ECGS Bushing Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheFallGuy, Apr 25, 2017.
  1. Apr 25, 2017 at 7:59 PM
    TheFallGuy
    TheFallGuy [OP] Well-Known Member
    The Dog House
    2015 PRO
    Got a quick question, I installed the ECGS bushing in my 2015 tacoma this evening. For those who've done it, how critical is it getting the new bushing flush w/the carrier. I've attached some pics, it looks recessed inside the carrier due to the bevel but it actually sticks out about 1/32" - 1/16". Is it good to go this way, I don't want to risk going to far and having to back it out. My original needle bushing actually sat inside that beveled area.
    Thanks in advance
  2. Apr 26, 2017 at 5:25 AM
    Bluesjam
    Bluesjam Well-Known Member
    Paul
    2020 Tacoma SR Magnetic Grey Double Cab 4x4
    I had read on the big thread that it was OK for the bushing to stick out 1/16" or so, as long as it's straight in the housing. Looks like your OK.
  3. Apr 26, 2017 at 5:41 AM
    Mongoose
    Mongoose Well-Known Member
    Catskill Mts. NY
    You're good, Chase from ECGS has said upto 1/4" sticking out would be OK. The bushing is longer than the OEM needle bearing.
  4. Apr 26, 2017 at 7:40 AM
    TheFallGuy
    The Dog House
    2015 PRO
    Thanks guys, I read in one of those endless pages threads about guys using a 1 5/16" socket reversed with good results. I used a standard race driver set which one puck is either to big (won't fit inside the rubber seal) or to small (allows the bushing to go in further than its supposed to) so I just wanted to be sure. Called ECGS this morning and they concurred it should be fine with a 1/16" or so either way.
    JoefromPTC likes this.
  5. Apr 26, 2017 at 11:20 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup. mine sticks out at least 1/8th of an inch, I just made sure the CV fully seats without bottoming on the bushing and i was good. Id rather have it sticking out further so the CV is SLIGHTLY less of a lever on the bushing itself.
    Either way you are all good.
