ECGS Bushing Questions (Friction?)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wicked1, Jul 10, 2022.
  1. Jul 11, 2022 at 7:23 AM
    wicked1
    wicked1 [OP] Well-Known Member
    I think they did just check, for the sake of checking, after the install..
    Here's a thread about it:
  2. Jul 11, 2022 at 7:26 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Mine never gets hot. Maybe he was low on fluid but it looks like the thread never went anywhere.
    Stop overthinking it.
    wi_taco and wicked1[QUOTED][OP] like this.
  3. Jul 13, 2022 at 9:02 AM
    wicked1
    OK, this is funny.
    Got the truck on the lift today. Have the bushing in the freezer, everything is ready to go. Pull the CV, and what's in there? A bushing!! hah. I always wondered if it was in there, because SOO many people w/ modified trucks have it. And, yes. It's there.
    I didn't build the vehicle.. "Mainline Overland" did, for someone else.. And I bought it from him a few years ago. I have a thick binder of invoices for everything, and none mention the bushing.
    Chris(NJ) and wi_taco like this.
  4. Jul 13, 2022 at 9:09 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    currently sitting at 125k miles on my ECGS bushing using 75w-90 synthetic oil in diffs and tcase over the life of the truck.
    ZERO ISSUES.
    Front diff oil came out decently clean at 60k miles, insanely clean at 120k miles - so clean that ill be upping the next oil change from what would be at 180k (60k mi OCI) to 200k (80k mi OCI).
    Doesnt surprise me the truck already had the bushing tbh, it was probably just subconscious that the builder did it when the lift was installed.
  5. Jul 13, 2022 at 9:14 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I'll chime in since I have it installed too. 30k on it using 75/90. Happy to report No Issues! Doesn't run hot, or anything like that.
  6. Jul 13, 2022 at 10:57 AM
    taco912
    taco912 Well-Known Member
    North of the Bridge
    2006 AC 4.0 AT 4x4 SR5 TRD OR
    Mine has only been in about 10K but I just did and axel reboot, wheel bearings and all the seals and the all looked good when removed.
  7. Jul 13, 2022 at 11:00 AM
    wicked1
    I don't know how long mine's been in.. At most about 80k miles! If it was installed when they did the lift and camper and all.. Looks good as new. But I don't know when it was installed.
  8. Feb 6, 2025 at 2:10 PM
    Cards3
    Cards3 Well-Known Member
    Jake
    Northwest Arkansas
    2011 DC Tacoma TRD offroad
    Stock
    I put in ecgs bushing probably a little over a year ago but there seems to still be a lot of play and the new seal I put in is leaking. Wondering if the play in CV wore out seal already?
    https://youtu.be/mhhyLtkh4kM?si=DvkRe7V3NCUi9_Yi
  9. Feb 6, 2025 at 8:55 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    Those instances of odd symptoms post ECGS change could be a number of things. Before I'd consider anything but an outlier I'd expect some corroborating accounts from others esp on a site like this where there's a large number of people that have installed them and drive lots of miles in tacomas.
  10. Feb 6, 2025 at 9:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That play looks normal.
    How far in did you drive seal?
    Flush is good. In any further and they tend to leak.
    What weight gear oil did you use?
    Has it ever leaked out of the breather under the hood?
  11. Feb 6, 2025 at 9:37 PM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    I did ecgs bushing ..took it on a 6 week trip no issues... I have wedge camper .n. 5 gal water 5 gal gas 45qt fridge..etc.
    Mpg's I improved bye changing from 285/75/16...to..255/85/16 weight saving
    ridefreak likes this.
  12. Feb 7, 2025 at 5:26 AM
    Cards3
    Jake
    Northwest Arkansas
    Stock
    I believe I set the seal flush. It's been over a year and I just noticed it leaking. I used 75W90. Hasn't leaked out of the breather. I'm currently out of town working and called the local Toyota dealership here to see if they could change the seal they told me it would cost $630 to change a $29 seal that it takes 4.5 hours. I'm pretty sure when I did this last I didn't have to even remove the CV from the hub I just had to undo the 2 bolts on the lower control and was able to remove the CV from pumpkin to get to the seal. Half tempted to buy couple jack stands and do it in their parking lot thinking it would take be about an hour laying on the ground in the cold. Dealerships are such crooks.
    ridefreak and TnShooter[QUOTED] like this.
  13. Feb 8, 2025 at 6:54 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    That's how I removed mine, had it apart in 20min.
