfire0480
    hellfire0480 Well-Known Member
    Long Island
    2019 TRD OR Quicksand
    Eibach Pro lift, MR701, 285/70R17 AT3W, SOS Sliders, Sherpa RR
  9. Mar 21, 2020 at 4:32 AM
    Timbertoy
    Timbertoy Well-Known Member
    Wayne
    2019 Red Tacoma
    You left out on your poll - lift installed and ECGS bearing installed at same time. No apparent issue. Just preventative measures.
    jsinnard and 2ayne like this.
  10. Mar 21, 2020 at 3:13 PM
    awynne56
    awynne56 Well-Known Member
    Andy
    2019 Taco trd sport
    front grill pro
    Installed the ecgs bushing withe lift. I just did it because it’s a known weak point, rather not have to deal with it later
  11. Mar 21, 2020 at 4:59 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    You forgot the option for "had symptoms and pulled the NB and after inspection nothing was wrong with NB"
    That would be my vote. I have the NB somewhere in my toolbox just wasting space.
  12. Mar 21, 2020 at 6:46 PM
    jcareyDFW
    Those would've been valid options and if one sat down and thought about the possibilities they could get pretty extensive. With 50 respondents the results at this time are as follows:
    24% Chance of failure whether lifted or not
    13% Chance of failure without a lift
    29% Chance of failure with lift
    3% Chance of failure if lifted with diff drop
    26% Chance of failure if lifted without diff drop
  13. Mar 21, 2020 at 6:49 PM
    Bishop84
    Bishop84 Well-Known Member
    I was one of the early 3rd gen ECGS bushings. 2 1/4" lift.
    I did the needle bearing as a hail mary, then replaced with solid bushing.
    We actually had no idea if the diffs were the same, but I just hammered it in.
    Grossomotto likes this.
  14. Apr 3, 2020 at 6:01 PM
    BearWithMe
    BearWithMe Well-Known Member
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Thanks for the stats! Looks like a diff drop isn't such a bad idea after all. Not sure why everyone dumps on diff drops -- it's a solid concept.
  15. Apr 3, 2020 at 6:10 PM
    2ayne
    2ayne Well-Known Member
    Zayne
    Ohio
    2017 Cement TRD Pro
    Lifted both of my 3rd gens and installed the ECGS Clamshell bushing when I did the lift.
    Used a diff drop on both trucks.
  16. Apr 3, 2020 at 7:50 PM
    Dr. Emmett Brown
    You mean the 9 people who voted for those two options? Lol
  17. Jul 1, 2020 at 9:43 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Well my ECGS bushing failed.
  18. Jul 1, 2020 at 9:58 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    What happened to it? Burned up?
  19. Jul 1, 2020 at 10:24 PM
    Slashaar
    Josh
    Kansas City, MO
    Or Im ignorant idk.
    I have a lot of in/out play at the diff.
    No up/down.
    EDIT: I'm stupid, carry on. Its normal.
    uploadadventure likes this.
  20. Jul 2, 2020 at 7:19 AM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    This, that's me. If you lift, just do it while you are in there. It is obviously as issue and the part is only like $65. Put it in and forget about it. Or I guess you can lift without it and have to keep second guessing every noise and vibration thinking that you might grenade a diff.
    jsinnard likes this.
